3rd gen tailgate slow drop assist mechanism
Discussion in '3rd Gen. Tacomas (2016-2023)' started by adambs928, Mar 6, 2020.
  1. Mar 6, 2020 at 7:16 AM
    adambs928
    adambs928 [OP] New Member
    Adam
    2016 Red Tacoma TRD Off-Road
    Does anybody know the mechanism/part that allows your tailgate to drop slowly on the 3rd Gen Tacomas? Is it something which I am able to easily replace myself?
    The tailgate on my 2016 seems to be going bad, in the sense that the tailgate now drops with force instead of being let down gently. I want to fix it with OEM parts, as opposed to installing an aftermarket strut.
    shotgunbilly420 likes this.
  2. Mar 6, 2020 at 7:22 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    That would be the damper. You need to remove the bumper to get access to the nut that holds it in place on the bed cross sill.
    El Chivo Norteño likes this.
  3. Mar 6, 2020 at 7:30 AM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    Actually, I may have mispoke above. You may be able to access the damper by removing the passenger side tail light cluster. If so, it would be a pretty easy job.
  4. Mar 6, 2020 at 7:35 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Read this. Toyota changed the damper design. You have the 2016. https://www.tacomaworld.com/threads/broken-tailgate-damper-rubber-grommet.467984/
    Unlawful_moose and eurowner like this.
  5. Mar 6, 2020 at 8:02 AM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
  6. Jan 22, 2022 at 7:24 AM
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    Did we ever find a non dealer fix or a part number?
  7. Jan 22, 2022 at 8:49 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
  8. Feb 16, 2022 at 8:20 AM
    sychan29
    sychan29 Member
    Has anyone changed the actual damper mechanism? My bushing seems ok. 2017 Sport
  9. Jan 16, 2023 at 9:12 AM
    Pavao
    Pavao Well-Known Member
    2017 Tacoma SR
    Sorry, old post, but has anyone changed the dumper?
    The plastic bushing on mine seems to be ok, but more importantly, there’s some oil/residue leaking from the mechanism, I think that helps it narrow it down the problem pretty good in my case.
    So has anyone changed it, remove tail light or bumper? And what/where to get the part
    TIA
  10. Jan 16, 2023 at 9:20 AM
    eurowner
    eurowner Duke Sky
    Scoty
  11. Jan 16, 2023 at 9:37 AM
    3rdGenJen
    3rdGenJen Well-Known Member
    2021 Cement Gray TRD OffRoad Access cab
    Snugtop Rebel, Rek Gen mudflaps, FM transmitter for Sony CD player
    Haven't changed the damper, but here's a dumper for you :thumbsup:Unknown.jpg
    Pavao[QUOTED] likes this.
  12. Jan 16, 2023 at 12:01 PM
    Pavao
    2017 Tacoma SR
    Lmao
  13. Jan 16, 2023 at 12:04 PM
    Pavao
    2017 Tacoma SR
  14. Jan 16, 2023 at 12:24 PM
    eurowner
    eurowner Duke Sky
    Scoty
    :thumbsup: I couldn't tell what chassis you have. Looks like you are calling the parts department of the dealer of your choice to verify if it fits the 6' bed.
