4.0 Idler Pulley Replacement OEM vs Gates Reference
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bruce988jl, Oct 23, 2017.
  1. Apr 21, 2020 at 5:56 AM
    #81
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    This might be a retarded question but ....
    the new Toyota pulleys do come with the bearings already pressed in, correct?
    #81
  2. Apr 22, 2020 at 9:17 PM
    #82
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Not 100% sure, but I have yet to see a new pulley sold without a bearing pressed in. Contact the vendor to be certain.
  3. Apr 23, 2020 at 3:02 AM
    #83
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    yes the bearing and pulley come as one unit ready to install
    Chris(NJ)[QUOTED] likes this.
  4. Apr 23, 2020 at 4:34 AM
    #84
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    The 3 idlers come with the bearings.
    The tensioner pulley OEM is only sold as an assembly with the pulley and tensioner and requires dismounting the alternator and AC compressor as its the base they bolt to/thru.
    SR-71A, EdgemanVA and Chris(NJ) like this.
  5. Apr 23, 2020 at 4:44 AM
    #85
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Thanks guys! Ordered the 3 idler pulleys and a couple other things from McGeorge Toyota. Just waiting on them to ship. Must exhibit patience when places have good prices I suppose. Hoping they can get everything to me before my work quarantine ends in a month.
  6. Apr 23, 2020 at 4:51 AM
    #86
    muddog321
    FL
    Chris(NJ) likes this.
  7. Apr 23, 2020 at 5:00 AM
    #87
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Will do! My plan was to check that for play once the others were being replaced. Sounds stupid, I know. But I didn't feel like buying the whole assembly from Toyota if I didn't have to. If the tensioner pulley is shot, I'll figure out a solution then.
  8. Apr 24, 2020 at 1:27 AM
    #88
    Chuy
    Lakeside, CA
    Silver Taco
    Accipiter13 and Chris(NJ) like this.
  9. Jun 15, 2020 at 7:59 PM
    #89
    cali_shark30
    cali_shark30 Member
    2015 Tacoma TRD Sport DCLB Pre-run
    In the original post there is a parts diagram (for Toyota OEM replacements) with the part numbers. It shows two washer looking things that go in front and behind idler pulley number 1 and 2 (all three pulleys) part number 16659AD010 for the front and part number 1664931020 for the back one. Do the original factory pulleys have these washers? Are these washers needed? The retail manager at my local Toyota dealer said, “the OEM replacement pulleys need these washers now because Toyota changed the manufacturer for the idler pulley”. Is there truth to this? Everything i’ve read about changing these pulleys they just mention the pulley itself and never these two washers.
    I want to stick with OEM and not buy the gates pulleys.
  10. Jun 15, 2020 at 8:53 PM
    #90
    Chuy
    Lakeside, CA
    Silver Taco
    The washers provide protection for the bearing. As spacers they may also prevent the bolt from bottoming out. Gates and other reputable manufacturers include a combination washer and center reducer for their bearings.
  11. Jun 16, 2020 at 2:17 AM
    #91
    muddog321
    FL
    To post 89 yes the OEM use those washers and I reused my old ones but they were rusty so had to sand the 2 front ones and paint but the rear ones were fairly clean.
    Just pay attention when you take the old ones off and see which went where. Or as dealer said buy the new ones and make the job easier and cleaner.
  12. Jun 16, 2020 at 8:49 AM
    #92
    cali_shark30
    cali_shark30 Member
    Did all three pulleys have the washers? Or just the two upper number 2 pulleys? Thanks for the info about your experience.
  13. Jul 30, 2020 at 2:09 PM
    #93
    F34Rnnr
    F34Rnnr Active Member
    Hey all, just FYI for those looking for OEM pulleys, I found what I believe to be OEM manufacturer under a different name.
    Koyo is a bearing manufacturer out of Japan that supplies many Japanese autos with OEM bearings. I ordered a full set of idlers matching the 4.0 from an eBay seller.
    These suckers look perfect and appear exactly as OEM. It would not surprise me at all if these were the OEM manufacturer, and the best part is, they were ~$20 per pulley with free shipping (compared to $50+ for oem and $35+ for Gates).
    #93
  14. Jul 31, 2020 at 9:45 AM
    #94
    TheDevilYouLove
    Marylandistan
    I’d be amazed if those aren’t Chinese fakes for that price.
    #94
    SR-71A likes this.
  15. Jul 31, 2020 at 9:59 AM
    #95
    F34Rnnr
    I don’t see why, OEM Idlers from Toyota dealers is ~$50-75, it’s not unusual for OEM manufacturers to have their branded parts considerably discounted from the Toyota-branded parts.
    Take, for example water pumps and radiators. Denso and Aisin make these for Toyota. If you buy the Toyota-branded part from a dealership (even the online discount dealers) you’re looking at $300+ each. RockAuto has the Denso and Aisin parts for $75-90.
    EdgemanVA and Sae68 like this.
  16. Jul 31, 2020 at 10:13 AM
    #96
    TheDevilYouLove
    Marylandistan
    OK then
  17. Jul 31, 2020 at 10:13 AM
    #97
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
    You got more info
    You got more info on that.
    #97
  18. Jul 31, 2020 at 11:08 AM
    #98
    F34Rnnr
    Seller is Asianauto on eBay. 99.6% seller rating and mostly deals in Japanese OEM auto parts. I think it’s legit. Here’s a link to the idlers. https://www.ebay.com/itm/323395249428
    #98
    grydsrt and Sae68[QUOTED] like this.
  19. Jul 31, 2020 at 1:29 PM
    #99
    wlayabq
    wlayabq Member
    2013 DCSB TRD
    can you team me more about the "jet engine" whine? I've been trying to diagnose a whine from my '13 4.0, that comes and goes between 1500and2k RPM's, belt is fairly new, replaced idler pulley #1, replaced the tensioner last weekend (that was a pain in the ass), and still haven't fixed the whine..... I haven't had any problems with the other accessories, AC works fine, no whine when turning from the PS pump, no power problems from the alternator.... wondering if its related to one of those or maybe the water pump? any insight would be really appreciated
  20. Sep 15, 2021 at 12:10 PM
    #100
    Bareknuckles
    Bareknuckles Member
    Marc
    '07 Prerunner Double Cab 2wd
    I have 356k on my 07 Taco... original pulleys! Getting ready to do a timing cover reseal so I'm going to swap out for new pulleys among some other parts while I'm in there. But... just wanted to shout out my solid OEM parts on this old lady with a lot of miles.
