3rd Gen E-Brake Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ShiftyShank, Sep 30, 2021.
  1. Sep 30, 2021 at 8:09 AM
    ShiftyShank
    ShiftyShank [OP] Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    Hey guys, Recently I have discovered a defect on my 2019 TRDOR (MT).
    I've lightly searched the forum and could not find related posts. So I wanted to post this issue and see if anyone else has run into this before.
    What happened is I parked my truck in the garage and engage the parking brake. Upon the next time I hop in the truck and drop the park brake handle and put it in first. The brake is still engaged and I cannot move the vehicle. Both times I had to get my floor jack out and lift the rear end, and engage/disengage the parking brake multiple times to eventually get it to release while knocking the rear wheels by hand. It appears to me that the left wheel is the wheel with the problem. I will link a video below of the second time this happened. I have not followed up with Toyota yet at this moment.
    Luckily both times were at home and I was able to remedy the issue. After the first time I took it to the dealer and they could not recreate this problem and saw no problems with the parking brake upon inspection. I want to know if anyone else has experienced this.
    https://youtu.be/pq30trZNAmQ
  2. Sep 30, 2021 at 8:11 AM
    Bishop84
    Bishop84 Well-Known Member
    Very common, typically its in the winter, they released a TSB that addresses this when water enters the drums, I'm surprised the dealer didn't use that TSB to at least try and resolve the issue for you.
    Chew, Skydvrr and Kev250R like this.
  3. Sep 30, 2021 at 8:16 AM
    ShiftyShank
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    I'm unfamiliar: TSB is?
    Good to know it's common. Has only happened this summer.
    I appreciate the info. That'll help when I contact them next.
  4. Sep 30, 2021 at 8:17 AM
    Bishop84
    Technical service bulletin. It's a plug that goes in the rear axle. Make sure to ask for it during the cold months.
    Skydvrr and ShiftyShank[OP] like this.
  5. Sep 30, 2021 at 8:19 AM
    ShiftyShank
    Pat
    Northern Colorado
    02' BestGen 5VZFET
  6. Sep 30, 2021 at 8:20 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    What’s the TSB # ? Tks
    mosccat and ShiftyShank[OP] like this.
  7. Sep 30, 2021 at 8:23 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Happened to me twice in SoCal. Heard a loud thud when the truck moved.
    ShiftyShank[OP] likes this.
  8. Sep 30, 2021 at 8:27 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Link for the TSB?
  9. Sep 30, 2021 at 8:33 AM
    TacoTruckCO
    TacoTruckCO Well-Known Member
    Joel
    Portland, OR
    Voodoo Blue 20 OR DCLB
    i had this happen on my old '11 F150. The parking brake mechanism was frozen with rust. Rust may not be the issue here, but might be worth looking at it for any rust or something that is causing it to stick. And getting that plug can't hurt!
  10. Jun 25, 2022 at 8:42 PM
    It's a TRD Thang
    It's a TRD Thang Well-Known Member
    Canada
    2021 Army Green Off Road
    3 inch Leveling kit with 265 75 r16 Ko2's
    Had my drums replaced yesterday on my 2021. Apparently the ebrake cable can come too tight from factory. I'm hoping my fuel mileage improves a bit
  11. Jun 25, 2022 at 8:49 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    By any chance, did you wash the truck or play in a puddle and put it away wet? It is common for the shoes to stick to the drums from corrosion if they are not dried off... if you did, it is a good to go drive the truck and get the brakes warmed up to dry them out. I see this happen frequently with the commercial vehicles I work on. The longer they sit the worse the stick gets...
  12. Jun 26, 2022 at 11:19 AM
    ShiftyShank
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    Yup happened after I wash the truck my friend.
    Speedfreak[QUOTED] likes this.
  13. Jun 26, 2022 at 12:06 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Good one! Thanks for the laugh.
  14. Jun 26, 2022 at 12:53 PM
    It's a TRD Thang
    Canada
    It can cause drag but obviously you're not very intelligent
    mosccat likes this.
  15. Jun 26, 2022 at 12:57 PM
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    Same here, happened twice after washing. I now drive around the block after washing and hasn’t happened in the past 2 years.
    Never happens from rain, only water sprayed directly…
  16. Jun 26, 2022 at 1:12 PM
    turbosix
    turbosix Well-Known Member
    dfw
    2024 TRD Pro
    OP.. why are you using the ebrake? i'm pretty sure your garage isnt poured at a 45* angle... you should be leaving the truck in gear.
  17. Jun 26, 2022 at 2:47 PM
    ShiftyShank
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    This is the same practice I now use to avoid the issue.
    It's safe practice to use your parking brake and leave the vehicle in gear. Regardless of the surface being level or graded
  18. Jun 26, 2022 at 2:52 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Can't say I've ever used the ebrake on any of my vehicles unless parked on a grade, even then I forget to use it, lol.
    turbosix likes this.
  19. Jun 26, 2022 at 2:53 PM
    turbosix
    dfw
    2024 TRD Pro
    :rofl:no... you don't need both. especially when the thing is on level ground. if it was an auto would you also be putting it in park and pulling the ebrake?
  20. Jun 26, 2022 at 2:54 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    You have never seen the park pall in an automatic transmission, or seen a vehicle roll away from a slight hill because the compression alone wouldn't hold it then...
