3rd brake light/ bed light help.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eight, Apr 17, 2022.
  1. Apr 17, 2022 at 2:51 PM
    eight
    eight [OP] Well-Known Member
    2019 silver Tacoma TRD sport
    Hey and thanks in advance for any help. I have a 2019 Tacoma with a camper on it. My issue/ question is that the white lights for the bed on the 3rd brake light don’t turn on. I thought the whole light was just disconnected, but my son asked me why a red light turns on sometime. So the red brake works still, but the white light for the bed doesn’t work. I’m sure that it was done to keep an mirroring, reflection, or blinding issue from happening. I want to get it working because the camper light inside doesn’t work, and I figure the bed light would be nice to have. Does anyone know if there is a cable that usually gets cut when installing a camper shell. I had it looked at a dealership when I had other work done on it, and they said it had some relays installed and wouldn’t mess with it since its wasn’t a Toyota product. Thanks again for reading this far
  2. Apr 17, 2022 at 2:58 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Do 3rd gen tacomas have a cargo lamp switch on the dash? like this? [​IMG]
    eight[OP] and Skydvrr like this.
  3. Apr 17, 2022 at 3:09 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    My 3rd Gen has this switch. It came with the factory bedlights. OP; this will also turn on the white lights that are on the 3rd brake light (when the door is opened or if you manually turn it on).
    If the white light isn't coming on, check the bulbs. The may be burnt out?
    eight[OP] likes this.
  4. Apr 17, 2022 at 3:19 PM
    eight
    Yeah mine has that switch, I’ll check the bulbs when I get a chance. For some reason I thought they were LEDs
  5. Apr 17, 2022 at 4:39 PM
    Clappie
    Clappie Member
    Sacramento
    2019 Cement TRD Sport AT
    They are leds.
  6. Apr 17, 2022 at 5:26 PM
    caribe makaira
    Caribbean, Puerto Rico
    Could be they removed the fuse to the Cargo Lamp circuit...
  7. Apr 17, 2022 at 5:48 PM
    eight
    Thanks, I’ll look at the fuses tomorrow when the suns out.
  8. Apr 18, 2022 at 6:55 AM
    Silvertip13
    Silvertip13 Member
    2022 Tacoma TRD Sport
    Does anyone know the routing of the 3rd brake/cargo light harness inside the cab? As does it run down the rear passenger c pillar or out the center of the head liner? I’m adding a canopy and want to disconnect it without pulling the headliner.
    This may be where op’s harness could be modified if it’s not the fuse or lamp
  9. Apr 18, 2022 at 7:10 AM
    caribe makaira
    Rear middle down to rear DRIVER's side c pillar.
  10. Apr 18, 2022 at 2:51 PM
    eight
    Hey thanks for the help. It was the fuse that had blown out. I now have light to see what I’m doing at night!
    soundman98 likes this.
