3RZ-FE Fuel Injector Spray Pattern - 23250-75050
Discussion in '1st Gen. Tacomas (1995-2004)' started by JoeBro, Feb 15, 2025.
  1. Feb 15, 2025 at 1:00 PM
    JoeBro
    JoeBro [OP] Member
    Joe
    1992 Toyota 2wd
    Wheels
    Does this look normal? There are 4 holes, but I only see fuel coming out of the holes on the outside. I'm spraying cleaner thru them and pulsing the injector continuously to see the pattern. I can't get the truck to run is the reason I'm doing this. All four injectors act the same way.
  2. Feb 15, 2025 at 3:52 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    I can’t say 100% correct (nice test set up btw)
    man, as injectors out and for piece of mind
    Would send to Motorwest
    $100 (if 2rz/3rz)
    4-5 day turnaround
    Well Recommend Vendor
  3. Feb 15, 2025 at 4:07 PM
    JoeBro
    JoeBro [OP] Member
    Joe
    1992 Toyota 2wd
    Wheels
    Thanks ControlCar, I found this setup on you tube from the "Rachets and Wrenches" dude. It wasn't my idea. The fuel injector is "continuously pulsed" from a tool I purchased on Amazon for $30 as I spray carb cleaner throught it. I'm just curious why nothing is coming through the center holes on the injector.
    Also, ohming them out, I'm getting 12.8, 12.8, 12,8 and 13.0. I think the FSM says 13.4 ohm - 14.2 ohms. I'm beginning to wonder if these injectors are the culprit of the truck not running.
  4. Feb 15, 2025 at 4:13 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Yeah that's normal for the early injectors. They just spray down the two intake runners on the 8-port intake
    TnShooter likes this.
  5. Feb 15, 2025 at 5:43 PM
    JoeBro
    JoeBro [OP] Member
    Joe
    1992 Toyota 2wd
    Wheels
    I noticed in the factory service manual that it specifies two ohm ranges? By one of the specs (12-16), these injectors are ok, but not according to the other (13.4-14.2). I know I probably should send them off, just trying to save money if they are ok.
  6. Feb 15, 2025 at 6:11 PM
    Speedytech7
    How great is resistance difference between them
  7. Feb 15, 2025 at 7:08 PM
    JoeBro
    JoeBro [OP] Member
    Joe
    1992 Toyota 2wd
    Wheels
    Injector - 1 = 12.6 ohms
    Injector - 2 = 12.8 ohms
    Injector - 3 = 12.7 ohms
    Injector - 4 = 13.0 ohms
  8. Feb 15, 2025 at 7:18 PM
    Speedytech7
    That's fine, when they fail they go high resistance or open. That's about perfect. Common "high impedance" injectors are in the 12-14 range and those are and amtheyre all very close to each other
    ControlCar likes this.
  9. Feb 15, 2025 at 7:38 PM
    JoeBro
    JoeBro [OP] Member
    Joe
    1992 Toyota 2wd
    Wheels
    Thanks Speedy,..before I installed them back into the head, I wanted to have some assurance they were ok. This completes my fuel system diagnosis. Seems everything is ok on fuel side now.
    Just dying to find out why this truck won’t start. Guess I’ll try to replace the coil & igniter for a hotter spark.
  10. Feb 17, 2025 at 5:12 PM
    ControlCar
    Steven
    Sugar Land TX
    Joe
    Unsure on 92 4cyl but just in case….
    Make sure to inspect the black injector cups
    that injectors seat into
    If brittle and cracked, could let in un-monitored air and cause issues
    mine were marble hard…didn’t see any obvious cracks……but seasoned members convinced me to RR I cups while I was in there
  11. Feb 17, 2025 at 5:44 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    The coil is only part of the story.....
    as the injector ages....it can start to leak
    and a fuel leak is much more corrosive to the top of a hot piston than water
    with the twin holes they are way less likely to clog like the later denso ones 2000 and later
    but internals wears the same
    earlier oem twin hole ones were made by Matsushita Electric
    Later taco's with the 'pinkys' should run injector cleaner regularly
