3rd gen Low beam positive wire
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JKS8o8, Jul 21, 2019.
  1. Jul 21, 2019 at 10:27 PM
    JKS8o8
    JKS8o8 [OP] Active Member
    Mililani, Hawaii
    2017 Tacoma TRD Sport
    Hello TW, I was wondering if anyone knows what color the positive wire for the low beams are?
    I recently bought VLED triton v6 switchbacks for my front turn signals and it requires me to tap into the low beam positive wire to dim. I searched many of the threads but couldn’t find anything. Any help would be appreciated!
  2. Jul 22, 2019 at 4:02 AM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
  3. Jul 22, 2019 at 4:49 AM
    Mountain2018
    Mountain2018 Well-Known Member
    Harpers Ferry/Leesburg VA
    2018 4x4 SB gray
    Too funny! I literally just went thru this same install and was looking for the info by searching on and off since the lights would not dim. My issue turned out to be a bad solder that looked fine.
    Of note, an older VLED switchback thread had someone installing these incorrectly state they only dim 10% with 90% brightness remaining when headlights are on. Actually its the exact opposite. They dim significantly and do not cause annoying glare at night.
    May do a product write up but a word to the wise. Avoid these homebrew LED switchback "kits" that lack any type of directions, full wiring kit and don't do returns, even on items/,kit unused.
    JKS8o8[OP] likes this.
  4. Jul 22, 2019 at 8:02 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    9C2C2557-97AC-4FAA-A530-BEEB58D08B4A.jpg 9A392D27-0765-4A34-9081-78FEAFA0C02D.jpg Red is positive on drivers side and blue is positive on passenger side....white with black stripe is always ground. They do dim at least 50% but when using the dim wire off the Vled v-6 triton bulb you will get hyper flashing of the turn signal but only when the headlights are on go figure. I got an email into VLeds to figure out how to correct this as the resistors they sell don’t correct this they actually just cancel out the turn flasher...it only flashes once wether the headlights are on or not with the resistor. So I just disconnected the dimmer wire and everything works as it should I just can’t dim the turn signal DRL...I’ll wait to see what they say.
  5. Jul 22, 2019 at 9:36 AM
    JKS8o8
    Mililani, Hawaii
    Right on, thanks man! Lmk what VLED says about the hyper flash with the headlights on. I think I might just run it with the hyper flash until they give an answer lol
  6. Jul 22, 2019 at 9:48 AM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    Will do...I’m running led headlights on the low beams so that may be part of the problem...Lmk if you have the same issue. Like I said turn signals and hazards work perfectly except when the headlights are on they hyperflash. Turn headlights off no issues...weird. If I disconnect the dimmer wire from the switch backs turn headlights on no issues.
  7. Jul 22, 2019 at 10:19 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Where are u guys installing these? In the Amber spot in the headlights?
  8. Jul 22, 2019 at 10:25 AM
    JKS8o8
    Mililani, Hawaii
    Yeah I’ll let you know if I run into the same problem. I’m running hids in my headlights so I’ll see if I have the same problem.
    It’s weird that it only has problems when the headlights are on and the dimmer wire is connected.
  9. Jul 22, 2019 at 10:25 AM
    JKS8o8
    Mililani, Hawaii
    Yes the front turn signals
  10. Jul 22, 2019 at 10:40 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    They're white then switch the Amber turn?
  11. Jul 22, 2019 at 10:41 AM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    Switchbacks dimmed with headlights on
    Switchbacks on with DRL no dim headlights off
    Switchbacks with left turn signal on
    JKS8o8[OP] and Skydvrr like this.
  12. Jul 22, 2019 at 3:18 PM
    JKS8o8
    Mililani, Hawaii
    Yup white DRL and amber turn signals/hazards
  13. Jul 22, 2019 at 3:20 PM
    JKS8o8
    Mililani, Hawaii
    Looks sick bro!! How does it look at night? Bright enough to run just fogs and DRL’s?
  14. Jul 22, 2019 at 3:28 PM
    Tacospike
    Two Trucks
    It’s like the stage 2 tails except for front DRL turn instead of a reverse turn
  15. Jul 22, 2019 at 3:33 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    That's what I figured.
  16. Jul 22, 2019 at 8:25 PM
    Mountain2018
    2018 4x4 SB gray
    Must be the addition of low beam LEDS causing the hyper flash issue. With headlights on have no hyperflash and they dim as designed.
  17. Jul 22, 2019 at 9:04 PM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    That’s what I thought...it being the low beam LEDs...I spoke with VLeds today and they said no the headlight leds shouldn’t affect it. Anyway their electrical engineer wants to know why so they gave me a few tests to do and I have to report back...I’m going to put the stock headlights bulbs back in and see if it’s good.
  18. Jul 22, 2019 at 9:10 PM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    They are bright but the light doesn’t project forward enough to use as headlights...for me it’s just accent lighting
  19. Jul 22, 2019 at 9:30 PM
    JKS8o8
    Mililani, Hawaii
    Let us know what happens when you put the stocks back in! I’m curious to see what will happen with mines. Got 55w hids In the low beams
  20. Jul 22, 2019 at 9:30 PM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    I have a question not sure it would really matter but...when you hooked up the dim wire(s) from the v-6 triton switchbacks did you connect both dim wires to one headlight or each dim wire to each headlight?
