4.56 or 4.88
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ten Eight Rider, Mar 30, 2020.
  1. Mar 30, 2020 at 2:29 PM
    Ten Eight Rider
    Ten Eight Rider [OP] Well-Known Member
    Central California
    2006 White Tacoma SR5 DCLB 4x4 V6
    Fox 2.5" Coilovers, Fox 2.0 Rear Remote Reservoir DSC, SPC Light Racing UCA, Wheelers Progressive 1.5" AAL, Wheelers Bump Stops, Wheelers Braided Brake Lines, Fuel Revolver 16x8, Toyo AT 265/75/16, ECGS Bushing, Energy Suspension Steering rack bushings/sway bar bushings, All-Pro Sway Bar Links, At the Helm Fabrication bumpers (front and rear), Cali-Raised LED lights, Leer Cap
    Looking for suggestions...
    I have 2006 DCLB 4x4 V6. I've added ATH Fab front/rear plate bumpers, and Leer camper shell. I'm adding ShmellFab sliders next week and doing the CMC. I plan to ad a winch (Warn 8000s) and full BAMF skids within the next 3 months. I'm currently lifted 2" and running 265/75/16. In about two weeks I will be switching to 295/75/16 BFG KO2 (33.40" tire), which are heavy tires, so I am going to do a gear swap.
    I've spoken to a couple of reputable gear manufacturers/mechanics (MobileGear and Nitro) who both told that 4.56 would be a good gear choice for 295/75/16. It seems like a lot of guys in this forum are swapping out to 4.88 gears with 33" tires. Am I missing something, should I go with 4.56, or 4.88?
    Please give me some detail why one or the other. Thanks!
    Sna likes this.
  2. Mar 30, 2020 at 3:03 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I'd think little difference. If you have an auto. W/OD, the 4.56 with 33.40" tires will run 1927 rpm. @ 60 mph. The 4.88 with 33.40" will run 2062 rpm. @ 60 mph. To me, 136 rpm. ain't much difference. Good luck. All sounds good.
    Mully likes this.
  3. Mar 30, 2020 at 3:17 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    So a simple equation that puts you roughly in the ballpark of what gear ratio to go with based solely on tire size would be
    (Stock gear ratio) × (New tire size) ÷ (Old tire Size) = New gear ratio
    Example for my truck
    3.73 x 35 ÷ 31.65 = 4.12
    Now since I like to do a lot of crawling and have a lot of extra weight added on I opted to go with 4.56 rather than 4.10 or 4.30 for more low end torque and some giddy up.
  4. Mar 30, 2020 at 3:40 PM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    I'm running 456 and like them, 488 would've worked fine for me too, most of the speed limits @ here are 60-65.
  5. Mar 30, 2020 at 3:43 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I’ve got 4.56 full armor with 285/75/17 and a auto, I love the way it performs I’d do 4.88 if you have plans for 35s.
  6. Mar 30, 2020 at 6:22 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I can't believe, as much as I've read about gearing, I've not seen this formula. Won't tell you what you need, just tell you what will get you back to where you were before the tire change. That is great. Thanks.
    SassySquatch69, Hikerbox and SR-71A like this.
  7. Mar 30, 2020 at 7:06 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    I have 35s and 4.88s. Do 4.56.
  8. Mar 30, 2020 at 7:37 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I have 32's with 4.10 & 2.7, auto., 4X4. Very weak puppy, straining constantly.
  9. Mar 31, 2020 at 6:18 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    I'm Maggie supercharged w/ 2.8" pulley running 35's and 4.56 gears with light armor. Truck is a rocket :burnrubber:
  10. Mar 31, 2020 at 9:22 AM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    When figuring gearing, big difference in 2.7, auto, 2.7 MT, 4.0 auto. 4.0 MT, supercharged, not supercharged. Everything's got to be figured in.
    EatSleepTacos, Sna and Strictlytoyz like this.
  11. Mar 31, 2020 at 4:44 PM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    6-speed with armor, 33’s and other goodies. I will be going 4.56 gears soon, even though I know I’ll be slightly over geared.
    If I was the same setup with an AT, I’d most likely go with 4.88’s. YMMV.
  12. Apr 1, 2020 at 9:33 AM
    Ten Eight Rider
    Central California
    So for guys running 33's with V6 Auto Trans and 4.88 gears, what is your top speed on freeway? Am I correct to think I'll have better freeway speed with 4.56?
    Right now I drive 75-80 mph often! I think it would suck if I couldn't get my truck up to 75 mph.
    Jared8907 and kingk0ng like this.
  13. Apr 1, 2020 at 9:37 AM
    tymebandit951
    tymebandit951 Well-Known Member
    Boise, ID
    2013 4x4 DCSB
    I'm running 33s with 4.88 and my truck is comfortable at 60-70. I can surely go 75-80 but my rpms would be pretty darn high. At 65 I'm sitting at about 2500ish rpms. However, when there is a steep uphill grade, my truck doesnt skip a beat
  14. Apr 1, 2020 at 9:39 AM
    MA_TACO
    Wesley Chapel, FL
    On 33's with 4.88 auto you'll be cranking over 3000 rpms at that speed. I'm running 35's with 4.56 auto and at 70mph my rpms are at 2250
  15. Apr 1, 2020 at 10:11 AM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    75 mph. on 33" with 4.88 = 2609 rpm. 75 mph. on 33" W/ 4.56 = 2438 rpm
    shmabs likes this.
  16. Apr 1, 2020 at 10:27 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    OP, do you have auto or manual trans? That will make a difference in making your choice. Also, what elevation are you at? If you live at a higher elev like 5000ft and up, your motor loses more power so lower gears are better suited.
    FWIW, I have 285/75/16 that I'm running 4.56 with an auto trans. Ratio seems really good to me at 5200ft elevation. I also ran 265/75/16 as well with these gears and I liked that as well. IMO, if you have an auto trans, 4.88 sounds more appropriate. If manual, then 4.56.
    Sna and smw62891 like this.
  17. Apr 1, 2020 at 10:30 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Manual and auto are different. Manuals are geared lower overall.
    OP, you're kinda in the middle ground with the 295s. Your truck is a heavy girl, so I would recommend 4.88.
  18. Apr 1, 2020 at 10:36 AM
    boostedka
    James
    NM
    Also, check out this site for calculating: http://www.grimmjeeper.com/gears.html
    A750F is the auto trans. I don't recall the code for the manual.
    EDIT: RA60F is the manual trans code
  19. Apr 2, 2020 at 6:24 AM
    Ten Eight Rider
    Central California
    My truck originally had 245 tires so with that math, it works out to 4.08. Seems like 4.56 would be the better choice.
  20. Apr 2, 2020 at 6:32 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Just keep in mind that just like @rphillips stated this equation basically just puts you in the ball park of the gearing that would bring you back to a stockish feel. With that in mind, going 4.56 like you stated with the AT I don't think you'll be upset. I have a MT on 35's and feel like I'm slightly overgeared for DD use but feels great offroad
