3M headlight restoration kit, before and after with PICS..
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpeedoJosh, Feb 15, 2013.
  1. Feb 15, 2013 at 11:04 AM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    So the headlights on my 98 weren't much help at night anymore. They had the classic haze over them, so I went and got the 3M restoration it from the auto store. Found it at Autozone for about $22. They have a few different kits, this is the one that works with a drill, and comes with the green tape to mask off areas surrounding the lights to protect them. (Others come with no tape, and there is another one that comes with tape and protectant.) Directions were pretty straight forward and easy to follow.
    Pics:
    Driver side (I tested out the sanding pad for a couple seconds yesterday, thats why this one is a little scratched already.)
    Passenger side
    All taped off and ready for the kit.
    Driver side after last sand, before the polish disc
    Passenger side after last sand, before the polish
    Driver side all finished
    Passenger side all finished
    Kit worked well. Pretty easy. I didn't use all the pads, I'm sure it would of got a little more clear. Be careful of those tits that poke up on the headlights, as they will eat up the discs, especially the foam polish one. Mine is shredded.
    Link to kit I purchased.
    http://3mcollision.com/3m-lens-renewal-kit-39014.html
  2. Feb 15, 2013 at 11:27 AM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Used the same kit on my 02 and it work great. Save the polishing foam pad and rubbing compound, it'll need touch ups down the road. Or just hit them with a coat of clear to lock in the clean plastic. Good job btw
  3. Feb 15, 2013 at 11:29 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Good work. Now throw in some Silverstar Ultras and you're good to go.
  4. Feb 15, 2013 at 11:32 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    did mine using the same method...
    cleaned up just fine.
    however... near 6 months... they began to yellow (cloud) again.
    I recommend using some sort of UV protection
    on the surface of those to slow down that future degradation.
    Some waxes and the like have UV deterrents in them.
    I haven't tried any yet...
    because after cleaning mine the 2nd time,
    I removed them in favor of running
    the cheap ebay clear/black headlight housings.
  5. Feb 15, 2013 at 2:53 PM
    Pauhana
    Pauhana Well-Known Member
    Mark
    Irvine, CA
    04 SC PreRunner
    RECARO Trend Seats TRD SC URD Fuel Upgrades
    What if you were to add that clear film to the headlights. I believe they call it "clear bra" by 3M? Its the one that is also used on the front end of vehicles to protect it from all of the rock chips. Would this work?
  6. Feb 15, 2013 at 2:56 PM
    wareagle1
    wareagle1 Well-Known Member
    Brad
    Fayetteville, TN
    07 Tundra DC 5.7
    notta
    I use a little cleaner wax on mine about once a month. It doesn't take but a minute to do and keeps the plastic free from oxidation and build-up. When I sold my '05 they still looked new.
  7. Feb 15, 2013 at 3:28 PM
    SpeedoJosh
    Florida
    Bought some Mcgurie's UV protectant and put it on. So I'll see how they hold up now.
  8. Feb 15, 2013 at 4:03 PM
    hnmorris4
    hnmorris4 Well-Known Member
    West Virginia
    2019 Cavarly Blue SR5 V6 DCSB 4x4
    Toyota OEM Apple CarPlay stereo upgrade
    Keep in mind you can replace the entire assembly for both left and right side for about $60 on Ebay. That was the easiest way IMO to fix the dingy lights, inside and out.
  9. Feb 15, 2013 at 4:34 PM
    Madjik_Man
    Colorado Front Range
    This is my experience.... mine lasted 8 months tops. I restored them a second time and have been semi-frequently spraying it with a clear lens coat (made for restored headlights). So far I'm about 6 months in and they still look brand new.
  10. Feb 15, 2013 at 4:48 PM
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    Given your location (Florida), you might have some good qualitative information for the rest of us.
  11. Feb 15, 2013 at 7:31 PM
    adower
    adower Well-Known Member
    Just make sure to buy something with UV protectant and hit the head lights up every now and then. It sure beats buying OEM new lights. Plus if you dont let them get bad it only takes a few mins to do it.
  12. Mar 30, 2014 at 8:01 PM
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    Ok sorry for the necro post but here's a before and after of a 98' IS 250
    Well worth the cost and effort.
  13. Mar 31, 2014 at 6:00 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Did mine a couple years ago with the 3M kit. They are yellow again and I knew they would be. My 3M kit instructions said to immediately apply the protectant and keep it on there. I decided to ignore that little tip. Meguiar's power ball had no effect a few weeks ago. For the fight and hassle of my own fault I went thru to clear them with the 3M kit, I will purchase new ones now when needed. The kit works just fine, I tried to speed the process a bit. Make sure you have plenty of water flowing across the plastic as you sand. Don't rush. Check your pads often.
