3rd Gen Axle Recall -Torque
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma_Pop, Nov 18, 2024.
  1. Nov 18, 2024 at 6:16 PM
    Tacoma_Pop
    Tacoma_Pop [OP] New Member
    2023 TRD Sport Premium 6 Speed
    I finally took my 2023 TRD Sport to the dealer to address the recall some of us received associated with the possibility of weld splatters on the rear axle impacting the torque specs on certain nuts that hold the rear wheel housing to the axle. Essentially, the nuts keep the rear wheels attached to the vehicle
    I watched the Tech remove all 8 nuts, inspect, and re-attach. The tech did NOT USE A TORQUE WRENCH.
    I asked the tech why a torque wrench was not applied. He said the nuts in question do not need to be overly-tight and a torque wrench was not needed.
    I understood the recall increased the torque on those nuts from 33 pound feet to 41 pound feet.
    SHOULD I BE CONCERNED?
    Wasn’t the entire logic of recall to make sure the nuts were torqued to factory requirements?
  2. Nov 18, 2024 at 8:29 PM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    Most shops will not let anybody stand and watch their techs work on customer’s vehicles, because of liabilty crap. Tech giving you BS because you only standing, and watching. Other option, buy 3/8 drive torque wrench from Home Depot, or Napa, torque axle nuts yourself. Next time go another Toyota dealer, for anymore recalls, or warranty.
    boston23 and MagicToolbox like this.
  3. Nov 18, 2024 at 9:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I am just going to go ahead and say it.
    There isn't a technician out there that's breaking out a torque wrench for every bolt.
    And the ones saying they do, as saying it to cover their ass.
    And to keep the haters from hatin'
    If you turn wrenches daily, you can "feel" what tight it.
    Sometimes it's better to "know" it's tight.
    Than to "think" it's tight based off a "click" or a "beep".
    Sure, certain things should always be torqued.
    But not everything.
    OZ TRD, boston23, Toy_Runner and 5 others like this.
  4. Nov 19, 2024 at 5:32 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Typically the oversight isn’t appreciated.
    Yeah, he probably should’ve used a torque wrench.
    boston23 likes this.
  5. Nov 19, 2024 at 5:47 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    No. Torque spec didn’t change.
    No. They hold the axle in, they don’t need to be tightened to an exact torque to accomplish that. Snug will do. The nuts have a large flat surface area sort of like a washer head bolt that makes a lot of friction contact with the axle housing. If they’re snug, they won’t be coming off.
    The logic of the recall was to make sure weld splatter on the axle housing surface where the nut goes wasn’t present to keep the nut from tightening properly. Undo the nuts, check for splatter, if none is there then retighten nuts and call it done.
    In a perfect world, the tech would use a torque wrench. However, unless the tech is a complete moron, he doesn’t need to use a torque wrench to adequately perform the job.
  6. Nov 19, 2024 at 6:05 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The recall was for possible mfg debris, which if present would prevent the nuts from clamping the wheel bearing studs properly. Torque spec wasn't the issue.
    When I installed the Archive Garage wheel speed sensor guards (which is held in place with 2 of the 4 nuts), I didn't use a torque wrench. The torque spec is low, and would need to be reduced further because I used cosmoline. You'd be more likely to overtighten and snap a stud with a torque wrench here. If you want to see how it's held up, check the June page of the 2023 Tacoma World calendar.
  7. Nov 19, 2024 at 6:56 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I just did the recall yesterday myself and yes the torque changed from 33 ft. lbs to 41 ft. lbs. and if the technician did not torque them he didn’t follow the recall instructions.
  8. Nov 19, 2024 at 7:01 AM
    BLtheP
    Plano, TX
    I just read the recall and it doesn’t say anything about the torque changing?
  9. Nov 19, 2024 at 7:11 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    3JOH22A likes this.
  10. Nov 19, 2024 at 7:22 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    eurowner likes this.
  11. Nov 19, 2024 at 8:02 AM
    TnShooter
    Deogee
    STOCK
    If it makes any of you 3rd Gen guys feel better.
    Us 2nd Gen are running around with a spec of 29 ft/lbs.
    And it's the same nut / stud.
    Tight should be good enough.
  12. Nov 19, 2024 at 8:08 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Yes, that makes us feel a lot better lol.
    boston23 and TnShooter[QUOTED] like this.
  13. Nov 19, 2024 at 12:58 PM
    Tacoma_Pop
    @STEELeR43
    As a Consumer that paid Toyota’s price for the last of the 3G… to avoid the POS Turbo in the 4G… I watch and have every right to do so. I didn’t ask for the “Voluntary” Service. Like all, I was more or less mandated to do. It is a Toyota CYA RECALL.
    The other responses associated with knowing what is tight helps ease my mind. I realize it is not possible to get a torque wrench everywhere, but these nuts are very accessible, especially with vehicle lifted in air.
    I assume the TSB Recall cites 41 ft pounds for a reason. More than likely the nuts are on tighter than 41 ft pounds, and I am OK. It simply PISSES ME OFF that Toyota takes market leading dollars for this vehicle… contradicts “Toyota Quality” with need to recall, and fails to follow their published protocol to repair.
  14. Nov 19, 2024 at 1:33 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    For anyone interested in doing the recall yourself you will need to purchase one of these to gain access to the nut that’s behind the lower shock mount on each side otherwise you will need to pull the lower shock bolts out.
    https://a.co/d/bT6C5ce
  15. Nov 19, 2024 at 1:56 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    what's with the over the top reaction and unnecessary bolding
    Phlogiston, Chew and eurowner like this.
  16. Nov 19, 2024 at 1:58 PM
    canuck guy
    Alberta
    23TRDOR
    that's total b.s. and old wives tale
    ya they don't want you in the shop
    it's to keep their people working
    liability is not it
  17. Nov 19, 2024 at 3:16 PM
    STEELeR43
    Hawaii
    @Tacoma_Pop
    Why write in all bold letters?
    I bought brand new 2023 TRD OffRoad 6MT, last year, and I luv my 4x4. I got the axle nut recall taken care of at my Toyota dealer, no problems.
    Like I said my previous post, find another Toyota dealer, for any issues that comes up.
    I don't want to start arguement, I get what you wrote. But what happens if customer watching tech at shop, forgets him/herself, trips and falls over, gets hurt. Who is responsible?
    Phlogiston and Chew like this.
  18. Nov 19, 2024 at 4:30 PM
    Tacoma_Pop
    The cut and paste made bold font… No meaning behind it…
    … and this particular dealer is better than most… Maybe none of the performed recalls utilized a torque wrench… Who knows…
    … and yah you can’t come into shop, but you can watch at bay door
  19. Nov 19, 2024 at 4:37 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Looks Angry
    t0p_d0g likes this.
  20. Nov 19, 2024 at 6:29 PM
    Tacoma_Pop
    Maybe annoyed at Toyota… Not at Taco Fellas… :)
