4" Spindle lift onto 3" Rough country Struts??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma Pretty Boi, Mar 31, 2021.
  1. Mar 31, 2021 at 12:09 PM
    Tacoma Pretty Boi
    Tacoma Pretty Boi [OP] Member
    2020 White Tacoma SR5 V6
    265/75 R16
    Hey Guys so i installed a 3" front Strut lift from Rough Country and now i wanna go 1" higher with the 4" front Spindal Maxtrac lift so i can cover my 32's a little better on turns my question is does anybody know if i will have any problems doing this ? Such as will the 4" spindle lift fit with the 3"lift Struts.
  2. Mar 31, 2021 at 12:12 PM
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    You'll be getting a 7" lift out of that combo. Better to remove the RC struts or if possible lower the struts to the smallest height and add the spindles.
    Tacoma Pretty Boi[OP] likes this.
  3. Mar 31, 2021 at 12:19 PM
    Tacoma Pretty Boi
    265/75 R16
    Ok stupid question but how do you lower the struts? And also what would another option be to get that 1" lift with the Rc Struts. Cuz just with the Rc struts my stock spindle already feels like it barley made it in length when i put on these Struts
  4. Mar 31, 2021 at 12:30 PM
    renlo
    Im not familiar with the RC struts but was asking if they are like the Bilstein 5100s with the adjustable clip settings. If not and you dont have your oem suspension, many are often sold on here at a low cost.
  5. Mar 31, 2021 at 9:11 PM
    Tacoma Pretty Boi
    265/75 R16
    Ok if i take off the Rc struts any idea what struts would go good with the 4" maxtrac spindle lift? Any idea what the Stock Struts are on the 2020 Sr5 tacoma
  6. Apr 1, 2021 at 9:53 AM
    renlo
    you can use oem struts from trd or or sport. It doesn't matter.
  7. Apr 1, 2021 at 10:22 AM
    Rivermaniac
    Rivermaniac Well-Known Member
    You can use 5100 bilsteins with 884 coil set at the bottom setting and will get the maxtrac plus 1 “ from the coil.
  8. Apr 1, 2021 at 10:29 AM
    Car Ram-Rod
    Car Ram-Rod Well-Known Member
    Don’t the spindles need to be coupled with a longer coilover to begin with so technically the rc coil overs will be 1” too short?
  9. Apr 1, 2021 at 10:33 AM
    Car Ram-Rod
    If I’m thinking of this correctly you should be able to put a 1” lift spacer (1/2” thick actually) on the rc struts, or lower the rc coil overs and put a larger spacer, along with the new spindles to achieve the 4” lift.
  10. Apr 1, 2021 at 10:35 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    No, a lift spindle retains all stock geometry. The only thing that is different is that the hub moves down on the spindle 4" lower which creates 4" of lift.
  11. Apr 1, 2021 at 10:36 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    No, to get 4" of lift with a Maxtrak spindle the only thing you need to do is install the spindle, nothing else. You must use stock height coilovers or you will be higher than 4".
  12. Apr 1, 2021 at 10:36 AM
    Car Ram-Rod
    If the spindle is getting taller wouldn’t the shock need to be a longer shock as well?
  13. Apr 1, 2021 at 10:39 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    No, as I explained previously all stock geometry is maintained the only difference with a lift spindle is that the hub moves down lower on the spindle nothing else changes. The position of the UCA and LCA relative to the spindle are still the same.
  14. Apr 1, 2021 at 10:40 AM
    Car Ram-Rod
    Oh so only the hub is moving? Is the spindle the same size as stock or its larger?
  15. Apr 1, 2021 at 10:46 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    It is larger, much stronger and actually adds +3/4" to your track width per side : https://maxtracsuspension.com/i-30500089-2005-18-tacoma-2wd-6-lug-4-lift-spindles.html
    Just in case you have not realized this - they can only be used on a 2wd because a s the hub moves down the hub moves below the LCA leaving no place for the axle to go.
  16. Apr 1, 2021 at 10:52 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
  17. Apr 1, 2021 at 11:08 AM
    Car Ram-Rod
    Mind blown. I knew this lift was for a 2wd, however, I’ve never lifted 2wd truck (kinda silly) so I never even thought about the fact that the hub can be in line or below the LCA.
    Thanks for the info!
  18. Apr 1, 2021 at 12:54 PM
    renlo
    Also keep in mind that spindle lifts will push your wheel further out and will mimic a negative offset wheel.
  19. Apr 1, 2021 at 1:05 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    we already covered that...
  20. Apr 1, 2021 at 3:10 PM
    Wagsbro
    Wagsbro Will
    Will
    Plano TX
    2018 gray tacoma trd off-road
    2-2.5 inch lift with Bilstein 6112/5160s included in the wheelers trail pro lift kit. And 255/85r16 Yokohama Geolander G003 tires.
    you don't need a 7 inch lift for 32's, a 3 inch lift with a proper alignemnt should fit with no rub
