3rd gen tonneau covers fit 2nd gen bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HGPineapple, Feb 9, 2024.
  1. Feb 9, 2024 at 2:42 PM
    HGPineapple
    HGPineapple [OP] Active Member
    Hawaii
    2013 Superwhite RC
  2. Feb 9, 2024 at 2:54 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    I believe the height of the rails are different among the two but I could be wrong.
  3. Feb 9, 2024 at 6:42 PM
    545 Well-Known Member
    2015 Access Cab
    Front of the bed is different, different height for front rail. Would have to get a seal if you cared
    Tailgate is substantially different
    HGPineapple[OP] likes this.
  4. Feb 9, 2024 at 7:09 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I'll bet you're closer to making a Gen 3 tonneau fit on a Gen 2 than you realize, @HGPineapple. They're not going to be a direct fit. But with some clever mods and a bit of fabricating it can probably be done.
    I did it, in fact. Sort of. I mounted the Mountain Top tonneau from my Gen 1 truck on my Gen 2. It took a bit of work, but the results are surprisingly good. Those aluminum checkperlate tonneaux from Denmark's Mountain Top Industries are kind of rare and I'm very happy to have it in use (as the Gen 1 truck is running an ARE canopy now).
    Key to my project -- critical, in fact -- were the aluminum bed rails from KB Voodoo. Replacing the silly OEM plastic bed rails that make the Gen 2 beds different heights on the sides compared to the front and back with the thinner KB Voodoo rails made everything "flat" within a couple of millimeters and let the tonneau's rubber perimeter seal fit tight.
    The Gen 2 and Gen 3 SMC (sheet molding compound) composite inner beds are exactly the same, as are the C-channel sections (as far as I can tell). The front rails should be completely compatible. The key thing is leveling the sides.
    A few pix:
    Tonneau test-fitted onto OEM bedside rails. Note the significant gap across the tailgate. The same gap was across the front (although the details of the Mountain Top mounting system make it less of a problem there.)
    KB Voodoo bed rail in place.
    Tonneau installed. It's been this way for three years or so now and I love it.
    I just got back from a 6000 mile winter camping trip with my RTT mounted on the tonneau. Worked perfectly.
  5. Feb 12, 2024 at 11:23 AM
    HGPineapple
    Hawaii
    2013 Superwhite RC
    Thanks for that info @4xdog. Ill look into it.
