3rd Brake Light Replacement on a 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ionvoid, Apr 24, 2022.
  1. Apr 24, 2022 at 4:55 PM
    Ionvoid
    Ionvoid [OP] SharkyTheTaco
    Maxim
    Lafayette Colorado
    2017 TRD Off-road DCSB
    2.5 King shocks, Dirt KIng UCA's, snorkel, TRD 17" Bronze Wheels, 285/70/17 KO2s, lightbar, bed rack, rooftop tent, 5 subwoofers on 2800 watts RMS, upgraded tweeters and door speakers.
    Hey everyone, I recently purchased a new 3rd brake light for my 2017 Tacoma. I am replacing the old one because of leaking issues. The dealership quoted me 700$ for a replacement done by them, so I opted to try it out myself. I have spent about 5 hours now trying to get one nut to tighten on a bolt that secures the brake light in place. I cannot seem to get the nut to tighten or loosen and it seems to be stuck on the bolt. This is extremely frustrating due to not being able to see what I am working on and how hard it is to fish a socket wrench up there. Does anyone have any tips to how I could either get the nut off the bolt, or get it tightened somehow?
  2. Apr 24, 2022 at 4:56 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    There is a recall for the 3rd brake light, should be free of charge at the dealer
  3. Apr 24, 2022 at 5:04 PM
    Ionvoid
    Maxim
    Lafayette Colorado
    I went in for it already, they said my factory break light was damaged and to replace it was 700$
  4. Apr 24, 2022 at 5:06 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    How far did you drop the headliner?
  5. Apr 24, 2022 at 5:09 PM
    Ionvoid
    Maxim
    Lafayette Colorado
    Not very far, just got it enough to get my socket in. I was worried about dropping it further because of the airbags in the rear.
  6. Apr 24, 2022 at 5:14 PM
    HisDad
    Texas at last
    Dropping further would probably make the job easier, but i've neverdone it, so I can't give you any advice on how to get it down.
    My general practice is to disconnect the negative battery terminal when getting anywhere near airbags.
    It sounds like you may have cross threaded the nut though.
  7. Apr 24, 2022 at 5:17 PM
    HisDad
    Texas at last
  8. Apr 24, 2022 at 5:19 PM
    HisDad
    Texas at last
  9. Apr 24, 2022 at 5:24 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    ^^^ not true. another thread of same topic details the same issue and the LSC. I in fact experienced the same as OP. Total f job and money grab by Mother Ship.
    experienced the very same. Lamp was broken obviously by oem installation - cracked on the passenger side nut/bolt location - verified by dealer. No leak so not fixable at dealer cost via LSC - dealer option was as you note. F that $700 for a repair that has a material cost of $80.00. I tried to purchase the trim part from the dealer and they said no - as it is only to be sold as part of the LSC. Their Solution was for me to re-install the broken part - have them reinspect, then again deny the fix and pay them to install a new brake light (at the cost of as stated for parts and labor) and then they would sell and install the trim bezel at an additional expensive fee. F Toyota! Remove the coat hanger brackets, loosen the c pillars, remove the plastic lense/head liner light - pull the headliner down (works easier if you open back sliding window and have someone gently push the head liner down). Then you can get to the nut (10mm deep-socket) and remove. Pull light and clean surface with rubbing alcohol. Install new light and replace loosened parts.
    HisDad likes this.
  10. Apr 24, 2022 at 6:20 PM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
  11. Jun 4, 2022 at 10:47 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    True here. They replaced my headliner, all new carpet and put me in a rental for months (parts shortage) until parts came in and it was fixed. Cost - ZERO under recall. :):):)
    shakerhood and HisDad like this.
  12. Jun 4, 2022 at 1:51 PM
    GoldenBrew
    Golden, Colorado
    only because you qualified (aka water leakage) for the LRC. If you don't have a leak or signs of a leak you don't qualify. So if you did not have a leak and they did the LRC they only did it for the $ they get from the Mother Ship. No dealer here willing to do that. Glad you got it done regardless of the situation. :thumbsup:
    2016Tacoman[QUOTED] likes this.
  13. Jun 6, 2022 at 8:44 AM
    themcnertney
    themcnertney Well-Known Member
    Dan
    Akron, OH
    2016 Toyota Tacoma, Off Road, 6 speed manual
