3rd gen v6 cylinder numbering
Discussion in '3rd Gen. Tacomas (2016-2023)' started by UH60 Mech, Mar 14, 2019.
  1. Mar 14, 2019 at 5:13 PM
    UH60 Mech
    UH60 Mech [OP] Active Member
    2016 4x4 TRD
    Anybody know the cylinder numbers. I need to replace my no. 3 coil pack
  2. Mar 14, 2019 at 5:17 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    I believe it is 123456. Not 100% sure.
    fatfurious2 likes this.
  3. Mar 14, 2019 at 5:18 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    #3 is Passenger side middle.
    5 —|— 6
    3 —|— 4
    1 —|— 2
    (Front of vehicle)
    Firing order is 123456 as said above.
  4. Mar 14, 2019 at 5:22 PM
    UH60 Mech
    2016 4x4 TRD
    Thanks a million.. that's what I thought but wanted a second opinion.. hard to find online specifically
    shakerhood likes this.
  5. Mar 18, 2025 at 4:28 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    Thread resurrection - unrelated to original post but still relevant
    so if I've got a P-0430 check engine code, referring to bank 2, and I believe the likely culprit is a damaged O² sensor, I need the drivers side replacement?
  6. Mar 18, 2025 at 4:38 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Don’t start throwing money at it pm @Vlady
  7. Mar 18, 2025 at 5:04 PM
    TurboGT
    Gabe
    Portland
    I'm pretty confident its the O² sensor... it started acting up after my cats got stolen, and they cut damn near on the O² nut
    That said if @Vlady knows better...
    t0p_d0g likes this.
