3rz vs 22re
Discussion in 'General Tacoma Talk' started by Tacomaguy12345, May 15, 2024.
  1. May 15, 2024 at 11:20 PM
    Tacomaguy12345
    Tacomaguy12345 [OP] New Member
    Im looking to buy my first Toyota pickup and struggling to decide whether I should look for the 3rz or settle with the 22re. I’ve don’t quite a bit of research and from what I read both are good but 3rz has better power and about same mpg. Mpg is a big factor for me because it would be a daily and where I live everything is far away. Also read that the 3rz is easier to work on. I’m 17 y/o and need something good on gas reliable and easy to work on. Thanks for any feedback!
  2. May 16, 2024 at 5:28 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    The 22RE is old tech. It hasn't been made for about 30 years. Your choice.
  3. May 16, 2024 at 5:32 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    3RZ all day long. Just make sure the valve clearances have been checked regularly and there isn’t much else to go wrong.
  4. May 22, 2024 at 2:31 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I had a single cab 22re 5 speed while it truly is bulletproof it’s slower than molasses I also I had the 3rz single cab 5 speed that was a little better I currently have the 2trfe single cab 5 speed and this one is the fastest out of all of them
    keep in mind almost no mechanic will want to touch the 22re if you ever need one. I live in SoCal so plenty of Toyotas here but when I called for a mechanic no one wanted to touch it since it was pre obd2
  5. May 22, 2024 at 2:35 PM
    Clearwater Bill
    Billy
    Largo Florida
    Then buying a truck will never be optimum.
    There are lots of reliable choices out there with significantly better MPG
  6. Jun 19, 2024 at 9:43 PM
    CVCV
    CVCV 3rd Toyota Truck
    Tacoma 2022 3.5L DCSB TRD OR 4x4
    Sounds like you should look for a 3RZ, but don’t pass up a great deal on a solid 22RE.
    Your best deal is a solid truck, not just a solid engine.
