3rd gen jack points
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ob1-adobe, Jan 25, 2020.
  1. Jan 25, 2020 at 5:48 PM
    Ob1-adobe
    Ob1-adobe [OP] Well-Known Member
    2019 Tacoma TRD Off-Road DCSB Magnetic Gray
    I’m gonna lose my man card on this one, but oh well. It’s kind of important.
    I was reading my owners manual to see where the jack points are and the jack function and all that on my 19 taco Trd off road.
    kinda confused. The front jack points in the Manuel were a little vague and the rear I thought made sense except I watched this guy and he put them in a different spot
    https://m.youtube.com/watch?v=tPDFtunIxOU
  2. Jan 25, 2020 at 5:58 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    He clearly didn't read the manual, that spot will work too.
    For the rear, they are recommending just inside of the u bolt plate. But before the center pumpkin.
    For the front they are recommending on the side rail of the frame just ahead of the transmission cross member.
    There are other points but if you are not comfortable just use these points. Also choke a wheel front and back on the opposite side and jack it up on a level, firm surface.
  3. Jan 25, 2020 at 6:03 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Why did they blur out his mouth?
  4. Jan 25, 2020 at 6:04 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    I was wondering the same thing. It wasn't blurry at first then it was. I bet he smacking his lip jacking up the truck!
    Kolohe07 and BC Hunter like this.
  5. Jan 25, 2020 at 6:14 PM
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    I jack the rear up with a bottle jack on the ends of the u-bolts. Put it under the end of the control arm on the front. Always use jackstands.
    nat103 likes this.
  6. Jan 25, 2020 at 6:22 PM
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    Pretty much the frame, crossmember, rear axle and this spot in the picture are good points to lift your truck 20200125_182126.jpg
  7. Jan 25, 2020 at 6:26 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Since it’s related I’m going to small kind hijack
    I didn’t see anything in the manual regarding floor jacks locations for lifting either the front or rear completely. I found a 2nd gen Toyota pdf that says to use the bump out (does this have a name?) in the front center obviously for lifting the front end. And the differential for the rear. I did make sure my floor jack wasn’t resting on the little (drain? Extrusion off center on the bottom) and I put a folded microfiber on the floor jack cup because i don’t have one of those rubber covers. Also obviously use jack stands which I put at the jacking points mentioned already.
    my question, if you know, what’s the best/safest procedure to lift the whole truck completely with just 1 floor jack and 4 jack stands? I need to start rotating my own tires
    davidstacoma and Abominator like this.
  8. Jan 25, 2020 at 6:52 PM
    NTH
    NTH Active Member
    Elkridge, Maryland
    ‘19 Tacoma TRD Pro Super White AT
    My method:
    1. From front bumper, place floor jack to the front lift point (bulge) as shown in pic above and lift entire front end.
    2. Place 2 stands on either side, on frame rails, directly in front of tranny cross member.
    3. Lower front end onto stands
    4. Take floor jack to the back and place lift pad under the rear diff.
    5. Lift entire rear and place stands under rear axle
    6. Lower rear end onto stands.
  9. Jan 25, 2020 at 6:55 PM
    baldbeardedtaco
    FL
    I mean that’s what I was thinking that made sense but worried about shifting on the front stands as the rear comes up
  10. Jan 25, 2020 at 6:56 PM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    That's the way I do it as well.
  11. Jan 25, 2020 at 6:56 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    This point that @NorNev pointed out is the point Iift my truck up from with my floor jack. Once the wheels are off the ground, place the jack stands at the spots for the factory jack point.
    At the rear I lift at the centre of the diff on the bottom of the pumpkin. Then put the jack stands under the axle where you would lift with the factory jack.
    Extra Hard Taco likes this.
  12. Jan 25, 2020 at 6:58 PM
    baldbeardedtaco
    FL
    Yes I used those same points to lift the front or rear separately but have always been worried about shifting on the stands as a whole
  13. Jan 25, 2020 at 7:00 PM
    baldbeardedtaco
    FL
    I have 3 ton harbir freight stands that I currently use. Is there any reason these wouldn’t be sufficient for lifting the whole truck?
  14. Jan 25, 2020 at 7:02 PM
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    I just lift one side at a time. Use two jacks
  15. Jan 25, 2020 at 7:02 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Your jack stands have a castle top, correct. Most do. When placing the stand make sure the frame sits in the valley, same with the diff. And just be slow when lifting and lowering.
  16. Jan 25, 2020 at 7:04 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    A jack stand rated at 3 tons is capable of supporting 6,000lbs. That means 4 will support 24,000lbs. Your jack stands will support your truck when positioned properly.
  17. Jan 25, 2020 at 7:16 PM
    baldbeardedtaco
    FL
    Not sure about castle top
    I see how when used in the rear inside of the ubolts on the axle it can cradle the axle but on the front points between the cross member and body mount it’s basically flat so nothing really gets in the valley
  18. Jan 25, 2020 at 7:21 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Yes they are castle tops. So make sure the diff sits in the round valley and the frame sits between the two peaks if they are wide enough. Don't have it sitting on the peaks if possible.
    Sorry for the crayon art work.
    RJ_MacReady and davidstacoma like this.
  19. Jan 25, 2020 at 7:24 PM
    baldbeardedtaco
    FL
    Ok I see now. I don’t think they are wide enough to straddle the frame though but I’ll pull it out tomorrow to double check. Thank you!
    Speedfreak[QUOTED] likes this.
  20. Jan 25, 2020 at 7:42 PM
    NTH
    NTH Active Member
    Elkridge, Maryland
    The front stands will not shift when you lift the rear!
    Do yourself a favor, and get yourself 4 Esco stands. 2 flat tops for the front and 2 axle cradles for rear axle.
    davidstacoma likes this.
