3rd Gen - Rear Drum Brakes???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Beancooker, Jul 12, 2019.
  1. Jul 12, 2019 at 10:38 AM
    #101
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Have u pulled your ebrake at low speed? I'm guessing not
  2. Jul 12, 2019 at 10:40 AM
    #102
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    Ladies! ladies! You’re both pretty. Now break it up...
  3. Jul 12, 2019 at 10:41 AM
    #103
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    I REFUSE to look anything up. EVER.
  4. Jul 12, 2019 at 10:42 AM
    #104
    stun gun
    Aaronski
    Tacomas.
    God I miss these drum brake fights. I really do. It’s been over a year since the last legitimate one.
  5. Jul 12, 2019 at 10:43 AM
    #105
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Does anybody know what the best oil is for my Tacoma?
    PRE-K and Malvolio like this.
  6. Jul 12, 2019 at 10:44 AM
    #106
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    That's because you live in the southwest. Seized calipers are a lot more expensive than slave cylinders.
  7. Jul 12, 2019 at 10:44 AM
    #107
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    Take it from Darsheel folks:
  8. Jul 12, 2019 at 11:05 AM
    #108
    stun gun
    Aaronski
    Tacomas.
    He’s right you know.
    You changed your name AGAIN.
    Shocking. THIS fuckin guy.
  9. Jul 12, 2019 at 11:18 AM
    #109
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    Yeah, coconut oil. Look it up! LMAO:rofl:
  10. Jul 12, 2019 at 11:20 AM
    #110
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Can't possibly agree more on this. I would almost guarantee the people who complain this haven't expected true brake fade. I have with both disc and drum. I love to drive well call it spiritedly. Never had a problem with the 3 Tacoma's rear drum brakes I've had. I also pull often, no problem with the rear.
    Now those front rotors I have destroyed several times under repeated hard braking on 2 of my 3 Tacoma's. Was a great chance to upgrade these when I did. Never had a problem with drums stopping.
    Tullie D likes this.
  11. Jul 12, 2019 at 11:22 AM
    #111
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
  12. Jul 12, 2019 at 11:27 AM
    #112
    PRE-K
    PRE-K Active Member
    '19 DCSB OR
    I get that drums on the rear of an already light truck are plenty effective. Also, according to Toyota, towing is low priority for Tacoma owners, so again, discs aren't really "mandatory".
    My question/concern would be extended use of TRAC (4H on an icy road, for example), in which the brakes are frequently and automatically being applied. I'd presume a fair amount of heat could build up, at which point the traction control WILL shut down (according to Toyota). A disc setup dissipates heat far better, either making TRAC more effective, or just keeping TRAC operational.
    Thoughts???
  13. Jul 12, 2019 at 11:30 AM
    #113
    stun gun
    Aaronski
    Tacomas.
    Thoughts? Were gonna be fine.
  14. Jul 12, 2019 at 11:31 AM
    #114
    Skydvrr
    Nick
    YMH
    Black '17 OR
    TacomaSport86 likes this.
  15. Jul 12, 2019 at 11:32 AM
    #115
    TacomaSport86
    The rear brakes on a Tacoma don't do much compared to the front. Very little weight in the rear.
  16. Jul 12, 2019 at 11:34 AM
    #116
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Funny you mention the FMVSS; the first FMVSS issued required discs in the front. In 1968... along with seatbelts. Seems like they've know for a long time discs have better stopping power.
  17. Jul 12, 2019 at 11:43 AM
    #117
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Shouldn't be riding brakes on hills anyway, that's what the lower gears are for.
  18. Jul 12, 2019 at 11:47 AM
    #118
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    Jenn's got more junk in the trunk[​IMG]
    skiploder and Dryfly24[QUOTED] like this.
  19. Jul 12, 2019 at 11:48 AM
    #119
    CZ-Jack
    CZ-Jack Well-Known Member
    2019 DCSB OR Cement
    Maybe they kept the drum brakes because they have near-zero drag when compared to disc brakes? Which theoretically increases MPG. I doubt the increased drag reduces fuel efficiency by any measurable degree, but I'd be interesting to know.
    r1200gs4ok likes this.
  20. Jul 12, 2019 at 11:50 AM
    #120
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    They don't. Drums actually apply a greater amount of torque given a particular diameter and can stop better than discs in many applications.
    Where discs excel is in dissipating heat better and in a scenario where the brakes are generating a great amount of heat, they are less prone to fade. Rear brakes rarely have this issue as they don't have enough of a load on them. If rear drums are causing you issues, you're well beyond the point in which your front discs are fading as well. This is 100% why front discs are mandated - not because they "stop better"
    TD90S and stun gun like this.
