3rd Gen DCLBs Stock vs Lifted
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RNILT, Aug 13, 2022.
  1. Aug 13, 2022 at 3:04 PM
    RNILT
    RNILT [OP] Well-Known Member
    Luke
    2022 TRD Off-Road DCLB Barcelona Red
    TLDR: Would love to see pics of your 3rd Gen DCLBs and descriptions of whether they’re stock or lifted. Especially looking for comparisons of stock vs OEM TRD Lift Kit (or an equivalent, modest lift).
    More info: My DCLB Off-Road is arriving this week. I plan to run it stock for a while and see what it needs based on my use. But I’m considering/researching a small lift. Mostly because sometimes, to my eye, a DCLB can look a bit low and long. Been reading through the forums but haven’t seen too many pics of DCLBs that include descriptions of their lifts/tires.
    For now, I’m interested in a modest lift, like the OEM TRD Lift Kit. I gather most dealerships won’t do the TRD Lifts on 6’ beds. I saw someone post that, when their dealer said no, they instead had the dealer install 2" spacers in the front and 1" blocks in the back - and they had it done before they took delivery so it could be included in the warranty.
    Should I consider going that route if they say no to TRD Lift Kit? I’m totally okay with just changing the height and not the suspension.
    Or would just going up on tire size accomplish what I’m looking for?
    Truck will be a daily driver, with occasional long highway trips and frequent weekend camping adventures. Bumpy dirt roads, forest service roads, and some beginner off-roading but nothing challenging. Also need to tow a tear drop trailer or small lightweight camper sometimes.
    Totally new to trucks, suspensions, and lifts, so forgive any errors or ignorance.
    Thanks for any help - and for your pics, which will let me better visualize all of this.
  2. Aug 13, 2022 at 3:07 PM
    Motofox
    Motofox Well known hermit
    Stephen
    Northern California
    2014 DCLB
    custom pin-striping and dirt
  3. Aug 13, 2022 at 3:11 PM
    GarrettTacoma
    GarrettTacoma Well-Known Member
    2022 2.7L SR DCSB 2022 TRD OR DCLB
    NOT lifted with 265/75-16 tires.
    TexasWhiteIce likes this.
  4. Aug 13, 2022 at 3:13 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    For your intended use, stock is more than enough capable to handle that.
    For aesthetics, I do feel DCLB will look better running on tires that are a bit larger and wheels with some poke like 0mm offset to -10mm to make it look wider. Check https://www.tacomaworld.com/threads/lets-see-those-double-cab-long-beds-3rd-gen.417031/ you'll find all the possible DCLB and what people do with it.
    Also, whatever mod you do to it, it'll just void that part of warranty. No reasonable dealership would deny your engine failure warranty because you changed the shocks
  5. Aug 13, 2022 at 3:18 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    There are literally 100s of threads on DCLBs and 3Gen lifts. You spent more time typing then it would have taken to search.
    Bishop84 and Motofox like this.
  6. Aug 13, 2022 at 10:09 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    TRD lift kit isn't an option for a DCLB, at least according to Mama Toyota, as you indicated:
    "Fits MY20+ Tacoma V6 4X4 (Excluding: 2WD, 4Cyl, Double Cab Long Bed, and TRD Pro)"
    Mine is not lifted, 4Runner TRD Pro wheels with a +4mm offset and the OEM Toyo A30s 265/65R17 (for now)
  7. Aug 14, 2022 at 6:10 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    2" F/R 6112/5160 Bilstein 2nd gen Pro suspension
  8. Aug 14, 2022 at 7:28 AM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Icon 2,5'' coilovers and rear springs, RCI full skids, caliraised sliders, Warfab hitch skid, UpTop roof rack, kb voodo bed rack, Diode Dynamis Pro fogs, Seat Jackers with Molle, taco garage mounts..... and other stuff
    Hello and welcome. I’ve got a DCKB with 265/75/16 and a 2” icon lift front abs 1.75 rear.
  9. Aug 14, 2022 at 5:08 PM
    Color_Me_Taco
    Color_Me_Taco Well-Known Member
    Doug
    Utah
    2022 TRD OffRoad, 2019 TRD OffRoad, 2021 Subaru STI, 2021 Kawasaki ZX6R
    ADD, Rigid, ToyTech, DBcustomz, Methods, Nittos, Powertank, Morimoto
    TRD OR LB Toytech 2.5 BOSS suspension lift.
  10. Aug 14, 2022 at 5:10 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Keep it stock, stock is cool and it will last a very long time.
    Good luck with your truck.
    Mikeh80 likes this.
  11. Aug 14, 2022 at 8:34 PM
    bwhiteside5
    bwhiteside5 Active Member
    Brandon
    San Antonio TX
    2020 CMNT 4x4 TRD OR DCSB
    •LEER 100xq cap •~2” Lift: Eibach in front, fox 2.0 & icon rtx leaf pack opt. 2 in rear. •285/75R17 Nitto RGs •17” SCS Ray10 gunmetal -10 •CMC, Front wheel well heat gun plastic molding.
    you can get an actual full suspension lift for about the same price as that overpriced TRD spacer lift.
  12. Aug 15, 2022 at 4:52 AM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    94DBD21A-EA28-42DC-A2C7-2FF582237ED3.jpg Oh ya- this is mine with a 2.5” Icon Lift.
