3M Adhesive remover
Discussion in 'Detailing' started by dgc1, Jun 24, 2017.
  1. Jun 24, 2017 at 5:09 AM
    dgc1
    dgc1 [OP] Active Member
    Is it safe to use this to remove bugs from your truck? I did not know if it would hurt my paint.
  2. Jun 24, 2017 at 5:28 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    NMTrailRider likes this.
  3. Jun 24, 2017 at 5:35 AM
    Cazzwell
    Cazzwell The Circuit Rider Signman
    2018 Silver Sky DCSB TRD Sport
    Stock.
    It should be fine as long as its the citrus based and not acetone or another harsh solvent.
    I use a product called orange peel to get rid of adhesives, tar, and bugs.
    http://www.uscutter.com/Orange-Peel-Adhesive-Remover
    Just remember to wash the truck when you're done.
  4. Jun 26, 2017 at 7:47 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I wouldn't use it. Get yourself a paint safe bug sponge and presoak the bugs when you wash to get them off. You can also apply a sealer or wax to the front of the truck so they don't stick on so much.
    I would avoid using any harsh chemical. They can be paint safe when washed off adequately and with proper soaps but even then not worth the risk.
    Use a good sealer or wax and wash bugs off sooner rather than later and it will make life easier when its time to wash them off.
    You can also get them off with a clay bar. Just wash what you can off first.
