3rd gen can swap help needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Booleo, Feb 7, 2025.
  1. Feb 7, 2025 at 11:00 AM
    Booleo
    Booleo [OP] Well-Known Member
    James
    2022 White Tacoma
    Custom +5 IFS on 10” coilovers 4wd 40” trailing arms 14” coilover short course setup
    Guys it fuckin happened. I rolled my 3rd gen… time for the rebuild. First step is a new cab. I don’t know any of you really, has anyone ever gone through the process of swapping a cab and rewiring it and willing to help me. I can get the new cab mounted onto my frame a trailer the truck up to wherever the person is. I can only find cabs with bare metal no wiring left inside. So I’ll have swap over all my wiring into the new cab. Not sure how hard of a process that is but I’m willing to get it done and however long it takes. The truck still runs and drives straight! I did not have a roll cage in place so atleast that makes it easier to swap over the cab just 4 bolts and cut some wires and I can swap it with a skid loader. Once that’s done and wired up I can lock in the frame with the roll cage sitting at my house. Frames kinked in the rear but nothing a frame shop couldn’t handle, already talked to a few willing to take it on.
    SoonToBeOn39s likes this.
  2. Feb 7, 2025 at 11:03 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Apparently this truck is not a daily driver and driven pretty hard. Why not just use a hi-lift and BFH, get it back close and keep sending it?
    OZ TRD, K9tacoma, musicisevil and 2 others like this.
  3. Feb 7, 2025 at 11:10 AM
    545 Well-Known Member
    2015 Access Cab
    Well no one could have seen a rollover coming
    OZ TRD, RIX TUX, monoman and 5 others like this.
  4. Feb 7, 2025 at 11:51 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Plenty of people have used a hi-lift to get their cab back into shape after rolling. Pics don't look that bad now that you've added some more, so a hi-lift probably wouldn't do you any good. For how you use the truck, doing a cab swap sounds like dumb shit to me since you are just going to roll it again. But you do you, it's your truck.
  5. Feb 7, 2025 at 12:00 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
  6. Feb 7, 2025 at 12:08 PM
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    King of the hammers ?
    Booleo[OP], FunknNasty and t0p_d0g like this.
  7. Feb 8, 2025 at 4:27 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I kind of agree with @TenBeers also don't think he was trying to be a dick.
    From the pics it does not look so bad. Many worse looking bodies out there.
    Leave it fucked and do a roll cage. All that damage is just trail cred.
    With all the work you do yourself I'm kind of surprised you want a new cab.
  8. Feb 8, 2025 at 6:55 AM
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    If you do decide that the cab change out is really the way you want to go, I'd highly recommend extracting your wiring harnesses without cutting them. Definitely more tedious, but far better for long term reliability.
    musicisevil and OldSchlPunk like this.
  9. Feb 8, 2025 at 8:20 AM
    barcelona_tacoma
    barcelona_tacoma Member
    2020 OR
    bought, not built
    Wire harnesses are prefabricated before installing them into the chassis at the factory. So you should be able to take the harness out without cutting anything.
    I would start by taking everything out of your cab, labeling all the nuts and bolts as you go. When you get all the I interior trim out of the way, you'll be able to see how the harness is ran.
    I would try to keep the harness attached to the dash, and remove both at the same time. There's a lot of wiring behind there and could be a pain to get back together.
    Take a lot of pictures.
    Booleo[OP] likes this.
  10. Feb 8, 2025 at 8:28 AM
    Dirt McGirk
    Dirt McGirk Well-Known Member
    Phoenix, AZ
    19 TRD OR 4X4
    I can see why you don’t have friends to ask for help on this.
    rascott95, OZ TRD, t0p_d0g and 4 others like this.
  11. Feb 12, 2025 at 7:56 AM
    Booleo
    James
    2022 White Tacoma
    yea thinking about it more I guess it’s really just easier to wack at that caved in spot a bit and just throw the cage in, or just cut the whole roof off and reweld it back on. the cage sits super tight against these cabs. Clean cab shell was only 750$. I’ll just get that roof caved back out best I can and start on the cage. Cab swap really wouldn’t be that bad tho but definitely save me a fuck load of time to avoid it. @TenBeers my bad, was just soo fucking pissed that I rolled my shit, was able to keep it alive for about 2 years of hardcore ripping. It’s bound to happen when you’re going crazy. That’s why it’s going to be a race vehicle soon so I have reason to break it again haha.
  12. Feb 12, 2025 at 1:54 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  13. Feb 13, 2025 at 10:01 AM
    Booleo
    James
    2022 White Tacoma
    Exactly what I’m thinkin haha. This is gold
  14. Feb 13, 2025 at 10:04 AM
    Booleo
    James
    2022 White Tacoma
    Yea happened down Boone rd towards the start gate. Some weird s Saturn with big whoops through their. Never realized how much anti squat I created in the rear when changing ride height so once the shocks faded out I had no idea what the truck was doing. Redesigned my rear to be a 4 link with longer trailing arms and much less anti squat around 30-50% so the shocks can do all the work without have geometry clashes like before.
    baboltin[QUOTED] and FunknNasty like this.
  15. Feb 14, 2025 at 11:50 AM
    Booleo
    James
    2022 White Tacoma
    I can see why your balls haven’t dropped yet
    FunknNasty likes this.
  16. Feb 15, 2025 at 5:55 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
  17. Feb 21, 2025 at 9:01 PM
    Booleo
    James
    2022 White Tacoma
    Those dudes get the job done it’s awesome to watch. I ended up getting a porta-power like @ClassyTacos recommended and I was able to push the cab back out enough I think to get the cage in their. I’ll find out soon enough.
    Before/after porta-power photos below:
    Time to cut the frame rails and replace it with some 2x6 boxed steel tubing and then back half the rear attached to the cab cage. Then I can burn in the 4 link, mount shocks/bump out
  18. Feb 22, 2025 at 6:23 PM
    TacosyBurritos
    TacosyBurritos Well-Known Member
    2021 TRDS AC 4x4 MT
    At the risk of incurring the fiery wrath of the OP, I’m gonna go ahead and point out that your engine bay currently has more protection than the area the driver occupies whilst shredding mad gnar and holding down the whoops for the 3rd gen crowd.
    I understand that a roll cage doesn’t make the truck ride buttery smooth at 70 across the desert, but I’m of the opinion that it ought to be the first priority before you get out there to show everyone just how far your balls have dropped.
    A truck built for high speed in the desert that lacks a roll cage reminds me of the guy riding his sport bike in flip flops and a tank top.
    with that said, I sincerely hope a proper cage is the next thing on your agenda before you get back to holding it down for the 3rd gen crowd in the desert.
    EDIT: From what I’ve gathered it looks like a cage is in the works. Bravo!
    dryheat likes this.
  19. Feb 22, 2025 at 6:26 PM
    Booleo
    James
    2022 White Tacoma
    Appreciate your concern, but before writing a super lengthy story, read through the messages because I’ve mentioned multiple times that a cab cage is going in this time around.
  20. Feb 22, 2025 at 7:54 PM
    dryheat
    dryheat Well-Known Member
    I didn't read your OP. Can you sum up in 5 words or less what you want?
