3rd gen LCAs on 2nd gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by asterny, Dec 1, 2020.
  1. Dec 1, 2020 at 10:37 AM
    asterny
    asterny [OP] Member
    I've seen it posted that all of the suspension for 3rd gen is compatible with 2nd gen (in my case, 2008 TRD Sport) EXCEPT for the LCAs (lower control arms). Can somewhere direct me if this is actually the case? When I looked at some after-market LCAs, they say they fit Tacoma from 2005 - current (which seems to indicate compatibility for both 2nd and 3rd gen). Is there a moderately priced brand that someone can recommend? (Dealership is quoting $650/LCA).
    I have at least one loose bushing in driver's side LCA, and am debating how much I might want to replace other nearby components. I am considering replacing some parts with (https://honolulu.craigslist.org/big/pts/d/kailua-kona-3rd-gen-tacoma-parts/7234410895.html) and wondering if I'll get much in terms of performance and/or durability. My truck is at 112,000 but seems like the front suspension took a pounding from previous owner (recently replaced brake pads, wheel hubs/bearings, now LCAs...)
    Any advice is much appreciated.
  2. Dec 1, 2020 at 10:39 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The rearward bushing/bolt is a different diameter which is why they're not compatible. The rearward alignment tabs on the frame are different too which is why you can't just swap hardware and make it work.
    kylehorvath and Kolter45 like this.
  3. Dec 1, 2020 at 10:52 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Bolts of the stock LCA on the 3rd gen is a larger diameter (and bushing is bigger).
    It would make sense with the right spacers a 2nd gen LCA would fit in the bigger opening of the 3rd gen rear mount, but the other way around does not work.
    jtaco11, Kolter45 and asterny[OP] like this.
  4. Dec 1, 2020 at 11:13 AM
    asterny
    asterny [OP] Member
    Would it make sense to upgrade/replace other components, or just stick to LCA for now?
  5. Dec 1, 2020 at 3:12 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    For me and my situation (graphic details below, tl;dr my truck is old and tired and was gonna need the work soon anyway), I went ahead and bit the bullet. I have a driver side BJ that is toast, and after a LOT of hand-wringing and saving up, am about to replace UCA, LCA, all 4 struts, coils, sway bar drop links, and sway bar bushings all at once.
    For reference, I have an 09 AC TRD OR with 210k miles on the factory suspension, except for some cheap quick-struts in the front from when the driver side front factory shock shit its brains out over a speedbump at 185k miles. I live in the salt belt and now Vermont, and I decided to go with a full rebuild now rather than wait around for parts to fail one by one and have the labor time add up as I try to do everything onesies and twosies.
    I went with some very low mileage Gen 3 factory shocks and UCAs from a seller here on TW, and some used but recently rebuilt Dirt King LCAs. They are the older Uniball type and I will probably get pissed off at the Uniballs here in Vermont but I wanted to see and experience certain things for myself after reading about them for a long time. You could do what I was originally going to do and pick up factory LCAs for ~250 each shipped, or you could go with Beck Arnleys from Rock Auto which seem to be well regarded among non-Toyota LCAs and cost slightly less.
    clinteastside likes this.
  6. Jun 20, 2022 at 3:42 PM
    LP808
    LP808 Well-Known Member
    2016 Base SR5 Tacoma
    None
    Forgive me if anyone answered this, but what about LCA skids? Could a skid from a 2nd gen LCA fit on a 3rd?
  7. Apr 2, 2023 at 10:41 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    These are for the 3rd gens.
  8. Apr 2, 2023 at 12:25 PM
    Blain
    Blain I ain't got time to bleed
    Tx
    I bought brand new 2nd gen takeoff LCA and UCA's for ~$100 and swapped them out on my 2006 a couple of weekends ago. Easy peasy.
    TegoTaco likes this.
  9. Apr 2, 2023 at 4:08 PM
    TegoTaco
    Ontario, Canada
    “I ain’t got time to bleed!”
    :bowdown:
    Blain[QUOTED] likes this.
  10. Apr 2, 2023 at 7:44 PM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    2nd Gen rear bushing is the metric equivalent of 9/16” and 3rd Gen is 5/8”. The arms are identical in every way and the rear bushings can be swapped back and forth to go 2nd-3rd or 3rd-2nd
  11. Apr 3, 2023 at 2:55 PM
    TegoTaco
    Ontario, Canada
  12. Apr 3, 2023 at 2:59 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
