3rd gen body mount bushing kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nomis88, Sep 12, 2020.
  1. Sep 12, 2020 at 1:38 PM
    Nomis88
    Nomis88 [OP] Well-Known Member
    max
    17 taco
    Am I missing something or is there no 3rd gen body mount bushing kit? I bough a kit for a second gen but the brackets don’t align with the bolt holes for the four cab mounts.
  2. Sep 12, 2020 at 1:51 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
  3. Sep 12, 2020 at 3:34 PM
    Nomis88
    max
    17 taco
    I changed the radiator bushings which were shot and I was hoping to change out the rest of the cab bushings (even though they look okay) just for peace of mind. The radiator bushing are interchangeable from previous gens and I’m sure the cab bushings are too, it’s the bracket that is not fitting on the cab bushings
    twitchhero likes this.
  4. Sep 23, 2020 at 3:00 PM
    Fernando95diaz
    Fernando95diaz Well-Known Member
    Fernando
    2019 Tacoma off road 4x4
    Were you having any squeaking before changing the rad bushings?
  5. Sep 23, 2020 at 3:25 PM
    Nomis88
    max
    17 taco
    More so clunking in the front end. The radiator bushings fixed that. 40k miles and both radiator bushings failed
  6. Sep 23, 2020 at 7:52 PM
    Fernando95diaz
    Fernando
    Was it consistent before you figure out what it was mine squeaks at low speeds I had it at around 10k went away now at 18k it suddenly came back
  7. Sep 23, 2020 at 9:02 PM
    Nomis88
    max
    17 taco
    it never completely disappeared but it changed noises and became less prominent at times. It only happened at low speeds. If you are chasing noises I would start with the radiator bushings, they are super easy to change out
  8. Sep 23, 2020 at 9:30 PM
    Fernando95diaz
    Fernando
    Do you have the part number you used for your bushings?
  9. Sep 23, 2020 at 9:37 PM
    Nomis88
    max
    17 taco
  10. Sep 23, 2020 at 9:44 PM
    Fernando95diaz
    Fernando
  11. Sep 23, 2020 at 9:52 PM
    Nomis88
    max
    17 taco
    the bracket (diamond shaped plate) mounting holes don’t align with the third gen bolt holes. The provided bracket is too short.
    whatstcp[QUOTED] likes this.
  12. Oct 4, 2020 at 8:17 PM
    Fernando95diaz
    Fernando
    Was the squeak gone right after the swap?
  13. Oct 5, 2020 at 11:06 AM
    Nomis88
    max
    17 taco
    I only swapped the radiator support bushings, but yeah that fixed my problem
    Fernando95diaz likes this.
  14. Oct 24, 2021 at 5:48 PM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    So did you find one? I need to do all mine.
    BeefStrokiNOff likes this.
