3rzfe clutch torque specifications?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tdog2.7L, Jun 25, 2021.
  1. Jun 25, 2021 at 8:24 PM
    Tdog2.7L
    Tdog2.7L [OP] Well-Known Member
    2004 Tacoma 2.7l 4x4 & 2018 TRD Sport M/T
    Happy Friday everyone! I’m in the middle of a clutch job and wanted to double check torque specs before zipping everything back up. My truck is a 2004 2.7l.
    Fly wheel: 19ft lbs + 90*
    Pressure plate: 14ft lbs
    Trans to engine bolts: 53ft lbs
    Access cover bolts: 27ft lbs
    Front and rear drive shaft bolts: 65ft lbs
    Carrier bearing bolts: 27ft lbs
    Trans crossmember to frame bolts: 30ft lbs
    Trans crossmember to trans mount bolts: 14ft lbs
    Starter bolts: 29ft lbs
    Also reminder to check your shifter bushing seats, mine were completely gone in both the trans an tcase :burnrubber: Shift fork was toast too
    JudoJohn likes this.
  2. Jun 26, 2021 at 9:38 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Some of those values looked low (ex: Trans crossmember to trans mount bolts: 14ft lbs), so I opened a 2003 FSM I have.
    Here is the diagram and the Ft/Lbs is the last number in each text box:
    Tdog2.7L[OP] likes this.
  3. Jun 26, 2021 at 9:43 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    :ohsnap:
  4. Jun 26, 2021 at 9:46 AM
    Key-Rei
    Key
    Florida
    Cant believe that fork is still functional like that. Damn.
    As for the torque specs be aware there are some known misprints in the fsms, sometimes it's best to take the Newton meter value and convert it to verify the foot pound value is the same.
    One notable example is on the second gen tacomas the FSM says to torque the rear leaf spring u-bolt nuts to 37 foot pounds, but if you actually convert the Newton meters into foot pounds it gives you a torque value of 73ft-lbs which is much more appropriate for an M14 fine thread nut.
    Tdog2.7L[OP] and JudoJohn like this.
