3rd Gen Lifting Advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rustytaco71, Sep 13, 2017.
  1. Sep 13, 2017 at 1:35 PM
    Rustytaco71
    Rustytaco71 [OP] Well-Known Member
    2018 4Runner
    Howdy,
    Absolute noob to the truck world. Just picked up a 17' Double Cab TRD Sport and looking to lift it. Not trying to go too crazy, just something to give it a more beefy look. What's the most I can do without having too get too crazy with purchasing Upper Control Arms? I've been looking at the Toytec Boss lift. Any info would be greatly appreciated! Looking to run 275/70/17.
    Thanks!
  2. Sep 13, 2017 at 1:36 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
  3. Sep 13, 2017 at 1:38 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Welcome to TW, first thing to do is decide on a budget. To keep with stock UCAS try and stay under 2 inches of lift up front.
    ElBlancoTaco likes this.
  4. Sep 13, 2017 at 1:43 PM
    Rustytaco71
    2018 4Runner
    Thanks man!
    And yeah I'm definitely trying to ball on a budget here. Looking to keep my complete set up under 3k if possible. Want to get some nice wheels and tires and a nice noobie lift setup to get me going..for now:militarypress:
  5. Sep 13, 2017 at 1:46 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    tcjacado likes this.
  6. Sep 13, 2017 at 5:19 PM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    I love the Boss 2.0 and the ride is sweet. I have 265/70/17 KO2 and my son has the same with 275/70/17 KO2 with no issues so far. We did not need UCA's for that lift. Get a wheel with a -10 or -12mm offset and you will like the stance.$.02
  7. Sep 13, 2017 at 8:40 PM
    Fedup13
    Fedup13 Well-Known Member
    San Diego
    2021 OR DCSB 4x4
    Pics??
    AdventureKid likes this.
  8. Sep 13, 2017 at 8:44 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW!
  9. Sep 14, 2017 at 1:56 AM
    Rustytaco71
    2018 4Runner
    Thanks for all the info everyone and welcome! Much appreciated! In regards to the Bilsteins and OME springs, it almost seems a little more worthwhile to go with the BOSS kit since it is only a couple hundread of a difference. Being that the 3rd Gen's already essentially come with a "one inch" lift, would running the BOSS kit set at 1.25" up front and 2" in the back still keep me safe from requering UCA's?
  10. Sep 14, 2017 at 2:15 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Start reading.
    https://www.tacomaworld.com/threads/the-toytec-boss-lift-thread.424616/
    Personally not a fan of preloading the spring to achieve height like you do with adjustable coil overs but if that's the line you're looking to go, recommend also looking at the Bilstein 6112/5160 combo for a very good ride. No worries about thread maintenance as it's more of a set it and forget it kit.
    https://www.tacomaworld.com/threads/boss-2-0-or-bilstein-6112-5160-combo.402595/
    Ballinbosox likes this.
  11. Sep 14, 2017 at 6:51 PM
    Halena Molokai
    This is my son's, 275/70/17 KO2 SCS wheels 17x8.5 -10mm offset, Boss 2.0
  12. Sep 14, 2017 at 9:22 PM
    Fedup13
    San Diego
    2021 OR DCSB 4x4
    Nice, do you have pics of yours? I'm trying to decide between 265 70 17 and 275's
  13. Sep 14, 2017 at 9:56 PM
    AdventureKid
    AdventureKid Let's Go Places
    Jake
    Oceanside, CA
    17' DCSB TRD OR 4x4 6MT
    Camper Shell
    Exactly. In the same boat. Trying to see if 265/70/17 Look to dinky on a 1"-2" lift. Or if I should go with the 275/70/17. Just hate that E Load BFG Ko2.
    @jsinnard I hear preloading springs just makes the ride crap. What's the best method then for raising the suspension over 1" without preloading for maximum use from your suspension?
    Fedup13[QUOTED] likes this.
  14. Sep 14, 2017 at 10:07 PM
    Guapo Taco
    Guapo Taco Yut life!
    SoCal
    '17 Taco OR 4x4 Tortilla Tansand
    Also newb here. Can you explain what the alternative would be to adjustable coilovers? I see spacers and blocks are a big no no around here. I can understand why that option doesn't suit everybody. But if not spacers and not adjustable coilovers, what is the alternative?
  15. Sep 14, 2017 at 11:00 PM
    Halena Molokai
    I don't have any pics but if you want the bigger looking stance, go with the 275's they look good and the ride is still awesome with the Boss 2.0. Between my truck and my sons, the only difference in ride is the weight which is very minor. I think with the extra weight it gives it a nice ride on his with around 36PSI. With my 265's on C rated tires I run 32psi to get a good ride because at 36psi it was too bumpy for my taste IMO. You get that extra height with the 275's. Although the 265's still look good with a -12mm offset I feel it still ain't bad and I like it. $.02
    AdventureKid[QUOTED] likes this.
  16. Sep 15, 2017 at 2:30 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    To allow maximum travel of the shock use taller springs to do the lifting. The drawback is springs will settle over time so your ride height may decrease by up to 1/2 inch.
    Nothing wrong with coilovers if you want to lift 1-2 inches and you are able to dial in the exact height, just understand the higher you go, the more preload gets dialed in and you get a stiffer ride. To keep it adjustable, coilovers need periodic maintenance and possibly rebuilding every 30-40k miles. Some people don't mind that, it's just something I'd rather not have to do.
    If you're using aftermarket springs to do the lifting, you just use larger springs to go higher, just don't exceed the travel of the shock. Like I said, set it and forget it. That's why I recommended the OME kit paired with either Bilstein or the nitrocharger shocks for suspension newbies.
    The 6112/5160 does rely on preload but the shocks are so big they compensate for preload, it's also recommended not to go higher than 2 inches on them. They're very expensive but they definitely get the job done. The expense is why I didn't recommend them at first, they can be a bit more than a newbie might want to spend on his first lift for a 1-2 inch increase. There are other workable options like OME springs paired with 5100s or nitrochargers, especially on a daily driver that sees only a little offroad time.
    Since a 275 tire only comes in E load right now, it's pretty heavy and stiff compared to a C load, paired with a preloaded spring suspension and you're magnifying the stiffness.
    Ride is subjective though, what I like may not be what the next person likes.
    Best thing to do is call the people at Headstrong Offroad, let them know what your needs are, the frequency of offroad and they can help you decide on a suspension that will meet your needs and budget. They're very centered on happy customers instead of moving product.
    @HeadStrong Off-Road Marie please add more information for the folks and correct any misinformation I might have accidentally put out.
    ChaseHamilton likes this.
  17. Sep 17, 2017 at 7:46 AM
    Rustytaco71
    2018 4Runner
    Hey guys, thanks a lot for all the input!
    So I just paid for school and my budget will be a little tighter for now. If y'all could provide a quick .02$ on what I've come up with I'd really appreciate it!
    So the truck will be seeing little to no off roading for a while foremost. I have come to like how they look leveled up front with the 5100 set at .85". So I need the 888 coils with it? And I should be safe from buying UCA's correct?
    Now second topic.
    I have come across rough country lifts often, however I seems they rely on block lifts more than anything. They're fairly cheap however and I will be doing no serious off roading. What are your opinions on the 3-inch lift from RC? And does their "kit" have everything I need to maintain proper alignment or do I need to purchase UCA's? It's about $300-600 I believe for the kit which seems cheap if it would come with UCA.
    I apologize if some questions come off stupid, again I am a noob into the truck world.
    Thanks!
  18. Sep 17, 2017 at 11:51 AM
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
    If you get 5100s you can use your stock springs and set it at .85" to level out your truck.
    5100s set at .85" with 888 will lift your truck close to 4 inches. Most people usually using 887 or 888 springs leave the shock at the lowest setying and let the spring do the lifting.
    Rule of thumb is any lift under 2.5 inches does not require new uca. I lifted mine 2.5 and got new uca.
    Most here including me do not like rough country or pro comp lifts. Why spend over 30k on a truck and put a shitty lift on it, mind as well drive it stock
  19. Sep 17, 2017 at 12:00 PM
    Guapo Taco
    SoCal
    Does this rule of thumb for UCA apply regardless of gen 2 or gen 3? Or is this 2.5" PLUS 1" (3.5 total) for gen 3?
  20. Sep 17, 2017 at 3:00 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Most that lift over 2 inches in the 3rd gen are probably going to need aftermarket UCAs to get a decent alignment. Most under 2 inches of lift from stock height can get away with using the stock UCAs.
