3rd Brake Light Bar Recommendations for Bed Racks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vintage_carrot, Aug 12, 2020.
  1. Aug 12, 2020 at 1:52 PM
    vintage_carrot
    vintage_carrot [OP] Well-Known Member
    2020 SR5 DBL Long Bed
    Hey all,
    I just installed my bed racks but they obstruct the 3rd brake light on the cab. I wanted to get a light bar of some sort that I could attatch to the back of my racks and wire it up to either the tail light or to the trailer 4-pin connectors. I'm a dingus so I'd prefer plug n' play if possible but I could juevos up and just do some splicing and dicing. Would be nice if it complied with any DOT guidelines for a 3rd brake light.
    Any recommendations on the lights and a plug n play kit for it?
    Thanks!
  2. Aug 12, 2020 at 4:48 PM
    Ralf
    Ralf Summit Expedition Trucks Ltd.
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    ARB Summit Bar Safari Snorkel
    For starters, which brand bed rack did you go with? I've got some idea's that may help..
  3. Aug 12, 2020 at 4:51 PM
    Tacospike
    Two Trucks
    @Frsh2df
    You got a sweet set up. Some pics?
    Sorry to put you on the spot
    :anonymous:
    Frsh2df likes this.
  4. Aug 12, 2020 at 4:57 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    A little pricey, but these are pretty slick looking and would easily attach to a rack. Designed to use as a 3rd brake light, integrated reverse light and has a cargo light. Strictly speaking, not an SAE compliant light though.
    https://www.rigidindustries.com/chase-chase.html
    Tacospike likes this.
  5. Aug 12, 2020 at 5:07 PM
    BabyBells
    BabyBells New Member
    Stephanie
    2018 Tacoma Double Cab SR 4 cyl.
    For now: Carhartt seat covers, Meso's Total Tail Stage 1
  6. Aug 12, 2020 at 5:08 PM
    Ralf
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    Oh dam! These are slick! But yea, I can imagine pricey. Curious as to what bed rack OP purchased..
    crashnburn80[QUOTED] likes this.
  7. Aug 12, 2020 at 5:26 PM
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    Not at all man, Ill play. :fistbump:
    Here is my set up. It’s definitely not plug and play, but I just used posi taps and tapped into the brake light.
    The lights were from Amazon , I will have to look up which brand but they are definitely plenty bright. They came in like a pack of 6 or 8. I just used the 4.
    Mine only come on when the brakes are applied, I didn’t want them to be as running lights.
    30E3E889-937E-433C-8AA9-C4AF2DE0ED87.jpg 2FAD2B5B-8DBD-4A08-BDB3-D8A75FF31C3E.jpg F6465F90-5D3C-473C-8F54-E19E1F474DB9.jpg F65984DF-5A4C-448A-8268-ED48C58A4E25.jpg 73AE4F0B-6055-479F-9543-23D7824553D1.jpg
  8. Aug 12, 2020 at 5:29 PM
    Tacospike
    Two Trucks
    Damn those tail lights are sweet
    FishnTx and Frsh2df[QUOTED] like this.
  9. Aug 12, 2020 at 5:31 PM
    Frsh2df
    Thanks man I appreciate it.
    I almost had to use the pic with my old pro tails, but forgot I took a lot of shots with the Meso’s when I got them :D
    Tacospike[QUOTED] likes this.
  10. Aug 12, 2020 at 5:39 PM
    vintage_carrot
    I've got KB Voodoo Alu-Max racks at 14 inches rolling on my baby!
  11. Aug 12, 2020 at 5:40 PM
    vintage_carrot
    We basically have the same set up! These are pretty sick! I'll keep these in mind while I look for some plug and plays. Thanks!
    Edit: How did you run the cables from the rear bracket down the arm and into the tail light while staying hidden?
    Frsh2df[QUOTED] likes this.
  12. Aug 12, 2020 at 5:41 PM
    Frsh2df
    That’s the rack I’m running in the pics above but in 10”.
  13. Aug 12, 2020 at 5:43 PM
    Ralf
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    I would totally run the setup @Frsh2df has on his truck if I were you! That is cleaaannnnn
    Frsh2df likes this.
  14. Aug 12, 2020 at 5:45 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Frsh2df likes this.
  15. Aug 12, 2020 at 5:49 PM
    Frsh2df
    If you zoom in on the drivers rear arm of the rack you can kinda see the wire exposed. I have a Bakflip tonneau cover , and I ran the wires in the channel.
    From there directly down and zip tied them to my bed stiffeners and down through the bed. Then I removed the tail lights and routed them up and behind the light to tap for power.
    I don’t have all those pics , but can get them for you in the next day or so if you want.
  16. Aug 12, 2020 at 5:51 PM
    Frsh2df
    Only if they were available, they would definitely be sweet.
    Skydvrr[QUOTED] likes this.
  17. Aug 12, 2020 at 5:52 PM
    Frsh2df
    Thanks I appreciate it :cheers:
  18. Aug 12, 2020 at 5:53 PM
    vintage_carrot
    Oh man! Nah, I wouldn’t go out of your way for the photos! I think this might be the way I go because it’s so clean!
  19. Aug 12, 2020 at 5:54 PM
    Frsh2df
    Also forgot to add. I used a waterproof connector for the lights and it’s tucked away in that drivers rear arm.
    So when I ever need to remove the rack I can just unplug the lights and take everything off all at once.
  20. Aug 12, 2020 at 5:55 PM
    Frsh2df
    Its really no problem. Depending on work it might not be until this weekend though.
