37s on 6" lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06cclbtaco, Nov 15, 2016.
  1. Nov 15, 2016 at 7:34 PM
    06cclbtaco
    06cclbtaco [OP] New Member
    I've got a 2006 cclb prerunner and I plan to get the RC 6" lift. I need to know if 37x13.50s are possible to run. I want the biggest tire possible so if 37s won't work, 36s?
  2. Nov 15, 2016 at 7:35 PM
    06cclbtaco
    if anyone has pics of 37s or 36s on 6" of lift they would be greatly appreciated
  3. Nov 15, 2016 at 7:47 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  4. Nov 15, 2016 at 7:48 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Coilovers
  5. Nov 15, 2016 at 7:53 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Jesus...... hope you are prepared for like 10mpg
    Midnighttaco08 and PROseur like this.
  6. Nov 15, 2016 at 7:54 PM
    Clearwater Bill
    Billy
    Largo Florida
    Were DCLBs called CCLB in the old days? I thought CC was a GM/Nissan term..........
    OP, are you doing an LSx conversion? 'cause you'll need real grunt to roll that rubber.
  7. Nov 15, 2016 at 7:55 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Dont forget Dodge, but nah they have always been DCLB's. :D
  8. Nov 15, 2016 at 10:34 PM
    Pigpen
    Northwest Montana
    My buddy has a 6" DB lift and 35s. He still had to do the cab mount chop and cut some plastic/ remove mud flaps. You'll have a lot of modding to do, if you want 37s. Don't forget to regear!
  9. Nov 15, 2016 at 10:36 PM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    Why do you want to run 37s???
    Sounds like a lot of work and unnecessary wear and tear on drive components when 35s are more than enough for 6" lift.
    Maybe even 33s:anonymous:
    Rieslingguy likes this.
  10. Nov 15, 2016 at 10:40 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    Oh.... and welcome to TW!!!
    :cheers:
    :worthless:
  11. Nov 16, 2016 at 1:40 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
  12. Nov 26, 2016 at 8:25 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    This guy is spot on.:thumbsup: 37's are possible but you'll be making major body mods. Including completely removing & relocating the cab mount.......tubbing the inner fenders. And I don't think a stock front bumper is even possible. It'll have to some type of high clearance bumper.
  13. Nov 26, 2016 at 8:27 AM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
  14. Nov 27, 2016 at 10:27 AM
    sarsaparilla
    sarsaparilla Well-Known Member
    Tyler
    Austin, TX
    2014 DCSB 4x4 Super White II - Texas Edition
    Radio Operator: KG5SAI
    I dont know about 37s, but i do know that there is a fair bit of rubbing with 35s and a 6" kit. I have the front jacked and still get a bit of rub under certain circumstances (when wheelin'). I get the most rubbing in the rear. I had to remove the flairs, and they still rub a decent amount on the front of the wheel wells when tucking.
    Shwaa likes this.
  15. Nov 27, 2016 at 11:27 AM
    qfast817
    qfast817 Well-Known Member
    Q
    Fort Worth Texas
    Tacoma
    On my taco I have the rc 6in db and the 33.5 on it rub like crazy still. I don't know how y'all would fit 35-37
  16. Nov 27, 2016 at 12:55 PM
    RigginsTaco
    RigginsTaco Well-Known Member
    Andreas
    Boring taco with mods
    Stuff...
    Woah a thread where TW isn't digging into someone's soul for wanting a lift above 4" super surprised but I'll leave this here to boil some peoples blood
    qfast817, TegoTaco and Jareds Toyota like this.
