3rd Brake Light Outer Cover 3M Adhesive Seal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RingTacoma91, Apr 10, 2024.
  1. Apr 10, 2024 at 5:14 PM
    RingTacoma91
    RingTacoma91 [OP] Ring
    Robert
    Concord, CA
    2019 Tacoma Trd Pro
    Alpha Rex Pro Tail Lights, Smoked out 3rd Brake Light, 265/75 tires (Wildpeak A4W), rockers, Stinger Heigh10 stereo upgrade, OTT tune, BakFlip Tonneau Cover.
    So, I know this has been discussed ad-nauseum but I can't find any thread specifically addressing the OUTER cover of the 3rd brake light.
    I just replaced with the smoked out 3rd Brake Light from @tacomalifestyle but it doesn't come with the templated double-sided 3M seal for the outer cover. Instead they advise to use 3m tape, but the problem is turning the corner you will lose seal because it doesn't bend that sharply.
    I called my local Toyota dealership in Walnut Creek, CA and they said the only way to get that templated 3m seal for the outer cover is to purchase a new 3rd brake light assembly from Toyota ($$$). Mine was already replaced with the recall before I purchased it.
    The gasket seal was not perfectly centered on the new brake light I installed but it still sucked down/sealed down well when I tightened it on, over the hole so I think it is waterproofed OK but I want the added protection of a perfect seal for the outer cover without jerry-rigging 3M tape, or making complex cuts of tape to get a good seal.
    What are my options on this?
    See pic for reference.
    orangeblue likes this.
  2. Apr 11, 2024 at 4:33 AM
    orangeblue
    orangeblue Active Member
    19 Tacoma TRD 4WD
    Interested in this as well, I have the same brake light waiting to be installed, but Ive been putting it off because I heard it was a nightmare to install! I read somewhere that you can use Permatex RTV but that seems messy. Is your new light leaking?
    RingTacoma91[OP] likes this.
  3. Apr 11, 2024 at 6:05 AM
    akimmel
    akimmel Well-Known Member
    Alex
    2019 TRD OR DCSB 6MT
    What about window weld or betalink like bmw uses for body kit parts?
  4. Apr 11, 2024 at 6:51 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    This seems to be the same as OEM. Wouldn't need the bezel the kit comes with which really only covers up the sealant they use around the edge.
    https://www.ebay.com/itm/274949051845?itmmeta=01HV6PQ0TPSHSEBHBE3DWXHMVW&itmprp=enc%3AAQAJAAAA0FewavgF0%2FNJxnLS6yLzS0+pUHlx29%2F2c4h5T%2Fdq1tVhTDMl50MHDiEBRFM+vwf8WcdjQrwPQHbBBg4787X+oR9s6zrXoDz2BxQhHaW0OSXCgUfQbl0NXL3Nw0dzuRiKWWKhBVDbSE72VKNAy0QUtBC7YhKy9UpBDUxLvX8vYGrVBANdIlEq9bkuqXnaXlKGGy1daFDIy2YJySXB0lsOFlG6S2MXwHfFufu3bD44CFcXCpK%2F8IMa2OP9D2USyuCwKttY1zlopN4uK3sd0lZA0e0%3D%7Ctkp%3ABk9SR7iN3NbZYw
  5. Apr 11, 2024 at 8:45 AM
    RingTacoma91
    Robert
    Concord, CA
    2019 Tacoma Trd Pro
  6. Apr 11, 2024 at 8:46 AM
    RingTacoma91
    Robert
    Concord, CA
    2019 Tacoma Trd Pro
    I'm sure I could use a liquid sealant but I'd rather have the templated one, or a 1/4" think dual sided 3m pad that I can cut a template from but I can't find something like that. Perhaps because I don't know what it is called technically so I may be searching for the wrong keywords.
  7. Apr 11, 2024 at 8:48 AM
    RingTacoma91
    Robert
    Concord, CA
    2019 Tacoma Trd Pro
    From what I can tell, the seal around the actual light sat well outside the hole and sealed the light down well, but I'm not convinced 100%
    Sure would be great for @tacomalifestyle to include a templated 3M double sided gasket for the outer cover. I didn't anticipate this problem, and their instructional video says to use 3M tape but that doesn't seem feasible with the bends.
  8. Apr 11, 2024 at 9:57 AM
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
  9. Apr 11, 2024 at 10:56 AM
    TacoSupremo19
    NJ
    The outer cover is just a bezel. It's for hiding the adhesive they use on the original brake light. The new brake light comes with new, thicker foam sealant. They don't use a bezel on the lights after 2019. I actually bought a new light with the new part # and could see the difference in the foam.
  10. Apr 11, 2024 at 11:08 AM
    TacoSupremo19
    NJ
    No foam holds that piece on. The instructions say to squeeze just enough sealant on so is squeezes out out like 3mm from under the light. The you push the bezel in place and the sealant holds it in place. Toyota's instruction pdf is somewhere around here
  11. Apr 11, 2024 at 3:51 PM
    RingTacoma91
    Robert
    Concord, CA
    2019 Tacoma Trd Pro
    do you know which sealant I need to use?
  12. Apr 11, 2024 at 4:46 PM
    TacoSupremo19
    NJ
    I do apologize. I gave you bad information. That ring DOES have a an adhesive backing. I found the caimpaign pdf and included it here for you. Looks like it's a thin, double-sided tape
  13. Apr 12, 2024 at 4:02 PM
    RingTacoma91
    Robert
    Concord, CA
    2019 Tacoma Trd Pro
    they use a trim ring. This is what I’m looking for.
  14. Apr 13, 2024 at 3:24 AM
    TacoSupremo19
    NJ
  15. Apr 13, 2024 at 3:32 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  16. Apr 13, 2024 at 4:09 AM
    TacoSupremo19
    NJ
  17. Apr 13, 2024 at 4:19 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Would using thin 3M double sided tape work? Just put a small strip on the sides and the top and bottom?
    If the light is already sealed from the elements, is the trim ring just aesthetic?
  18. Apr 13, 2024 at 7:05 AM
    TacoSupremo19
    NJ
    Whatever tape you use it would have to be thin so the trim ring is flush with the light. Couldn't be thick like that gasket you showed.
    The trim ring is apart of Toyota"s "fix" for the leaking light. If the light is deemed structurally sound after inspection, they put sealant around the circumference of the light the apply the trim ring which helps push the sealant into the crevices and hides the sealant around the light.
  19. Apr 13, 2024 at 7:08 PM
    RingTacoma91
    Robert
    Concord, CA
    2019 Tacoma Trd Pro
    from that I understand, you are correct. I will use the sealant mentioned in the graphic I posted, then use 3m tape to put the outer ring on. I order a plastic head caulking tool to remove excess sealant when applying around the light and will painter tape to avoid mess.
  20. Apr 14, 2024 at 10:11 PM
    hotrod 15
    hotrod 15 Well-Known Member
    Robert
    2017 Toyota Tacoma trd pro
    I re-installed the outer ring around my mirimoto 3rd brake light, I used 3M, and it has sealed very well, but I did take my time and clean all of the remnants of the old sticky tape off of the paint
