3rd Gen TPMS Disable
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maine 110, Aug 10, 2017.
  1. Aug 10, 2017 at 2:59 PM
    Maine 110
    Maine 110 [OP] Member
    Jesse
    under a rock
    2022- 4cyl auto base
    under construction
    Has anyone figured out how to disable TPMS on the 3rd gens? I followed the thread in the 2nd gen and sucessfully disabled my 14, which I traded on my 16. Any input would be appreciated. And yes I did some searching first and have not found anything, if there is a post I missed please forgive me.
  2. Aug 10, 2017 at 3:01 PM
    GotToyota
    GotToyota Well-Known Member
    Portland, OR
    You cannot disable it, it is a safety feature. Of course, you can remove the TPMS sensors and deal with the light if you want... but it cannot be turned off. Some people have made a pressurized air tube with the sensors in there so that the light will stay off.
    Anton338 and CusterFan like this.
  3. Aug 10, 2017 at 3:16 PM
    rob&donnaTOY
    rob&donnaTOY Member
    Rob & Donna
    Allentown, PA
    2017 Toyota Tacoma TRD off road DCLB
    bed step, more to come ...
    ALL 2008 and newer passenger vehicles and light trucks sold are now required to have a system to alert the driver when the tire pressure drops below 10% of the recommended tire pressure.
    The only way to disable would be to completely remove the TPMS sensors from the tires (NOT RECOMMENDED, and your TPMS dash light will be on all the time) or search youtube for recommended pressure canisters you can place the TPMS sensors in.
    as @GotToyota stated, TPMS IS a safety feature ...
    GotToyota likes this.
  4. Aug 10, 2017 at 5:48 PM
    GotToyota
    Portland, OR
    @c4lvinnn - it cannot be disabled with TechStream
  5. Aug 10, 2017 at 5:50 PM
    Maine 110
    Jesse
    under a rock
    under construction
    Thanks for the info that TPMS is a safety feature. I don't want the safety feature on my truck, nor do I want the brittle aluminum valve stems that will break off when off road with no easy trail fix. There is an entire thread on the 2nd gen forum about how to bypass the light. https://www.tacomaworld.com/threads/complete-tpms-disable-guide.161292/ I am looking for how to disable this "safety feature"
  6. Aug 10, 2017 at 5:53 PM
    GotToyota
    Portland, OR
    That guide should be compatible or pretty similar for the 3rd gens.
  7. Aug 10, 2017 at 5:53 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Why not just buy a set of offroad wheels and tires then?
  8. Aug 10, 2017 at 5:55 PM
    Maine 110
    Jesse
    under a rock
    under construction
    I have off road tires and rims without sensors, I want to disable the light on the dash.
    over60 likes this.
  9. Aug 10, 2017 at 5:56 PM
    Lt. Dangle
    Ohio
    I vote go old school...
  10. Aug 10, 2017 at 5:57 PM
    Maine 110
    Jesse
    under a rock
    under construction
    thanks, I may venture in and try it. It was pretty easy on my 14, it took longer to take the dash apart than to do the mod.
  11. Aug 10, 2017 at 6:02 PM
    Maine 110
    Jesse
    under a rock
    under construction
    Ha, if all else fails I'll go that route...
    Reerun865 and CusterFan like this.
  12. Aug 10, 2017 at 6:54 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I did this on my 2006 and this 2016.... It's easy, cheap and reversible in 3 seconds.... I change to snow tires every fall...!!
    By far the best way..! 3/4" round piece of black tape placed "strategically" will solve yer problem..! Don't block the other Idiot lites.
    SandyTaco4x4 likes this.
  13. Aug 10, 2017 at 8:31 PM
    Gerrrr
    Gerrrr Well-Known Member
    Jeremy
    Ottawa, Canada
    2017 Blazing Blue Metallic (Limited 2013 Silver Streak DC Auto - Retired)
    Starting over.......
    I have used the "Pipe Bomb" for 4 years, no issues.
    Pull the sensors out of the tires and seal them up in an 8" long tube of ABS pipe. Drill hole in end cap and seat a valve stem. Inflate to 32psi, toss behind back seat and forget. Have added air once In2Gro years.
  14. Aug 10, 2017 at 8:34 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Some safety features are for sissies
    Just saying
  15. Sep 8, 2020 at 9:43 AM
    treyfive
    treyfive Well-Known Member
    Brandon
    New York
    2017 PEARL BLUE TACOMA TRD OFF ROAD
    What did you ever do about this? I find myself in the same situation right now...
  16. Sep 8, 2020 at 4:50 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Leave the sensors in there for the next guy and a little dull black paint behind the tpm indicator. Paint the bulb or simply remove the bulb or cover the bulb. It's just a light.
    CusterFan likes this.
  17. Sep 8, 2020 at 5:06 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Buy a monkey face sticker and put over the warning light. lol
    https://www.youtube.com/watch?v=gcA4l72-7X8
    Tullie D likes this.
  18. Sep 8, 2020 at 5:14 PM
    CusterFan
