3rd Gen Style 7/4 Pin Trailer Plug DIY
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steveo27, Apr 24, 2023.
  1. Apr 24, 2023 at 9:34 PM
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    UPDATE - SEE POST #6 FOR MORE INFO/DIY.
    I’m in the process of fixing a buncha little random things on my truck….
    Like most Tacomas, my 7 pin plug is pretty beat up and damaged.
    Since I’m replacing it, I might as well upgrade it too.
    3rd gens come with a 7 pin / 4 pin combo (see below)
    Has anyone updated their 7 pin to this new style plug?
    I’d like to relocate it up to the bumper right next to the plate like I see people do with the 7 pins.
    I’m assuming the 2nd gen male plug isn’t the same as the 3rd gen plug just because.
    Id rather not have to cut/splice the OEM hardness, but I don’t mind having to depin/repin.
    Id love to get any input from anyone who’s done this/thought about doing this.
    Thanks.
  2. Apr 25, 2023 at 5:15 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    I’m sure it can be done. Seems pretty straight forward, just have to figure out where to mount it. Ask the 3rd gen forum for a pic of the harness.
  3. Apr 25, 2023 at 5:27 AM
    cfcarpenter
    cfcarpenter Well-Known Member
    Clint
    PNW
    2005 DCLB 4wd MT
    Would you need a converter box for the 4wire? The older trucks would always need a 5 to 4 wire converter for the tail/brake lights to work properly. Might be wiring in a separate harness to make that work.
  4. Apr 25, 2023 at 8:04 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I too went down this rabbit hole and ended up just bailing on the idea as it wasn't immediately important. Your best bet will be to use an aftermarket 4/7 pin combo connector rather than the OEM one. The G2 and G3 Tacoma wiring for the trailer wiring use completely different style connectors and different wires/pins as well so you can't just easily re-pin it. You'll want to get generic, aftermarket parts then cut/splice into your existing wiring.
    There may be something out there but after weeks of searching for a plug n play solution I gave up.
    Here are a bunch of threads that were helpful for me:
    https://www.tacomaworld.com/threads...e-snap-some-pics-for-me.787171/#post-28167297
    https://www.tacomaworld.com/threads/7-pin-trailer-harness-plug-replacement-tip.288024/
    https://www.tacomaworld.com/threads/trailer-plug-relocation.380406/
  5. Apr 25, 2023 at 8:36 AM
    steveo27
    Pittsburgh
  6. May 1, 2023 at 6:08 PM
    steveo27
    Pittsburgh
    Welp, here’s my solution.
    Purchased the Hopkins 41144.
    https://www.amazon.com/gp/aw/d/B00YJGC6C6?ref=ppx_pop_mob_b_asin_title
    It’s a 7/4 pin combo that looks similar to the 3rd gen unit.
    I started by taking notes.
    Then I dissected the factory harness/plug and depinned it.
    Then I took the Hopkins plug and depinned it as well.
    Then I removed the pins/seals from the Toyota harness.
    And stripped the ends.
    Then I stripped the pins/seals off the Hopkins harness.
    I opened the pins back up and crimped them onto the Toyota harness after adding the Hopkins seals to it.
    I added a bit of solder just to be sure.
    Then I matched the Toyota wiring up to the Hopkins plug and repinned it.
    Now the aftermarket 7/4 pin trailer plug will plug into the factory harness.
    I just need to mount somewhere now.
    Hopefully this helps.
  7. May 1, 2023 at 9:41 PM
    caribe makaira
    Caribbean, Puerto Rico
    Orange Nimbus and clenkeit like this.
  8. Jun 22, 2023 at 8:36 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
