33x12.50r17 has anybody run this set ??
Discussion in 'Wheels & Tires' started by Hellboy0311, Oct 27, 2016.
  1. Oct 27, 2016 at 6:03 AM
    Hellboy0311
    Hellboy0311 [OP] Active Member
    Georgia
    on stock. does it work ? i have a 1.50 leveling kit with 1.25 spacers . i just purchased a new set of netto ridge 33x12.50r17 wonder if it i'll work
  2. Oct 27, 2016 at 6:50 AM
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    You'll have to go to a shop that'll mount them for you. It'll work just have to find a shop that'll do it since the rim isn't in spec to run 12.5" wide.
  3. Oct 27, 2016 at 6:55 AM
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    I'm running 285/70r17 so that's practically a 33hx 11 1/4w
    They are on level 8 trackers which is I believe 4.5" BS.
    HAD to do the CMC and still get some rubbing from the pinch weld at full bump clocked drivers side
    They would've fit stock wheels but wouldn't have cleared the UCA and would've contacted more body mount material
  4. Oct 27, 2016 at 7:01 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Awfully wide tire on a narrow rim, you'll wear out the center of the tire right away.
  5. Oct 27, 2016 at 7:04 AM
    pngo121
    Phi
    Pittsburg, CA
    Not true. Depends on your alignment and air pressure.
  6. Oct 27, 2016 at 7:08 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    To answer your question simply, no. It won't work.
    Nicetacobro likes this.
  7. Oct 27, 2016 at 7:33 AM
    Hellboy0311
    Georgia
    I said F*** it and I just order a new set of 17x9-12 rock stars just so i get the same look on the wheel. i hope that the -12 4.45 and the spacers help with the clearance. any thoughts on that ?
  8. Oct 27, 2016 at 10:00 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You wont rub the UCA anymore but I guarantee you'll rub on your cab mount as well as other places.
  9. Oct 27, 2016 at 10:02 AM
    Hellboy0311
    Georgia
    Good to know, what would you recoment? since I already purchased the wheels?
  10. Oct 27, 2016 at 10:03 AM
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I run that size on a 17x9 wheel with 4.5bs. you'll need to trim the cab mount back and a little bit of plastic. nothing too extensive though
  11. Oct 27, 2016 at 10:04 AM
    Hellboy0311
    Georgia
    I already have a 1.5 leveling kit on it.I dont to compromise the factorie's seting to much
  12. Oct 27, 2016 at 10:28 AM
    Hellboy0311
    Georgia
    the natural. thanks for the honesty, and I understand that my question to you and many in this forum may be stupid. but the solution is simple; just dont answer it. sure, you most be and expert in the subject and don't need to be bother. but like I said. dont answer and that would be cool too. thanks.
  13. Oct 27, 2016 at 10:44 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Pretty much trim whatever it rubs! I'd start with a CMC (cab mount chop). Not too hard. If you're mechanically inclined at all I'd buy a grinder and do the cutting yourself then have someone else weld it on.
    https://www.tacomaworld.com/threads/b-a-m-f-cmc-plates-cab-mount-chop.192527/
    Then I'd beat the pinch weld with a hammer. It's best to get a small sledge and beat outwards. You don't have to lay it completely flat, but enough to not rub
    https://www.tacomaworld.com/threads...lat-with-a-sledge-hammer-lets-discuss.425850/
    That's the major starting point and anything else that rubs at that point will be plastic you can trim.
  14. Oct 27, 2016 at 11:36 AM
    Hellboy0311
    Georgia
    thanks, i just came back from a loca shop here in GA , and you were right , so im putting a 3"
    procom nitro leveling kit on it. the mechanic said that still going to neet some treaming on the inner plastic wheel wel cover
  15. Oct 27, 2016 at 11:51 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah, he's right. The lift will help prevent you from rubbing while driving around town but once you compress the suspension and stuff that tire into the wheel well (hitting a bump while turning, etc) you will likely rub. Everyones truck is different, so I'd wait until you get everything mounted up then see where you rub. Then trim as necessary.
    MTNMAN21 likes this.
  16. Oct 27, 2016 at 12:21 PM
    Hellboy0311
    Georgia
  17. Oct 27, 2016 at 12:29 PM
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    eh? I thought I was just answering your question?
    x2. Lifting it more only helps around town. You still need that wheel to be able to travel up without hitting stuff when you're offroad (or even for certain supermarket entrances).
    If you lift more, then decrease the amount of up travel by extending bump stops, you may rub less. But it will suck compared to just doing some trimming.
  18. Oct 27, 2016 at 12:36 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    While you pros are in here i got a piggy back question, 16x10 -38 offset. Will it fit?
  19. Oct 27, 2016 at 12:37 PM
    ManBeast
    Zach
    Orange Park FL
    265 75 16 toyo at2
  20. Oct 27, 2016 at 12:51 PM
    Hellboy0311
    Georgia
    tx. desrigard that coment. i click on to the red sing you got there.
