34' tire on a 3rd Gen Tacoma?
Discussion in 'Wheels & Tires' started by alexabarca, Oct 23, 2018.
34' tire on a 3rd Gen Tacoma with a 3 inch lift?
  1. It can be done
    79 vote(s)
    92.9%
  2. Impossible
    6 vote(s)
    7.1%
Multiple votes are allowed.
  1. Oct 23, 2018 at 5:31 PM
    alexabarca
    alexabarca [OP] New Member
    2017 Tacoma TRD Sport 4x4
    Hi everyone,
    Inspired by a dude's Tacoma build which had 34' tires on the original TRD Sport wheels (17') on a 3/1 inch lift with 1.25 wheel spacers I went ahead and bought 285/75/17 All-Terrain tires for my truck before deciding which lift to go with, which up until now seems like a very stupid decision. As I did my research for the lift kit and called many off-road parts stores and talked to many "experts" it almost seems as if they get upset I got such a big tire, and that A LOT of cutting will have to be done and that the 3 inch lift will definitely not be enough, has anyone here put 34' tires on a 3rd gen? if so with what setup? PLEASE HELP! btw, I don't plan on doing any hardcore off-roading, it'll be on the freeways most of the time (unfortunately) and I preferably I would like to spend less than $800 on the lift kit alone, thanks!
  2. Oct 23, 2018 at 7:18 PM
    Ravnikar610
    Ravnikar610 Well-Known Member
    Minnesota
    2016 OR DCSB
    Firstly, you will have to cut and mend some. It is necessary to do an aggressive CMC (cab mount chop) and hammer the pinch weld on the cab side of the wheel well flat. A heat gun and gloves can move most of the plastic out of the way. Cutting the plastic on the cab side of the fender is best. A new alignment with maxed out caster is also needed. If you buy after market upper control arms you will be able to push caster even farther forward.
    You should NOT buy a lift in that price range. Minimum go Bilstein 6112's, UCA of your choice, and add a leaf in the rear. Even if your not off road, don't get spacers or anything above 3" lift.
    You can clear enough on STOCK suspension if you work hard enough. I ran 285/75/16s with no rub on stock suspension for a long time.
    riggityj, Blackntosh and xxTacocaTxx like this.
  3. Oct 23, 2018 at 7:24 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Damn... 34 foot tires on 17 foot rims... Wow. I wanna see that :eek:
    4x4Gaspar, Amchuge, CCWTaco and 10 others like this.
  4. Oct 23, 2018 at 7:38 PM
    -40 Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
    You opened a can of worms buying those 34’s. Lots of :sawzall:
    Plenty of builds on TW with 35” tires. You should have no problem finding inspiration. :spending:
  5. Oct 24, 2018 at 11:48 AM
    dualstroke
    dualstroke Well-Known Member
    2017 OR AC
    I'll stick with my pizza cutting 33's. No cutting.
    xxTacocaTxx likes this.
  6. Oct 24, 2018 at 8:41 PM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    34” tire is basically a 285/75/17 tire. I know a guy running this tire on his 3rd gen and all is needed is a body mount chop. He has aftermarket front and rear bumpers. So if you are stock bumpers you will have to most like move the front fender liner forward.
    I will be running this size on my 2015 second gen.
  7. Oct 24, 2018 at 8:54 PM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Exactly my thoughts lol
    Blackntosh likes this.
  8. Oct 24, 2018 at 8:57 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    What’s old is new again.
  9. Oct 24, 2018 at 8:57 PM
    TS7xTaco
    TS7xTaco Warlock
    Charles
    New Mexico
    16 Super White TRD-OR DCSB
    ARB Locked, Nitro 5.29's, Cooper 315's, 16x8 Methods, Cab mount hacked, Firewall Hammered, OME Suspension, Camburg UCA's, ARB OBA, RCI skids and sliders, WarFab Front Bumper, Home Brew Rear Bumper, Orange Virus Tuned, Dobinson Snorkel, Cobra Comms...
    I ran 285s with the OME suspension for 2 years with very minimal rubbing, and I like to think I wheel pretty hard. I've only just recently did a cab mount chop and pinch weld smash because I'm graduating to 35's...
    microsnook likes this.
  10. Oct 26, 2018 at 6:03 AM
    Jeremy4x4
    Jeremy4x4 Zero frucks given
    2017 sr5 4x4 double cab
    3by2 level kit 285 70 17 nitto tires,
    Pics
  11. Oct 26, 2018 at 6:13 AM
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    @Glenn_R
    Thought I remembered you running 34" tires....
  12. Oct 26, 2018 at 6:30 AM
    TS7xTaco
    TS7xTaco Warlock
    Charles
    New Mexico
    Not sure exactly what you want a picture of, so here's a few
    20181026_072540.jpg 20181026_072548.jpg 20181026_072605.jpg 20181026_072557.jpg
    Jeremy4x4[QUOTED] likes this.
  13. Oct 26, 2018 at 7:55 AM
    jerryb1984
    jerryb1984 Well-Known Member
    Jerry
    2018 DCLB TRD OFF ROAD
    16x8 FUEL BEAST 265 75 16 FALKEN WILDPEAK AT3 Tyger step sides 20% tint front to match factory tint bilstein 5100s on third notch PRO grill
    285 75 16 is a 32.8 or so
    285 75 17 is close to 34 so an extra inch. Not the same size.
    Guccitaco, Blackntosh, Bastek and 2 others like this.
  14. Oct 26, 2018 at 8:02 AM
    SCJeffro
    SCJeffro @Voodoo_Blu_Taco
    2021 Voodoo Blue TRD Sport
    I think I saw a post or two about tire sizes when I was using the search feature last week.... ;) at this point every tire size question possible has been asked and answered several times it seems.
  15. Oct 26, 2018 at 8:09 AM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Ive got 285/75/17 on my trd sport. They are on ray10's though and not the stock sport wheels. The wheel offset will play a big role in how much you will have to cut, hammer and what not. I have cut lots of the plastic, hammered the pinch weld, and gotten an alignment with over 5 degrees of caster. I had a CMC done initially, but am going this weekend to get it done much more aggressively. Should be good to go at this point. Im on ADS 2.5" coilovers with clickers along with Camburg UCA's. Id recommend those Camburgs due to how much adjustment they allow.
    https://www.instagram.com/p/BozChRynuQA/?taken-by=bigpermtaco
    You are going to want to find an alignment shop that knows what about lifted trucks with aftermarket parts. I found one with guys who go out on the same trails i do and so they did a fantastic job getting me all lined up.
    Bumble Bee Tuna likes this.
  16. May 26, 2020 at 4:15 PM
    Blackntosh
    Blackntosh "It is better to travel well then to arrive."
    Jeff
    Hollywood
    Tacoma TRD Pro 4x4
    Nitro Gear 5:29's / 4A FOX Midtravel Suspension Kit by Accutune w/2.5" DSC coil-overs, Camburg Kinetik Series Billet UCA's w/Uniball in the front, FOX 2.5" DSC Reseviors in the rear with KING 2.0" AirBump Stops w/ICON RXT Pack. RCI Metal Works Bed-Rack, Sliders, Rear-Recovery and Hardware / FreeSpirit RTT / Nitto Ridge Graplers 265/75/16 on Factory Alloy TRD Wheels.
    Man good info. Would you say Im gonna be alright? I just ordered some 285/75/17's for my tacoma. I had a stage Fox 4A mid travel kit put on my truck by accutune and am waiting for a cab mount chop/hammer pinch while I wait for my wheels. Then I just got a bad feeling that I needed to think more through as most people put a 33". I just wanted something a little more but not 35's as I heard too much cutting would need to be done. I think I'm alright as everything is adjustable...
    MattCowsmasher likes this.
  17. May 26, 2020 at 5:16 PM
    dskakie
    dskakie Well-Known Member
    Dan
    Northern CA
    2016 TRD OR DCSB
    you’ll be fine. Get a good alignment by a shop that knows what they’re doing and you may have to also cut a bit forward of the wheel (all plastic) then good to go. 285/75/17 is the best size
    AmateurTaco1313 and riz_atx like this.
  18. May 26, 2020 at 5:18 PM
    dskakie
    Dan
    Northern CA
    2016 TRD OR DCSB
    also check out this thread, it has a ton of info and pics :thumbsup:
    https://www.tacomaworld.com/threads/285-75-17-perfect-size-on-3rd-gen.588590/
  19. May 26, 2020 at 5:22 PM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    If you have to lift your truck so the tires fit then they DONT fit! In order to make those tires fit full bump, lock to lock there is a ton of cutting involved. Unfortunately most people on this forum don’t understand this and just lift their trucks to clear bigger tires so they look cool on the gram
  20. May 26, 2020 at 5:24 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    If I can make it work on a 2nd gen you should be fine as Sohail said it’s more about the wheel specs. I had to flatten pinch weld, trim about 10lbs of plastic, very aggressive cmc and my caster is at 3.7. I don’t rub at all now just at full lock/compression which is extremely rare.
    riz_atx likes this.
