33x12.50r22 Wheel and Tire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bchaney304, May 31, 2013.
  1. May 31, 2013 at 8:49 PM
    bchaney304
    bchaney304 [OP] New Member
    Brian
    WV
    3" Rough Country lift, 275/60-20 cooper zeon ltz tires, KMC wheels
    Tire fitment with 3" lift and 1" wheel adapters?
    Trying to put a 33x12.50r22 wheel and tire on 2012 tacoma
    the offset of the rim is a +15
    Worried the tire will rub the uca.
    Just wondering if anyone knows if this will fit or not?
  2. May 31, 2013 at 8:50 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    youre going to run 22's? no thanks.
  3. May 31, 2013 at 8:54 PM
    bchaney304
    Brian
    WV
    well even if i go with the rim i have now which is a 20"
    the new tires will still be 12-1/2" wide
    just wondering if it will rub
  4. Jun 1, 2013 at 1:58 AM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    Anything above a 265/70/r17 will rub if you aren't lifted.. not sure how that converts to inches..
    since youre lifted you might get by with it but you may need spacers and a cab mount chop..
    20 or 22 inch rims are wayy too big!
  5. Jun 1, 2013 at 2:03 AM
    escotek1
    escotek1 Member
    RoN
    Colorado
    15' DCSB TRD OFFROAD
    Just my input probably Not the best idea for these trucks to have anything bigger than 17's on the truck...
  6. Jun 1, 2013 at 6:54 AM
    ANT2013taco
    ANT2013taco Well-Known Member
    McAllen Texas
    13 TRD OR 4wd
    Yeah, stay away from anything bigger than 17" especially if you plan any off road excursions. Also, any bigger tires are prohibitively expensive compared to the 16 or 17
