4 Inch spindle lift with 16 inch wheels???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by natural1, May 30, 2014.
  1. May 30, 2014 at 7:31 PM
    natural1
    natural1 [OP] Member
    Keith
    Saint Cloud, Fl.
    07 PreRunner SR5
    I have 16 inch rims on my 07 Tacom Pre-Runner. I want to use 4 inch spindles in a lift kit will they work with my 16 inch rims. A note in the add says need a 17 inch wheel. If so, why?
  2. Nov 9, 2014 at 6:52 PM
    TXAggieTRD
    TXAggieTRD Well-Known Member
    Andrew
    TX
    '11 Pre-Runner V6 TX TRD Package
    Bump. Same question here. Is there a way to use spindles with 16's?
  3. Nov 9, 2014 at 7:11 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    must be a clearance issue with inner diameter of wheel
  4. Nov 9, 2014 at 7:14 PM
    crushh87
    crushh87 Woo Pig
    Jack
    Texas
    2013 Prerunner Silver
    4in MaxTrac Lift Spindles, 2in Pro Comp AAL, MB 352 16x8.5 Wheels, 285/75/r16 General Grabber AT2s, 2.7L I4
    Check the backspacing. If it is anything with more than 4.5in of BS they won't work without spacers
    I have 16s with 4.5in of BS and everything works fine. Only thing with 16s is make sure when you get your tires balanced the wheel weights won't hit your calipers.
