3rd Gen Lower Ball Joint Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by weasel6, Aug 17, 2023.
  1. Aug 17, 2023 at 2:31 PM
    weasel6
    weasel6 [OP] New Member
    2016 Grey Tacoma TRD Off Road
    New member, first post so bear with me.
    So after 71XXX fairly easy miles, the stealership has informed me that my passenger side lower ball joint has play and needs replacement. I haven't noticed any noise or play in the front end while driving, so I assume it's just beginning to go bad. Unfortunately my state has an inspection law and this has given me a fat rejection sticker until it's fixed. Regardless, I was quoted at just under a grand for the job because for some unknown reason the Toyota mothership only replaces the entire LCA as a unit. Said to hell with that and decided to try to do the replacement myself with the stock LCA's and new ball joints.
    Now my question, after searching far and wide I can't seem to find a guide or video on the replacement. Does anyone here have one, or can give me some guidance before I embark on this process.
    Thanks
  2. Aug 17, 2023 at 2:47 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I would say buy a Moog lower control arm or replace both and call it a day. They are all put together and ready to go. Not worth the effort to get everything pressed out. But it can be done , it’s just a pain in the neck . I think the whole arm is about 120 bucks
    TRDSport10 likes this.
  3. Aug 17, 2023 at 2:48 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    High probability the alignment bolts are frozen. Get a carbide reciprocating saw blade. Cut them out.
  4. Aug 17, 2023 at 2:54 PM
    TruckGuy63
    Gilbert
    New York
    That’s the other thing . You see if the ball joint Is really bad, yourself or have someone at a front end shop that you know check it . That does seem to be a fairly low mileage to be bad . Unless your boot got torn .
  5. Aug 17, 2023 at 3:19 PM
    weasel6
    That's exactly my thought. Seems awfully premature. The boot appears to be intact fully, and still has grease in it.
  6. Aug 17, 2023 at 3:32 PM
    Bishop84
    Bishop84 Well-Known Member
    I've changed them leaked out and small play at around 80,000km (similar) on a SR 4 banger.
    It happens, not very often.
    I personally am not a huge fan of press in aftermarket ball joints. This leaves OEM arms or aftermarket arms.
    The Mevotech arms don't have a great reputation anymore. So I'd good Moog (sealed no grease fittings) or OEM.
  7. Aug 17, 2023 at 3:58 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I was called a month or so ago by a coworker. A buddy of his took his 2016 Tacoma with 124,000kms to the dealer to get serviced before a trip. When he was picking it up, the Service adviser asks him, "Do you want do the repairs now or schedule them in?"
    He is confused and inquires about what repairs she is referring to. She tells him there is a major leak at the head gasket and at the rack and pinion with a price tag of $10,000 to repair. Oh and they are urgent!
    He talks to my coworker who talks to me being I own a Tacoma. Just to get an idea of how common these type of issues are. He even throws a piece of cardboard under the truck over night without a drop of fluid left. Based on mine and my coworkers recommendation (both Commercial Transport Technicians) he take it to another shop. Nothing is found... no issues as described by the Service Technician.
    It would seem that this dealership likes to throw shit into the fan and see where it sticks... 1 big job is great for the bottom line... not so much for the customer though.
    With that said... a ball joint is a safety item. I have seen brand new joints fail with in weeks and others last the life of the vehicle. I would recommend a second opinion before having the repair done. A quality frame and alignment shop would be a good place to consider.
    weasel6[OP] likes this.
  8. Aug 17, 2023 at 4:15 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
  9. Aug 17, 2023 at 4:26 PM
    weasel6
  10. Aug 17, 2023 at 4:26 PM
    weasel6
    That’s good advise. It’s definitely going to get a second opinion before I start.
  11. Aug 17, 2023 at 4:30 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I've done 3rd gen lower ball joints several times. I'd definitely recommend replacing the entire arm if doing this in your driveway.
    I already had a good ball joint press kit. But It didn't have the correct cup/adapter to work with pressing out the 3rd gen tacoma ball joint. So I had to buy a master cup/adapter set, just to be able to complete this job on 3rd gen tacomas.
    You would spend more on tools to replace just the ball joint. Get a complete arm and make life easier.
