3rd Gen Cab Angle?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by El Tigre, Jul 13, 2021.
  1. Jul 13, 2021 at 11:08 AM
    El Tigre
    El Tigre [OP] Well-Known Member
    Long Beach
    2018 DCSB TRD Sport 4x4 6speed
    Armrest MOLLE Panel (https://www.tacomaworld.com/threads/3rd-gen-center-armrest-molle-panel.712437/) Hood Scoop Hidden Baja Designs S8 10" Diode Dynamics SSC2 Pro Ditch Lights Bilstein 6112 front Bilstein 5160 rear Bakflip MX4 DIY Bed Lights RGB Rock Lights Modified Amazon 8 gang switch controller (thread coming)
    I've searched Google and the forum but possibly wording it incorrectly. Does anyone know the vertical angle of the back of the cab? For the purpose of building a frame over the bed but wanting to try and match the shape of the cab as well.
    Pic as example in case I'm still not explaining correctly...
    Grossomotto likes this.
  2. Jul 13, 2021 at 8:19 PM
    TRD2021SPORT
    TRD2021SPORT Well-Known Member
    2021 Tacoma TRD Sport AC
    Personally I would want to take the measurements myself than rely on someone else's measurements. Is there a reason you don't just stop by your local Toyota dealership and measure for yourself, after hours of course :)
  3. Jul 13, 2021 at 8:56 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    This is a job for a template. Take a thin piece of cardboard or card stock, and trace the shape of the cab on to it. Then lay out your tubing against that template to design the angle of your tubing bends.
  4. Jul 13, 2021 at 9:08 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  5. Jul 13, 2021 at 9:12 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I hate to be this guy, but it's actually 22.46°... accuracy counts.
    stu8319 and Grossomotto[QUOTED] like this.
  6. Jul 13, 2021 at 9:23 PM
    Grossomotto
    2017 4WDV6LB6MT
    Ha, I measured it as half of 45 while making these lights to mount to a bed rack that angles with the cab so they would point straight out. A lot of metal saws have the 22.5 degree angle as a setting so it's easy to make multiple cuts. (Going back and forth from 0 to 22.5)
    Bertw192[QUOTED] likes this.
  7. Jul 13, 2021 at 9:25 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Lol... I thought you were being a smart-ass... OP, disregard me...
    Grossomotto[QUOTED] likes this.
  8. Jul 13, 2021 at 10:25 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Bertw192 likes this.
  9. Jul 16, 2021 at 10:10 AM
    El Tigre
    Long Beach
    @TRD2021SPORT I was trying to do so on my own vehicle with some cardboard but kept messing it up...
    @Grossomotto and @Bertw192 Thank you both! Much appreciated, I spent the last two days trying to do some cardboard fun and kept getting frustrated.
    @Captqc thank you for the image, that's a sweet tool to find angles what is that? Based on that it looks like roughly 16 degrees but maybe that's because it's at the start of the slope?
  10. Jul 16, 2021 at 10:33 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Hey OP, yeah, the angle tool used in that photo is great, but because the side of the truck is curved, you'll end up with a different angle depending on where the tool is placed.
    If you go to your local hardware store, you can pick up that angle gage for fairly cheap. Then, get a steel straight edge and stick the angle tool to it. Then, hold up the straight piece of steel with the angle gage on it at the desired slope for your rack... that should give you an appropriate angle.
  11. Jul 16, 2021 at 10:51 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Download app Clinometer .
  12. Jul 16, 2021 at 12:33 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Exactly, do it on CAD (Cardboard Aided Design) Easy, accurate and cheap...
  13. Jul 21, 2021 at 11:40 PM
    ConantTaco
    ConantTaco Well-Known Member
    Dave
    2019 Tacoma TRD Off-road
    The most accurate method is a Cardboard template that you slowly and carefully trim to fit.
    Guaranteed fit!
    Bleep100 likes this.
  14. Jul 21, 2021 at 11:40 PM
    ConantTaco
    Dave
    Copy!!
  15. Jul 22, 2021 at 3:37 AM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    If you are not capable of measuring the angle are you going to be able to handle fabricating a rack?
    Dawalker1966 likes this.
  16. Jul 22, 2021 at 4:33 AM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Check with an auto glass company they should have the correct angle as it looks to be the same as the cab.:goingcrazy:
  17. Jul 22, 2021 at 6:28 AM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    That looks to be the most accurate way to measure, until you start to consider factors like Taco lean and the amount of fuel in the tank.
    EDIT: assuming 0deg is the ground.
  18. Jul 22, 2021 at 6:41 AM
    Sasquatchian
    Sasquatchian Well-Known Member
    Ditto. One of the best utility apps on my iPhone (and it's available for Android as well) Far more accurate and repeatable than those cheap plastic angle finders. I mostly use it for leveling out cameras when shooting architecture but it'd be perfect for this and then it travels with you wherever you go.
  19. Jul 22, 2021 at 7:42 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Measure both sides and split the difference.
    I'd also just put my angle finder on the rear side windows to find the angle. Then you're not trying to measure the angle while worrying about the slight curve of the metal corners near the top. The windows will be nice and flat.
  20. Jul 22, 2021 at 8:00 AM
    E.J.
    Josh
    NWA
    I think an angle finder/transfer tool like this would work better than a clinometer for this project. Place it on the front bedrail, adjust to a visually appealing angle (i.e. follow the edge of the window), and Bob's your uncle.
    DingleTower likes this.
