4 inch vs 3 inch lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rigo.rivero, Jun 2, 2018.
  1. Jun 2, 2018 at 3:40 PM
    Rigo.rivero
    Rigo.rivero [OP] Active Member
    Rigo
    2018 TRD OFF-ROAD
    Blacked out grill and badges.
    Hello to everyone! I purchased a 2018 Tacoma trd offroad a week ago and I really want to lift it and put some 33” tires. I called a shop near me and the said that they can sell me a 4” rough country lift for $850 installed. I cannot find any reviews on that lift so I’m scared that I might not like the ride and be stuck with it. I’m also thinking about a 3 inch lift instead but I want to be able to fit 33s or 285/70/r17 without having to do the body mount shop. Can anyone help me go in the right direction? I’ve seen a lot of videos of people using the 3” leveling kits but some use aftermarket control arms and some don’t even mention it.
  2. Jun 2, 2018 at 3:47 PM
    jdsundevil
    jdsundevil Well-Known Member
    2018 TRD Sport DCSB
    *edit*
    I thought better and decided not to provide advice since I’m no expert.
  3. Jun 2, 2018 at 3:49 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    You do understand that the body mount chop is because of width and I'd assume the 4" lift is a drop bracket and to do that you are cutting the frame as well just in a different spot and it's a hell of a lot harder to go back from a drop bracket than normal lift.
    And that rough country lifts are terrible.
    I'm going to assume you're just after looks though. Many say you can fit a 33" tire if in the 255 width.
    The mention of control arms is because you need new control arms for proper alignment if that lift is from coilover etc and not just a spacer/block lift.
    You will quickly find some saying you can fit that tire without rub but they depends if you wheel, your alignment and what lift.
    If you venture into total chaos UCA I can guarantee you will need a body mount chop as I have them and have found anyone with them to have all the same rub issues I had.
    That said a body mount chop really isn't that bad...
    TopKick and Thyces like this.
  4. Jun 2, 2018 at 3:55 PM
    Clearwater Bill
    Billy
    Largo Florida
    255 80 17 on stock wheels fit with no cutting rubbing or lift.
    BTW, lift doesnt give clearance anyway. Tire and wheel choice do.
    And anything over approx 2.5" will inherintly put you at risk for other issues to deal with.
    Do lots of reading before you jump. No reason to be in a hurry. Hurry is often expensive.
  5. Jun 2, 2018 at 3:56 PM
    Rigo.rivero
    Rigo
    2018 TRD OFF-ROAD
    So if I just do 3” spacers in the front and blocks in the rear then I don’t need control arms? Do I need a diff drop or any other mod to avoid vibration or premature damage to the truck? Sorry about my ignorance on this subject I just want to do it right the first time.
    71tattooguy likes this.
  6. Jun 2, 2018 at 3:58 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Spacers and blocks :(. Do yourself a favor and leave it stock.
  7. Jun 2, 2018 at 4:00 PM
    Rigo.rivero
    Rigo
    2018 TRD OFF-ROAD
    Clearwater bill, thanks for the advise! Trust me I’ve been there before and that’s what I’m trying to avoid. I guess I need to learn how to be patient lol
    Guami54 and Joe23 like this.
  8. Jun 2, 2018 at 4:00 PM
    Joe23
    If you want to do it right I'd skip block and spacer lol.
    This has been posted so many times.
    Just saying a good lift isn't cheap. Sure you don't need to go and get a $8000 lift since you won't be using it for off road I'd imagine but for $1500 possibly even less you could get a much better lift then blocks etc.
    But like bill mentioned above lift doesn't mean everything for fitting a 33"
  9. Jun 2, 2018 at 4:02 PM
    Joe23
    Just saying without changing anything you can run a 255 85 16 on your stock wheels and suspension
    Tocamo likes this.
  10. Jun 2, 2018 at 4:02 PM
    jdsundevil
    2018 TRD Sport DCSB
    If you are just going for looks, this Pro Comp kit is what I put on my truck and it runs great. Also I have 285/70/17 with 17x9 Fuel Recoil Wheels.
    https://www.4wheelparts.com/Suspension/Pro-Comp-Nitro-3-Inch-Leveling-Lift-Kit-65205K.aspx?t_c=1&t_s=358&t_pt=9333&t_pn=EXP65205K&utm_source=google,google&utm_medium=cpc,cpc&utm_campaign=shopping&emlprox=out&ppcfon=1&gp=1&scid=scplpEXP65205K&sc_intid=EXP65205K&gclid=EAIaIQobChMIrMi3g4q22wIVCkVpCh3wQQ-LEAQYAiABEgJBLfD_BwE
    I drive 99.5% of the time on streets so my kit was only for looks. I’m sure if you want to do a lot of off-roading you may want to go a different route.
    Also as others have mention above, spacers and blocks are not ideal. I’ve been told they put a lot of pressure on the suspension and long term may cause issues. Again, speak to a professional about their thoughts.
    71tattooguy and El Latigo like this.
  11. Jun 2, 2018 at 4:02 PM
    tcjacado
    tcjacado Well-Known Member
    Anything over 2.5 your front cv angles are going to be horrible causing all kinds of problems. Stay away from 3 and 4 inch lifts on that 4wd. Save your money, save your money some more and get some foxes and a add a leaf.
    TRSickler, Thyces, jeremy5000 and 3 others like this.
  12. Jun 2, 2018 at 4:06 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you dont need a lift for approach and departure angles offroad, life will be better w/o one. And 33" are going to give you true lift and axle clearance anyway.
    If you cant live w/o the look, make life easy. Call Marie @HeadStrong Off-Road tell her your goals and order what she tells you to.
  13. Jun 2, 2018 at 4:09 PM
    Joe23
    Oh and don't forget 33s will hurt your mpg, and power
  14. Jun 2, 2018 at 4:11 PM
    Rigo.rivero
    Rigo
    2018 TRD OFF-ROAD
    Ok let me start over lol. I am mostly doing it for the looks, but I want to be able to do some light off-roading every once in a while. For the hardcore stuff I have a 99 montero on 35’s. The Tacoma is my daily driver but I’ll like to take it for some offroad adventures some day lol
  15. Jun 2, 2018 at 4:12 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Do a 6 inch lift and put 48 inch tires on it
    DFrench, JSlamson, TacoTim85 and 4 others like this.
  16. Jun 2, 2018 at 4:13 PM
    Joe23
    Put some 265 75 16 or 265 70 17 for a 32"tire
    Won't need to do any cutting or anything and you'll keep some mpg and these trucks are pretty capable without anything done to them but better tires for light off road.
  17. Jun 2, 2018 at 4:13 PM
    Rigo.rivero
    Rigo
    2018 TRD OFF-ROAD
    Jdsundevil, your truck looks great!
    kgilly and jdsundevil like this.
  18. Jun 2, 2018 at 4:14 PM
    Joe23
    :rofl:
    bridge10 likes this.
  19. Jun 2, 2018 at 4:17 PM
    Joe23
  20. Jun 2, 2018 at 4:19 PM
    Clearwater Bill
    Billy
    Largo Florida
    @Joe23 beat me to it.
    Function over form.
    Joe23 likes this.
