35x10.50 17 Tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cribb, Dec 24, 2022.
  1. Dec 24, 2022 at 8:37 AM
    Cribb
    Cribb [OP] Once it hits your lips, it’s so good.
    South Carolina
    1996 Tacoma 2.7 XtraCab 4x4 5spd
    2” suspension lift, 2” body lift, 33” tires, K&N intake, LCE header, Alpine head unit, Kicker KS door and pillar speakers, 10” Rockville slim powered subwoofer, red/clear taillights, clear corners, clear turn signals, LED headlights, LED tag bulbs, LED reverse bulbs, LED dome lamp, Husky floor liners
    Hey Y’all,
    I see lots of newer Tacos running 35x10.50 17 Kenda Klever tires. Anyone running this size on a 1st gen and if so, what lift? I have a 2” spacer lift with 2” BL for 4” total and am really wanting the skinny look. Currently running 33x12.50 15 on stock wheels. I cannot find a 1st gen with the 35x10.50 17 except for this one below which was a random FB image from the inter web. Hoping to see something… :fingerscrossed:
    nv529 and Tdoo like this.
  2. Dec 24, 2022 at 8:47 AM
    02hilux
    Planet: EARTH
  3. Dec 24, 2022 at 8:50 AM
    Cribb
    South Carolina
    Forgot to add the one pic I found…
  4. Dec 24, 2022 at 9:46 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    People with IFS just don't understand :jerkoff:
    02hilux[QUOTED] likes this.
  5. Dec 25, 2022 at 5:00 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    No lift is going to have you cutting a lot more, I would think... Since your travel sends you more into the wheel well...
    I run those exact tires OP. 3" lift, 2" wheel spacer on 3rd gen wheels (less backspacing). They rub frame at full turn.
    Here are some random pics I had on my phone (unfortunately they're more of the rear which are x12.50):
  6. Dec 25, 2022 at 7:54 AM
    Cribb
    South Carolina
    Thanks for the reply and pics. From the looks of that front, I may want to stay with 33’s. Looks like a tight fit with the 35’s. I do have 4” of lift but I also want a little room in the wheel well for travel. Decisions…decisions…
  7. Dec 25, 2022 at 12:11 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    With 35s you'll be cutting no matter what, but it's rare I scrape. Got a good 3-4" of up travel there
    Cribb[QUOTED][OP] and Wulf like this.
  8. Dec 25, 2022 at 1:00 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Unless you have a drop bracket lift you'll have to do the same amount of tubbing to clear 35s whether you're at 0-4" of lift. Lift doesn't change the stock suspension geometry. I had to cut the firewall back to about the lower door hinges
    Cribb[OP] and theesotericone like this.
  9. Dec 25, 2022 at 1:06 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Sounds about right.
    Cribb[OP] and Wulf[QUOTED] like this.
  10. Dec 25, 2022 at 1:08 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You can measure your existing gaps now. If the gaps are 1" or more, then you can fit a 35" tire of the same width.
    Normally you'd have to cut away a lot of the firewall, but your 2" body lift will reduce that a bit:
  11. Dec 25, 2022 at 5:10 PM
    Cribb
    South Carolina
    I’ll def measure but leaning towards sticking with 33’s now :(
  12. Dec 28, 2022 at 8:26 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    58ADAFE3-77FB-47F1-A847-639BA3B15EA8.jpg 238548DA-D3DA-4F82-B421-19DAB3DE1205.jpg I have the 35x10.50 kendas. Ome 882s on 5100s on second perch up front. Stock rears with cheap add a leaf and drop shackles out back. 1” wheel spacers and 5th gen 4rnr wheels. Trimmed 2” out of the wheel arches and no tubbing of the firewall. Just trimmed a bit at the bottom of the firewall behind the tires where it hung down.
    Cribb[OP] likes this.
  13. Dec 29, 2022 at 1:57 AM
    Cribb
    South Carolina
    Exactly what I was looking for. Thank you!
  14. Dec 29, 2022 at 2:14 AM
    d33pt
    d33pt Well-Known Member
    What gear ratios are you running with the 35's?
  15. Dec 29, 2022 at 6:17 AM
    vern650
    brandon
    hyrum, ut
    im running 5.29s. 2.7l 5 spd.
  16. Dec 29, 2022 at 7:09 AM
    v5ensx
    v5ensx CARB legal is not CALI legal
    No need to cut the firewall if it's a pavement or to get driven on fire service road.
  17. Apr 30, 2024 at 10:05 PM
    Tdoo
    Tdoo Member
    Terry
    04 taco double cab
    3" lift, rear e locker, sliders
    I run them kendas with radflo 2.5s up front and Chevy 63’s in the back. 1.5” spacers. 5EC24466-8A65-4D4D-9AA8-180A288EAC3D.jpg
    PathFinder1776 likes this.
  18. Apr 30, 2024 at 10:07 PM
    Tdoo
    Tdoo Member
    Terry
    04 taco double cab
  19. May 1, 2024 at 8:07 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    39.5's fit with a little trimming :notsure:
