3rd Gen Oil Filter Removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jlaurence32, Oct 8, 2018.
  1. Oct 8, 2018 at 7:43 PM
    jlaurence32
    jlaurence32 [OP] Well-Known Member
    Colorado
    2016 MGM TRD Sport 4x4 DCSB
    I just watched about six oil change videos on You Tube. On removing the new cannister oil filter on the 3rd gen, there is a metal clip on the side of it. Some guys say you need to remove this clip and other guys just wrench the cannister off without touching it. Is it necessary to remove this clip?
    JJ Diablo likes this.
  2. Oct 8, 2018 at 7:44 PM
    Shellshock
    Iowa
    I’ve never touched the clip. Just turn it off.
  3. Oct 8, 2018 at 7:45 PM
    11Bravo4x4
    11Bravo4x4 Well-Known Member
    Mitchell
    2018 Tacoma off road 4x4 quicksand
    What he said ^^ I’ve been able to remove the canister without removing the clip and I’ve changed my oil 3 times. It is not necessary to remove the clip
  4. Oct 9, 2018 at 6:56 PM
    jlaurence32
    Colorado
    What's the clip for?
  5. Oct 9, 2018 at 7:04 PM
    Shellshock
    Iowa
    Decoration?
  6. Oct 22, 2018 at 2:26 PM
    jlaurence32
    Colorado
    The clip keeps the filter from spinning off if it becomes loose. There's a tab on the cannister that will stop it from spinning. I removed the clip before removing the filter, then reinstalled it after I was done.
    Lt. Dangle and tonered like this.
  7. Oct 22, 2018 at 3:08 PM
    petr321
    petr321 Well-Known Member
    Petr
    San Diego
    2018 DCSB OR
    When u use the tool to pull the canister off, it pushes the clip back so it’s not in ur way.
    Rob Daman and tonered like this.
  8. Oct 22, 2018 at 3:24 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    if the canister somehow got loose it acts as a 'keeper' to keep it from turning and falling off.
  9. Oct 22, 2018 at 4:05 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    Still getting my free oil changes so haven't had to deal with it yet. Does the clip just pull straight down for removal? Can't tell from the photo.
  10. Oct 22, 2018 at 4:18 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    No it is made from something like spring steel and has a slight amount of pressure on, it's no big deal when you are removing the canister.
    kahanabob and tonered like this.
  11. Oct 22, 2018 at 6:31 PM
    jlaurence32
    Colorado
    It does... Maybe it's weak enough to just pry sideways when removing the housing and spring back when done. But it needs to be strong enough to keep the housing from spinning of if it becomes loose.
    kahanabob and DTaco18[QUOTED] like this.
  12. Oct 22, 2018 at 7:18 PM
    DSIM
    DSIM Well-Known Member
    Daniel
    Raleigh, NC
    2017 MGM Tacoma TRD Off-Road
    No need to worry bout the clip. But i tell you what mine took some damn elbow grease and a large cheater bar to break loose.
    kahanabob likes this.
  13. Oct 22, 2018 at 7:26 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
  14. Oct 23, 2018 at 8:41 AM
    jlaurence32
    Colorado
    Ahh, thanks for the illustration. It must flex back to spin the housing off then return to where it was when done..
  15. Oct 23, 2018 at 8:46 AM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    IIRC the clip looked like it would get in the way, so I just pulled it off with a pair of pliers and reinserted it when I was finished. No problem, but next time I’ll try (gently) to turn past it. I have an aftermarket aluminum filter wrench ... maybe it’s bigger.
  16. Oct 23, 2018 at 9:04 AM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    How did you remove the clip? Soon will install a Baxter oil can adapter and need to remove that clip to install the adapter. Is it hard? special tools?, cut the engine in half?
  17. Oct 23, 2018 at 9:05 AM
    dman100
    2016 TRD OR DCSB
    I just pulled the clip straight down. It uses friction similar to an electrical spade connector.
  18. Oct 23, 2018 at 9:12 AM
    Dacon
    Danny
    Gilbert, Arizona.
    Get this wrench/tool to remove the filter canister. It has more engagements tabs and distributes the torque on more surfaces.
    GOOD
    BAD
    tonered likes this.
  19. Oct 23, 2018 at 9:27 AM
    gotblika
    Maui
    2015 DCLB Sport 4X4
    I don’t have a 3rd gen but by the picture it looks like it slides up and out the way and you slide back down when done. ‍:confused:
  20. Oct 23, 2018 at 9:51 AM
    gotblika
    Maui
    2015 DCLB Sport 4X4
    That illustration is from a 2016 tacoma FSM and looking at it again I noticed the bracket looks like its connected to the filter cap (this is how it was on my 13 4runner) so IDK if it applies to the bracket as pictured.
