3rd gen 4Runner steering wheel on 1st gen Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Teke, Jul 29, 2017.
  1. Jul 29, 2017 at 8:52 AM
    Teke
    Teke [OP] Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    As the title states, will a 3rd gen 4Runner steering wheel directly swap into a 1st gan Tacoma? I don't see why it wouldn't, but before I got to the trouble of pulling it off at pick-a-part I want to make sure it will. Mine looks like garbage so I want a new one.
  2. Jul 29, 2017 at 6:18 PM
    cazinpa
    cazinpa Well-Known Member
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    Doubtful
  3. Jul 29, 2017 at 7:14 PM
    khail19
    khail19 Well-Known Member
    Khail
    Reno, NV
    2000 Prerunner SR5
    DustStorm4x4 likes this.
  4. Jul 29, 2017 at 7:15 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Yep, it will. I've swapped 4runber steering wheels in both my 96 and 99 Tacoma.
    My 96 is a base model 5lug and and the click spring didn't have enough wires in it for the cruise control switch. I had to track one down that had the correct number of wires. However, if your truck currently has cruise control, you should be good to go.
    One other thing to remember is that 00 and older Tacomas and 4runners used a 3 wire cruise switch. 01+ used 2 wire. The switches are shaped different between 2 and 4 spoke wheels and thus, not interchangeable. However, a 3 wire switch from a 4 spoke wheel will go in place of a 2 wire switch on a 4 spoke wheel and visa versa
  5. Jul 30, 2017 at 12:10 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I've been trying to get an answear to the question of "enough wires" Thank you
  6. Jul 30, 2017 at 12:48 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    As best I can tell all 3rd gen 4runners and 98-04 Tacomas use the same clock spring, 95-97 have different airbag plugs and various numbers of wires in the clock spring.
  7. Jul 30, 2017 at 1:04 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    What i have is an 02 I'm looking at suppling factory cruise control parts for it. I don't have access to it to check if original non factory CC truck clock spring will work.
  8. Jul 30, 2017 at 1:31 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    When you have access to it, unbolt the airbag via one start bit screw on each side at the 3 and 9 o'clock position. Then the airbag should pop out (there are some white prongs that hold it in place that kinda pop in and out) the airbag harness is long enough to set the airbag on top of the steering wheel without unplugging it. Then there is a white plug directly above the steering wheel nut. Unplug it and see how many pins are inside the clock spring connector. You will need at least 3 for the for 01+. 2 for cruise and one for the horn.
  9. Jul 30, 2017 at 2:02 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Sorry to jack your thread op
    Trucks in another state. @coryohana need you to confirm this ^^^^
    Ok one more run at the blackjack tables. Vegas is being good to me this weekend. :fingerscrossed::bananadance::headbang::yes:
    Dalandser likes this.
  10. Jul 30, 2017 at 7:18 PM
    Teke
    Colin
    Indiana
    Well before I saw any of these responses I just went and got it and plopped it right on. Fit perfectly.
  11. Aug 19, 2017 at 2:29 PM
    coryohana
    coryohana Well-Known Member
    Cory
    Ventura, CA
    2002 Prerunner TRD 3.4 Auto w/locker
    *Magnuson Supercharger *OME suspension with 880 coils *Dakar Leaf Pack *SCS F5 Dark Bronze, wrapped in KO2's *Custom Diamond Back bed cover and rack with custom storage *LED exterior/interior light replacement *SS brake lines *TC LCA Cam Tab gussets *TC UCA
    mechanicjon likes this.
  12. Aug 19, 2017 at 3:02 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    What about putting a 2016 Tacoma steering wheel anybody heard of that? That may be a try to for me if I get my hands on one.
  13. Aug 19, 2017 at 5:12 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    the wheel itself may fit but all the electronics and airbag wires would not match up. I for one would not try to rig wires dealing with the airbag.
  14. Aug 19, 2017 at 11:41 PM
    Anthony250
    Anthony
    Rialto CA
    Just curious I don't have airbags anyways. I have a full roll cage.
