3rz 2.7l oil sending unit location.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sleep, Jan 9, 2023.
  1. Jan 9, 2023 at 11:27 AM
    Sleep
    Sleep [OP] Member
    1996 Tacoma
    2.5" lift front and rear Pacesetter Shorty headers and low restriction muffler
    Hello. Can someone please provide detailed photos of the location of the oil pressure sending unit on the 2.7l 3rz.
    Ive got a 1996 Tacoma and I can't figure out where the oil pressure sending unit plug, and accompanying wire go. (see photo)
    I know its on the right side of the block somewhere but I can't seem to find it.
    Thanks.
  2. Jan 9, 2023 at 11:31 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Pass side of the block, toward the front, under the exhaust manifold.
    Not to be confused with the coolant drain, which is also nearby.
  3. Jan 9, 2023 at 12:26 PM
    Sleep
    Sleep [OP] Member
    1996 Tacoma
    Thanks. Really hoping to get some photos here. I have a feeling a previous owner might have threaded a normal bolt into the oil sending unit location.
    I want some photos to be sure of that.
  4. Jan 9, 2023 at 12:27 PM
    0xDEADBEEF
    Ah ok. I can probably get that after work
  5. Jan 9, 2023 at 5:50 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    I'll be working on mine tomorrow and just bought a new oil sensor as well. I'll snap a picture its hard to miss. Is your oil light on? Its a simple switch that only feeds to the dash.
  6. Jan 9, 2023 at 5:55 PM
    0xDEADBEEF
    The one with wires coming out and a purple seal:
    Sleep[OP] likes this.
  7. Jan 9, 2023 at 8:28 PM
    Sleep
    Sleep [OP] Member
    1996 Tacoma
    Thanks a lot man. Going to go take another look and see what's there!
    Do you happen to have a photo of the termination of the other wire that comes out of the same loom in the top of your photo?
  8. Jan 14, 2023 at 1:47 PM
    Sleep
    Sleep [OP] Member
    1996 Tacoma
    Thanks for the help.
    I was able to find the plug and the wire had been ripped out of it. Reattached the wire and it's working fine again.
    In the first photo I posted the yellow and green wire on the left is actually for the oil pressure sending unit. Not sure what the plug on the right is yet. [​IMG]
  9. Jan 14, 2023 at 5:54 PM
    0xDEADBEEF
    That goes to the ac compressor clutch
