3rd gen sub/amp and LOC wiring diagram
Discussion in 'Audio & Video' started by Tbills87, Apr 6, 2019.
  1. Apr 6, 2019 at 7:15 PM
    Tbills87
    Tbills87 [OP] Member
    2021 trd o/r 4x
    In need a wiring diagram to install a line output converter that is NOT a plug and play. Please help
  2. Apr 6, 2019 at 8:22 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Do you have the JBL system or no?
  3. Apr 6, 2019 at 9:52 PM
    Fattypack
    Fattypack Well-Known Member
    Waipahu
    2018 Cement Grey TRDORDCLB 4x4
    What LOC system do you have?
    Edit: I am also planning on adding an amp and sub also.
  4. Apr 6, 2019 at 10:11 PM
    Tbills87
    2021 trd o/r 4x
    This is everything. The sub is a subwoofer and amp all in one as well
  5. Apr 6, 2019 at 10:12 PM
    Tbills87
    2021 trd o/r 4x
    I don’t think I have the jbl system in my Tacoma.... I’ll go check to make sure right now.
  6. Apr 6, 2019 at 10:17 PM
    Tbills87
    2021 trd o/r 4x
    I don’t think it’s the jbl
  7. Apr 7, 2019 at 4:42 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    For non-JBL, there are a few places you can go. Either directly behind the radio, or either of the front kick panels. Don’t tap into the rears because they are very limited from the stock radio.
    Easiest spot is the the grey+ and blue- wires in this connector in the passenger kick panel
    Eyez_on likes this.
  8. Apr 7, 2019 at 8:24 PM
    Tbills87
    2021 trd o/r 4x
    Your the man! Thanks! Much appreciated
  9. Apr 8, 2019 at 8:25 PM
    Tbills87
    2021 trd o/r 4x
    So what color wire are for what?
  10. Apr 8, 2019 at 8:26 PM
    Tbills87
    2021 trd o/r 4x
    There not labeled
  11. Apr 9, 2019 at 9:50 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Grey is +
    Blue is -
  12. Apr 9, 2019 at 10:57 PM
    Tbills87
    2021 trd o/r 4x
    And I just need to tap into one (left or right) speaker right?
  13. Apr 10, 2019 at 4:39 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yep
  14. Oct 12, 2020 at 8:04 AM
    TACOZAC
    TACOZAC Well-Known Member
    2018 OR 4x4
    this is the first time ive heard connecting the LOC to ONE front speaker, is this correct? Im doing the same LOC connecting
    Grey is +
    Blue is -
    on passenger side kick panel (2018 non JBL) .....ill still just plug in the TWO male input wires from the LOC into the AMP, correct?
    Remote power to the amp i can get from any 12v source or cigarette lighter? from the above photo, is the green or white wire a constant power source?
    thanks!!!
  15. Oct 12, 2020 at 8:53 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    You can pull audio from just one side with essentially no negatives. Most bass is mixed to come from both channels.
    As for tapping remote power, you can get it from any switched source like the cig lighter you mentioned. Unfortunately, none of the wires in the plug in that picture are switched power.
    TACOZAC[QUOTED] likes this.
  16. Oct 12, 2020 at 9:21 AM
    TACOZAC
    2018 OR 4x4
    Thanks for the quick reply.
  17. Oct 12, 2020 at 6:57 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Why are people using a LoC to install equipment that takes speaker level inputs?
    Just wondering.
    “We wanted to truly make installation a breeze so we designed this unit with the user in mind from start to finish. We added high level inputs so you don't need a remote wire from your receiver to trigger the unit on and off. The smart circuit will sense that an audio signal is present and turn on your radio and a signal is present. When you turn off your music signal the amplifier built into this subwoofer system will automatically turn itself off. Using the high level input is also the fastest and easiest way to install an aftermarket amp subwoofer combination since you do not have to remove the receiver. You simply use the high level input and wire it to one of your speakers. Another thing we did to make installation a breeze is we put all the inputs and outputs on one side. This makes wiring neater and easier. Our competitors models are more challenging to install.”
  18. Oct 13, 2020 at 8:08 AM
    TACOZAC
    2018 OR 4x4
    Where is that quote from? I have a Boss amp and seems like most are using the LOC to supply RCA cables and remote trigger. I don’t think I’m wrong on this just looking for guidance. I did order a fuse adapter to add the line for the remote trigger. Just need to figure out where to install the add a fuse vs finding kick panel source to trigger my amp on and off. Cheers
  19. Oct 13, 2020 at 12:45 PM
    dolbytone
    South Carolina
    09 TRD Off Road
  20. Oct 13, 2020 at 1:18 PM
    TACOZAC
    2018 OR 4x4
    Op has different setup than myself but I understand now what your are referring too. Thanks
