34x10.5r17 KO2s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SoonerTaco19, Feb 21, 2020.
  1. Feb 21, 2020 at 10:35 AM
    SoonerTaco19
    SoonerTaco19 [OP] New Member
    2019 white Tacoma TRD Off-road
    I'm considering the OME 2" lift (I understand it's actually closer to a 3" up front) and the above tires (33.5" x 10.6" actual measurements per BFG) mounted on the 4Runner TRD Pro wheels. Anyone have any experience with this setup? If so, CMC or new UCAs required?
  2. Feb 21, 2020 at 12:40 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    A CMC will be required, along with other trimming and manipulating. I just did a quick search of '34" tires' and there's a fair bit of reading material. I'm no expert in the matter, but it seems like 34" is kind of no-man's land. Most go with 33" and then jump to 35"... Regardless, lifting is not the key to larger tires. Tire width and trimming are the factors.
    https://www.tacomaworld.com/search/10280574/?q=34"+tires&t=post&o=date&c[title_only]=1
