4 hella horn mod Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 20somethingwidataco, Nov 11, 2017.
  1. Nov 11, 2017 at 4:04 PM
    20somethingwidataco
    20somethingwidataco [OP] Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Hey all, Just installed 4 hella horns into my taco, But I blew the stock 10amp fuse after honking it twice (Its "hella" loud) I was wondering If I could up the amp of the fuse to say a 15, or 20 amp fuse with out causing any problems. All the horns are grounded properly, and wired properly (ive done the install 3 other times, its simple) Thanks for the info!
    -Kidwidataco
  2. Nov 12, 2017 at 12:11 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Not a good idea, your fuse is there to protect the electrical circuit and is blowing because the circuit capacity is being exceeded. The correct thing to do would be to run a relay to the battery activated by the stock horn wiring, then you can draw much more current than 10A.
    Tullie D and Key-Rei like this.
  3. Nov 12, 2017 at 12:13 AM
    20somethingwidataco
    Will
    Washington State
    Ya, that's I was thinking. It's what I'll do next time I have time, I'll just keep replacing the amps when they blow and try to keep off my horns til then
  4. Nov 12, 2017 at 6:23 AM
    Muddinfun
    Muddinfun Well-Known Member
    Just disconnect 2 of the horns til you get around to wiring it correctly.
    crashnburn80 likes this.
  5. Nov 12, 2017 at 10:28 AM
    Muddinfun
  6. Nov 12, 2017 at 11:39 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    That's funny!
  7. Nov 13, 2017 at 9:33 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    Electromagnetic "buzzer" type horns such as those can each peak at as much as 25 to 30 A at startup, with 18 to 20 A peaks and 10 to 12 A continuous draw.
    The oscilloscope trace below show the current draw for a single Wolo Maxi Sound electric horn. In this test the horn was powered directly from a 45 A power supply via 10 gauge wires--i.e. it was fed all the power it could possibly want.
    Had the wiring been lesser gauge and/or the supply fused the horn would have been "starved" for power, the voltage would have dropped, and it would not have draw as much current.
    The four horns you installed using the OEM wiring were likely significantly starved--they will be much louder once a relay and higher capacity supply is installed. I would 12 gauge wire for both the supply and ground, with a 30 or 40 A inline fuse tied directly to the battery:
  8. Nov 13, 2017 at 10:22 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    2 pairs of those horns in NJ or NY is just begging for someone to follow you home or to work off of their normal route....
    The stock wiring side needs to be connected into the switching input side of a relay. The horns then should be wired directly to the battery, passing through the switching output side of a relay. I had a setup like this about 20 years ago with an airhorn and compressor.
  9. Nov 13, 2017 at 11:16 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    The OP sounds as though he knows what he's doing, nonetheless here's a generic horn wiring w/relay diagram:
  10. Nov 25, 2017 at 12:28 AM
    20somethingwidataco
    Will
    Washington State
    Yup, ran a relay with a 30 amp fuse from the battery. It's super loud now and hasn't popped a fuse. In WA it means get the f out of the way lol
  11. Nov 25, 2017 at 5:41 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    Cool...
  12. Nov 25, 2017 at 5:52 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I few years ago I did this very mod on a friend's Matrix. I juiced the horns directly off the battery with a 30 amp fuse and used a relay with the stock horn circuit has the signal source.
  13. Jan 13, 2018 at 4:31 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Did the airhorn get anyone to follow you home?
  14. Oct 19, 2019 at 5:59 PM
    20somethingwidataco
    Will
    Washington State
    Nope, not yet
  15. Oct 20, 2019 at 4:50 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Did you use your OEM horn harness as a “switch” for the relay?
  16. Oct 20, 2019 at 5:41 AM
    caribe makaira
    Caribbean, Puerto Rico
  17. Oct 20, 2019 at 10:35 AM
    20somethingwidataco
    Will
    Washington State
    I ran mine straight from the battery, to the hella horn relay, then to each horn
  18. Oct 20, 2019 at 10:40 AM
    caribe makaira
    And your "switch" is?
  19. Oct 20, 2019 at 2:00 PM
    20somethingwidataco
    Will
    Washington State
    Not sure what you mean by switch. Its just connected to my horn
  20. Oct 20, 2019 at 3:15 PM
    caribe makaira
    :thumbsup:
