4.0 Timing chain replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JohnQ public, Jun 28, 2017.
  1. Jun 28, 2017 at 9:52 AM
    JohnQ public
    JohnQ public [OP] Member
    Corpus Christi, TX
    09 Taco Prerunner 4.0
    Hello tacomaworld.
    I am getting ready to replace my timing chain on my 09 PreRunner with the 1GR-FE engine. I am mechanically inclined and have done many engine rebuilds before. This engine is new to me so I have a question that needs to be answered before I can start.
    Do you have to pull the PAN SUB-ASSEMBLY off in order to take the timing gear case off?
  2. Jun 28, 2017 at 9:56 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    If it was me I would pull the engine out of the truck and put it on an engine rotisserie. That's what I do when I replace the timing gain in the 3.6 piece of shit chevy engine. Way easier to work on that way.
  3. Jun 28, 2017 at 9:59 AM
    JohnQ public
    Corpus Christi, TX
    I am not going to remove the engine from it's bay. Besides there is so much room in there compared to my old 1992 4Runner with the 3.0 engine. This engine is much easier to work on and tions of room.
    stickyTaco and Brian007Taco like this.
  4. Jun 28, 2017 at 10:01 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    why do you feel the need to replace the timing chain?
    I have never heard of anyone breaking one.
    Master Z, DaveInDenver, JSU and 2 others like this.
  5. Jun 28, 2017 at 10:02 AM
    Bebop
    Nick
    Well that's what I would do and I would just replace every seal and gasket while I'm at it. Front main, rear main, valve covers, oil pan, idler pulleys, timing cover gasket, new coolant, oil, transmission fluid would be replaced as well. If I was gonna go through that much effort I would just build it so it would be like new again.
    hresendiz25 likes this.
  6. Jun 28, 2017 at 10:03 AM
    Bebop
    Nick
    I was also curious about this.
    Tar Heel likes this.
  7. Jun 28, 2017 at 10:04 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Me too why change it?
    PackCon likes this.
  8. Jun 28, 2017 at 10:07 AM
    JohnQ public
    Corpus Christi, TX
    The reason I'm changing it is because one of my camshaft timing gears sensor tab broke. Since I have to change that out and I have 225k miles on the engine, I might as well replace all the timing chain assembly while I'm in there.
    hresendiz25, Athlaos and honda50r like this.
  9. Jun 28, 2017 at 10:27 AM
    JohnQ public
    Corpus Christi, TX
  10. Jun 28, 2017 at 10:31 AM
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    Are you also changing sprockets?. Chain and sprockets wear out toguether.
    hresendiz25 and JSU like this.
  11. Jun 28, 2017 at 10:33 AM
    JohnQ public
    Corpus Christi, TX
    Yes I am. Already ordered the whole package.
    BassAckwards likes this.
  12. Jun 28, 2017 at 10:37 AM
    nd4spdbh
    SoCal
    i was gonna say just replace that part unless it caused damage to the chain n sprockets.... otherwise those are going to be fine.
  13. Jun 28, 2017 at 10:46 AM
    JohnQ public
    Corpus Christi, TX
    Normally I would agree, but my thinking is, since I have to take the timing chain cover off just to get that DAMN! long bolt off the can, I might as well replace everything since I have access to it. Better now than redoing the whole process over again in the future. Too many fish out in the bay that need catching than repairing my truck.
  14. Jun 28, 2017 at 11:12 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Curious what your oil change interval is? Looks pretty nasty in there.
    Durnaia likes this.
  15. Jun 28, 2017 at 11:17 AM
    JohnQ public
    Corpus Christi, TX
    Yes it does look bad. I purchased this truck from a friend and he did the oil change the day before I bought it. I just put 3k on it and I was going to clean it at the same time I changed out the timing chain and start putting synthetic oil in it and change it every 4k.
  16. Jun 28, 2017 at 11:25 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    According to the service manual, it looks like both the sub pan and main pan need to come OFF.
  17. Jun 28, 2017 at 11:30 AM
    JohnQ public
    Corpus Christi, TX
    Damn! I read that also but I saw a lot of 4.0 Timing chain replacement pics on the web with the pan still attached and some with it removed. I was just hoping that the removal is not necessary. I hate working on the ground in my old age. Oh well, thanks for the response.
    scottalot likes this.
  18. Jun 28, 2017 at 12:20 PM
    nd4spdbh
    SoCal
    @Torspd probably knows the answer to this.
    07 sport 4x4 likes this.
  19. Jun 28, 2017 at 12:22 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Yes I believe the pan assembly comes off and I feel like something about the heads coming off rings a bell as well.
  20. Jun 28, 2017 at 1:30 PM
    Muddinfun
    Muddinfun Well-Known Member
    If it were mine, I would go completely outside the box. If you hold the new part up there and there's room to slide it in without removing the timing cover, then all you need is clearance for the bolt. Clean and prep the area for surgery. Duct tape and plastic wrap the motor. Then use a die grinder to carve a half circle out of the cover to match one of these.
    http://www.streettunedmotorsports.com/parts/b/oem_dsm_half_moon_valve_gasket_md372348.jpg
    Lots of 4cyl front wheel drive cars have a half moon plug like this.
    Just a thought that seems like a ton less work than ripping the motor apart. Of coarse, this is assuming you know where the broken piece is. And, not, "oh, I know where it is. It's in the pan".
    I'm still curious how it broke.
