3rd Gen HID vs LED vs Halogen H11 projector headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnburn80, Jan 25, 2019.
  1. Apr 30, 2021 at 6:23 PM
    #4781
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Great post, though unsure on “green beer.” I’ll link it in the halogen post section.
    907rx7 and tclavell like this.
  2. Apr 30, 2021 at 6:29 PM
    #4782
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    This is why Dave is the best for customer service :thumbsup:
    tclavell likes this.
  3. Apr 30, 2021 at 6:40 PM
    #4783
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Don’t be hatin’ on the hometown brew!
  4. Apr 30, 2021 at 6:47 PM
    #4784
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Funny thing, Gordon Biersch brews Kirkland (Costco) beer. It is actually brewed in San Jose CA much closer to you than it is to me in Kirkland WA. :)
    907rx7 and daveeasa[QUOTED] like this.
  5. May 1, 2021 at 1:17 AM
    #4785
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Which units did you get? Note that huge increases in foreground light from poorly designed LEDs lead to positive perception of output, due to humans judging light output incorrectly based on near proximity illumination and not distance, which isn't how a headlight is supposed to work.
    I will say I take issue with Lastfit, being they are IP thief scum and blatantly copied Diode Dynamics website, marketing materials, graphics and videos even down to the music. Not like kinda copied, like copy/paste verbatim, the kind that gets you expelled from college and lands you in legal trouble in court. They only recently started removing the material after facing a legal action in a lawsuit from Diode Dynamics. I fully embrace capitalistic competition and may the best company win, but you will find no support in my threads for companies that engage in IP theft.
    jcampbell474, Aws123, selrod and 2 others like this.
  6. May 1, 2021 at 7:50 PM
    #4786
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  7. May 2, 2021 at 1:31 PM
    #4787
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    5th Gen 4runner post.
    Did some comparison tests using the 5th Gen 4runner H11 assemblies.
    GE/Tungasram +130 left vs Standard Osram H11 right
    Standard Osram H11 left vs GE/Tungsram +130 right
    The GE/Tungsrams provide ~37% increase in output intensity
    Compared to the Philips H9 swap
    Standard Osram H11 left vs Philips H9 right
    The Philips H9s gain ~42% greater output intensity vs Osram standard H11, and surprisingly only about 5% better than the GE/Tungsram +130s.
    Comparing to the 3rd Gen Tacoma output measurements:
    Some interesting things to compare:
    • The intensity numbers for the standard Osram H11 were ~16% higher for the T4R than the 3rd Gen Tacoma.
    • The GE +130s netted a 37% gain in the T4R, vs 74% gain in the 3rd Gen Tacoma. The Tacoma has better results with about 10% higher peak intensity, 1086 lux vs 989 lux.
    • The H9s netted a 42% gain in the T4R vs ~107% gain in the 3rd Gen Tacoma. The Tacoma has ~34% better peak intensity with 1294 lux vs 1030 lux.
    That 3rd Gen Tacoma projectors respond much more favorably to performance bulb upgrades than the 4runner projectors. For performance bulb upgrades to be most effective it requires precision optics, which goes inline with what has been mentioned before. The 4runner projectors are not that great.
    LEDs
    The 4runner uses uncommon side entry projectors, where the bulb is placed across/perpendicular to the projector lens rather than inline with it. The projectors use a cap/cover on the assembly that must be rotated and removed for access to the bulb inside. I'll need to double check, but access in here seems very tight for any type of fan cooled LED. The leading common bi-directional LED blade design seems particularly problematic for these projectors, as the solid metal blade would obstruct output being placed across the projector lens, unlike a transparent halogen bulb. But also as shown in the photo below, the projector is not sealed like 3rd Gen. Meaning if the cap cannot be reinstalled with an LED, the inside of the projector is at risk of being contaminated with dirt and dust which will greatly reduce performance.
    Other observations
    The uplight on these assemblies is very different than the Tacoma projectors. The Tacoma has a very distinct box of uplight in the center of each beam pattern directly above the hotspot. The 4runner projectors have a much softer and wider blend of light upward above the cut off, which also appears to be lower in intensity.
    Other testing notes:
    1) These assemblies were loaded with Philips Long Life (LL) H11 bulbs, which are lower output and longer life than standard bulbs. I replaced the LL bulbs with some mildly used Standard Osram H11s from other tests. So in comparing to an LL bulb if that is what you are running now, the relative gains with performance bulbs will be slightly better.
    2) Tungsram Nighthawk Xenon +120 are the best performing H11 bulb, but I did not have any of those on hand for the tests. The +130 bulbs are a close 2nd in the 3rd Gen Tacoma projector. However in the 5th Gen T4R projector, the reduced amount of blue coating on the +120s would likely have extra benefit due to the bulbs orientation in the projector.
  8. May 2, 2021 at 1:39 PM
    #4788
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    So maybe the Morimoto LED headlights for the 4Runner are a better upgrade than they are for the Tacoma :notsure:
    I can say going from the LL H11 to the Phillips H9 was a noticable upgrade.
    Toy_Runner likes this.
  9. May 2, 2021 at 1:42 PM
    #4789
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I have a feeling the blade obstruction will make them worse if LEDs are pointed outward and into the bowl, unsure how it will perform if the emitters were pointed up/down. I'll have to try it, but if the cap cannot close over the LED fan I'd really view it as a non-starter.
  10. May 2, 2021 at 2:06 PM
    #4790
    replica9000
    2019 T4R ORP
    I was thinking LED retrofit rather than the drop-in LEDs. If i remember correctly, the Morimoto LED replacement housing weren't too bad for the 3rd gen Taco.
  11. May 2, 2021 at 4:13 PM
    #4791
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Excellent comparison Crash. The different design of the 4runner projector definitely seems to be inferior to the rear-entry style.
    crashnburn80[OP] likes this.
  12. May 5, 2021 at 6:00 AM
    #4792
    daveeasa
    David
    PNW
    Super quick update, I have ordered a batch of H9 connectors which I am very hopeful are a near exact match to the OEM ones through a source from a fellow TW member. Minimum quantity was 250 and shipping was super painful. I don't own 125 H11 vehicles, so I'm hoping that there will be some decent interest. Once received I will start a BST thread and open for purchase at $10 a pair. I think most can get by simply popping out the green plastic part (described above) and replacing with the yellow H9 equivalent. And if your OEM connector is damaged for some reason, once the plastic part is removed, de-pinning and replacing the entire connector is reasonably straightforward.
    Of course you can still get by without any inner plastic part as it serves no functional purpose, but I suspect some of you would prefer to have things look legit and this should solve for that.
  13. May 6, 2021 at 2:07 AM
    #4793
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Philips Ultinon Pro9000 HL LED
    The latest replacement LED headlight 'bulbs' from Philips. I haven't seen these available in the US, I ordered these out of the UK. Philips markets these as the first replacement LED on the market to use OEM grade top contact Lumiled LED chips, which should reduce width and increases focus.
    First thing I always check is the width/cross section, which is a key element in focus, which is an important trait for output intensity and distance projection. Philips 2.85mm width is best in class for major name brands attempting to build a compliant LED product, but fall short of Hikari and Morimoto's latest offerings which both have better (reduced) width. For reference Sylvania 2.95mm, Hikari Ultra 2.64mm, Morimoto 2stroke 3.0 2.0mm. At this point the Philips product seems mildly underwhelming.
    Philips cross section:
    These bulbs spec:
    1350 lumens
    5800k color temp
    18w power draw
    5000 hours life
    An H11 bulb is spec'd at 1250 lumens, these LEDs are spec'd at 1350 lumens. The H11 spec allows for +/- 15% to be compliant, these Philips LEDs are about +8% making them compliant in terms of lumen output (replacement LEDs for headlights are not currently compliant for use on public roads in the US).
    Stable operating temp 1.11A @ 13.8v, aka these draw about 15.3w. Shy of the 18w spec by my stable temp measurements.
    As with any performance LED, fans keep the units cool. The heat sinks stay cool/warm to the touch while the body of the LED runs warmer. It is interesting to note these use an integrated driver, so there is no external driver box.
    Beam pattern comparison, Philips LED left vs GE/Tungsram +130 right (note color can be deceptive in photos)
    Philips LED pattern only. Note the lack of uplight and shorter pattern height.
    GE/Tungsram +130 pattern only. Note the difference in uplight and vertical height of the pattern, which makes sense when a replacement LED only projects directional light horizontally.
    42' Test. Philips LED left vs GE/Tungsram +130 right
    The halogens clearly do a better job in correctly placing peak intensity near the cut off for maximum distance projection, but this wasn't nearly as much of a blow out as I anticipated based on measured width, spec'd lumen output and power draw values.
    So how do they compare by the numbers? 42' Philips LED test measurement vs stock.
    The Philips LEDs handily beat out the stock output values, which was very surprising. Other products like Sylvania and Diode Dynamics targeted at building a compliant product have failed to exceed stock distance performance tests in the 3rd Gen projector.
    The measured color temp was a little under spec, near 5600k vs the 5800k spec.
    Comparing the Philips LEDs to the best in class focus Morimoto 2stroke 3.0s
    FULL STOP. Just wow. Look at that again.
    The Philips LEDs are rated at a 'legal' output rating of 1350 lumens running ~15w vs Morimotos drastically higher 2100 lumens at ~22w, yet the peak output distance intensity is within 4% between the two. How is that even possible given the Morimotos have a best in class 2.0mm width/cross section with significantly higher power and significantly higher output? Your mind should be spinning right now.
    Back to how Philips made a big deal about being the first with that OEM grade TopContact LED circuitry, it also seems their design of removing the metal housing on the upper side of the LED to facilitate unobstructed focus possibly helped significantly improved performance. When locked into place the thinner side of the LED faces upward, which is the most beneficial position to the low beam.
    So through superior engineering design, Philips was able to get near equivalent distance output intensity while maintaining legal lumen output levels vs a smaller LED with ~55% higher lumen output. Impressive to say the least. It is almost like a major respected German lighting brand might actually know what they are doing vs those Japanese sounding brands that are just reselling China products.
    Of course even the best LEDs don't match a good halogen upgrade in peak intensity, like the GE/Tungsram +130s.
    Highest output intensity LEDs tested so far have been the Hikari Ultras, included for relative comparison.
    My take aways:
    -The Philips Ultinon Pros will be added to my extremely exclusive list of recommended replacement LEDs
    -Product performance is exceptionally impressive for a product aimed at legally compliant output
    -This is the first product from a truly reputable manufacture to exceed stock performance in a 3rd Gen projector (and only the 3rd replacement LED tested to exceed stock performance so far)
    -Nothing replaces actual product testing
  14. May 6, 2021 at 3:59 AM
    #4794
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Thanks Crash, this is why testing multiple aspects is important vs reading a number on a box.
    Appreciate all the work and $$$
    Any chance you can put up a side by side with the new oem led?
  15. May 6, 2021 at 7:37 AM
    #4795
    Dtax
    Dtax Well-Known Member
    Massachusetts
    2017 Black Tacoma Sport
    Meso Bucket Tray
    @crashnburn80 - as always this is awesome and very appreciated!
    Question/observation - looks like the Hikari comp chart is up there twice vs the GE 130s? Sorry if i a not reading that all correctly.
    thanks again!
  16. May 6, 2021 at 7:42 AM
    #4796
    Steve Armstrong
    Steve Armstrong Well-Known Member
    SoCal
    2021 TRD Sport DCSB
    @ crashnburn80 - How much were these Ultinon Pros?
    And do you think they'll market them stateside?
  17. May 6, 2021 at 7:55 AM
    #4797
    ClimbMaintain
    ClimbMaintain Well-Known Member
    2020 Tacoma TRD OR DCSB AT
    Looks like the purveyor of all things, Amazon, wants GBP 149.90 for them. That's about $208 in US currency.
  18. May 6, 2021 at 8:54 AM
    #4798
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I no longer have the OEM LEDs for a side-by-side comparison. The OEM LEDs are definitely superior though, and have higher peak intensity than any replacement LED or performance halogen in the OEM halogen assemblies.
    Thanks for catching that. Fixed!
    No, these will not be marketed or sold stateside. Since replacement LED headlights are not legal in the US, and NHSTA has been cracking down on replacement LED headlights sold domestically for street use as illegal products forcing mandatory recalls, big name manufactures have just decided to not sell these products in the US.
    I got them out of the UK on ebay, which was the first place I was able to find them that wasn't based out of Russia. They were about $195.
    https://www.ebay.com/itm/233973905973
    Also! Be careful when ordering, there is a lower output foglight version as well, designated FL vs HL.
  19. May 6, 2021 at 10:26 AM
    #4799
    Steve Armstrong
    SoCal
    2021 TRD Sport DCSB
    Thanks both!
    I'll reconsider these when they go sub-$100 :p
  20. May 6, 2021 at 10:29 AM
    #4800
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Great review! thanks Ryland. I really like Philips lighting ever since I ran their first LED H4 bulbs in my 85 Toy PU(9 years ago), Really fantastic output from the 200mm H4 Buckets.
    I'm glad this was not a total waste of money for you(thanks agian). For now I'm sticking with the H9 bulbs, until Philips can pull a larger Rabbit out of it's hat.:thumbsup:
