3rd Gen Tacoma Transmission Plugs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacocart762, Oct 1, 2020.
  1. Oct 1, 2020 at 7:26 AM
    tacocart762
    tacocart762 [OP] Well-Known Member
    desert55gr
    Santa Clarita Valley
    2017 Tacoma TRD Offroad Dbl Cab Long Box
    1.5in Bilstein 6112 Front,1in Alcan Leaf Rear with Bill 5100's. Battle Armor side step,bull bar, and rear step.
    As many others have done on this forum I too drain and refill my transmission fluid. I started making a habit of this and doing the swap every 10k-15k miles. I never take the whole thing apart and drain every little drop. Instead I drain the pan and refill the pan per Toyotas instructions. A Scan Gauge II lets me know what temp my trans fluid is at so I am sure not to over/under fill it. My thinking is that at this rate about every three drain/fill cycles I will have new fluid in the transmission. I know it is not perfect but it is better then never touching the trans fluid.
    When I first started to research what all was needed to drain and fill the Tacoma transmission I had a hard time finding what part number was associated with the fill plug and gasket. Arguably this really doesn't need to be changed however when I first tried to pop off the fill plug it was stuck. So many heat/cool cycles had glued that thing to the trans and I rounded the bolt head trying over and over to get it off. I ended up getting a Irwin Bolt Extractor in conjunction with a breaker bar and the plug came right out. This situation called for a new fill plug and gasket. Below are the Toyota part numbers for the 3rd Gen Transmission fill plug. The drain plug can easily be found with a Google search.
    Fill Plug= 90341-18059
    Fill Plug Gasket= 90301-15004
  2. Oct 1, 2020 at 7:31 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Curious why you do this so often? I know in the beginning of the 3rd Gen release there was a lot of talk about low transmission fluid, is this still an issue?
    tacocart762[OP] likes this.
  3. Oct 1, 2020 at 7:37 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  4. Oct 1, 2020 at 7:37 AM
    tacocart762
    desert55gr
    I am not sure if it is still an issue. I know my truck was about 2qt low when I checked it last after I bought it. Truth be told I do not really need to drain and fill it that often. However since when I do actually drain and fill I am only getting about 1/3 of the total amount of fluid out of the transmission because the pan only holds about 4qt of the 11-12qt that's in the whole system. So I figure three changes should just about put 12 new quarts back into the trans.
    Then again
    Tacoma owners, like me, are obsessed with spending money that does not need to be spent. LoL
    SLeeper512 likes this.
  5. Oct 1, 2020 at 7:38 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Yep, those are them.The fill plug and o-ring are hard to find on the diagrams as they are on the extension housing.
  6. Oct 1, 2020 at 7:38 AM
    tacocart762
    desert55gr
    BillsSR5[QUOTED] likes this.
  7. Oct 1, 2020 at 7:39 AM
    tacocart762
    desert55gr
    yes they are. took me a while initially to locate them.
  8. Oct 1, 2020 at 7:42 AM
    BillsSR5
    bill
    2014 SR5
  9. Oct 1, 2020 at 7:42 AM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
  10. Oct 1, 2020 at 12:20 PM
    tacocart762
    desert55gr
    Great info! Thank you for that! I had no idea the manual even said anything about that. I bought my 17 used and it did not come with a manual sadly.
  11. Oct 1, 2020 at 12:27 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I’ve done two drain and fills so far and I’m at 53k miles. I’m glad I have. Last drain had gold glitter In the oil. I'll do it every so often, whenever I get bored or remember. I'm also gonna add lubeguard as recommended by @gearcruncher
    gearcruncher and Tacospike like this.
  12. Oct 1, 2020 at 3:17 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Nice, I plan on doing a 30k transmission oci myself to refresh the additive package and also do this on my other vehicles. If I were towing, it would be 15k. Assuming you guys are using WS fluid or flushing and going to Amsoil?
    Skydvrr likes this.
  13. Oct 1, 2020 at 3:20 PM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    i plan on using amsoil on my first drain/fill
  14. Oct 1, 2020 at 3:54 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I've been using just ws but I'm hoping the lubeguard will help. I'm not currently experiencing any trans issues but I can go through a transmission like nobodies business. 3 or 4 in my Silverado and 2 or 3 in my accord.
  15. Oct 9, 2021 at 8:01 PM
    Joe333x
    Joe333x Well-Known Member
    Im hoping this is exactly what I am looking for, I have a Tundra but this thread came up in my google search, is this a 24mm bolt? Commonly removed with a 15/16th? Mine came out super easy the first time but this time my 15/16 socket wouldn't cut it and started to round it off. I went out and bought a 24mm and got it off but I'd like to replace it and want to make sure I am ordering the correct part.
  16. Oct 19, 2021 at 1:01 PM
    tacocart762
    desert55gr
    Yes this will work on the Tundra. I did some searching too and this info is kinda hard to find. My transmission fill plug was stuck the first time and I had to buy a special 24mm socket to remove it. The edges were rounded and this tool helped remove it with a breaker bar https://www.penntoolco.com/HA53912/ . This is the new plug https://www.yotashop.com/toyota-198...ase-and-axle-oem-fill-drain-plug-90341-a0002/ . If you highlight those addresses and right click the mouse then select search on Google it will bring them up. Hope this helps!
    Skydvrr likes this.
