4-inch lift kit
Discussion in 'Suspension' started by bmo&taco, Apr 30, 2021.
  1. Apr 30, 2021 at 11:31 AM
    bmo&taco
    bmo&taco [OP] New Member
    2021 TRD Sport Tacoma LB
    Hi guys, I recently joined the Tacoma family and purchased a 2021 TRD Sport long bed earlier this month and I'm eager to get started on the mods, however, I want to make sure I get the proper guidance because this is all new to me.
    I'm planning to get a 4-inch lift that will be a comfortable and not so stiff ride. I really like the King shocks but from what I can see they only go up to 3-inches, unless I'm missing something.
    I don't really have a budget but I don't want it to be overkill for my needs. This is going to be my "trophy truck" and maybe taken off-road a couple of times a year. Thanks for helping out!
  2. Apr 30, 2021 at 11:34 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Do you have a 2wd or 4wd ?
  3. Apr 30, 2021 at 11:36 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    If you're 2wd, Maxtrac spindles are a great option for 4" lift without needing to change upper control arms. If you have a 4wd i would avoid the drop bracket style lifts and stick to a coilover/suspension lift of 3" or less to keep wear on the CV axles to a minimum.
    BudFriendguy and bmo&taco[OP] like this.
  4. Apr 30, 2021 at 11:36 AM
    BassAckwards
    Oh, and welcome aboard!! Hang onto your wallet :D
    bmo&taco[OP] likes this.
  5. Apr 30, 2021 at 11:37 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    just had to jump in and steal my thunder :smack:
    BassAckwards[QUOTED] likes this.
  6. Apr 30, 2021 at 11:39 AM
    BassAckwards
    Sorry, i just really dont want to see OP put a drop bracket lift on his truck if we can avoid it..
  7. Apr 30, 2021 at 11:39 AM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Also keep in mind lift doesn’t equal ground clearance. Need bigger tires for that. 2.5-3 inch lift, cmc and some plastic trimming and 33s seems the basic “plan to off-road infrequently” needs.
  8. Apr 30, 2021 at 11:41 AM
    bmo&taco
    it's a 2WD, forgot to mention that. Thanks for the recommendation.
    I'm curious, is it possible to get a 4-inch lift with King suspension?
  9. Apr 30, 2021 at 11:43 AM
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    Kings + 1 inch spacer?
    bmo&taco[QUOTED][OP] likes this.
  10. Apr 30, 2021 at 11:43 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Yes, google Maxtrac spindles super easy way to do a 4" lift while maintaining all factory geometry and any stock size coil over will work..
  11. Apr 30, 2021 at 11:44 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    You wanna think about that for a few minutes and edit your post ?
    Mmaira2018 likes this.
  12. Apr 30, 2021 at 11:44 AM
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    No
  13. Apr 30, 2021 at 11:50 AM
    bmo&taco
    I'll look into Maxtrac spindles @Evenflow. Thanks
  14. Apr 30, 2021 at 11:51 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    you should bro...
  15. Apr 30, 2021 at 11:55 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Stick with a 3"
    There is absolutely no performance advantage to a 4". A well thought out 2.5-3" lift using cloilovers will vastly out perform some lame 4" lift with spacers or drop brackets.
    A little bit of hammering and a CMC is all you need to fit some bigger tires.
    Mmaira2018, bmo&taco[OP] and barf like this.
  16. Apr 30, 2021 at 11:57 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Did you read the info ? he has a 2wd so no spacers or db's needed
  17. Apr 30, 2021 at 12:01 PM
    bmo&taco
    If I go with the 3-inch king suspension lift kit, would I still need a CMC.
    Also to note, I plan on getting some 33s and 17" wheels
  18. Apr 30, 2021 at 12:28 PM
    jbrandt
    Justin
    All I said was that there is no performance advantage to that extra inch of lift. Doesn't matter if it's 2wd or 4wd.
  19. Apr 30, 2021 at 2:23 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Well there is a ground clearance gain in both approach and crown with that extra inch and the way a maxtrac spindle works it would be like putting a portal axle on a 4wd so you do absolutely gain front diff clearance to ground
  20. Apr 30, 2021 at 2:29 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    don’t just do a CO lift on a 2wd, first you can’t do 3” without ending up with horrible alignment spec’s and what everyone always forgets is that when you crank up those coilovers and push those control arms down you narrow your front track width. 90% of the keyboard warriors on this site don’t even realize that their rear track width ends up wider than the front and the steering conditions that it creates. If you do the spindles all of your lift is achieved by the front hubs being relocated lower on the spindle. Your control arms stay flat, you have zero pre load on the co’s and you sit in the middle of the stroke instead of being close to topped out with minimal down travel to maintain tire contact adequately.
    If you pair a maxtrac with a king co it will be really nice. Yes, no matter what you do you will need a cmc.
