33x12.5 on 22x14 with 6 inch lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cam2323, Dec 10, 2019.
  1. Dec 10, 2019 at 8:46 PM
    Cam2323
    Cam2323 [OP] New Member
    Silver 2011 Toyota Tacoma
    6 inch lift
    I have a 2011 Toyota Tacoma with a 6 inch lift and I was wondering if I can run 22x14. I called over 3 shops and they are all telling me I can't run it and it is impossible but when I look on the custom offsets website people are running it with no rubbing or trimming. I was wondering if anyone is running 33x12.5 on 22x14 and if they rub or trim. THANKS
  2. Dec 10, 2019 at 8:48 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Shop liability trumps what’s possible. Buy wheels, get tires mounted, install them yourself.
    joeyv141 and whatstcp like this.
  3. Dec 10, 2019 at 8:53 PM
    Cam2323
    6 inch lift
    I am not educated on insalling rims and tires so I will need a shop. I just wanted to see if it is possible without spacers.
  4. Dec 10, 2019 at 8:55 PM
    T4RFTMFW
    6 bolts off. 6 bolts on.
    No.
    I’d also suggest you’re not aware of the substantial wear and tear that will cause your truck or how to fix it, so this will be a financial worm hole above and beyond the cost of that wheel and tire combo.
  5. Dec 10, 2019 at 9:00 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Likely this is because of lability, my dealer will refuse to work on F150s on spacer lifts above 6 inches due to possibly being sued.
    In reality you can do it. I think you can run even bigger wheels if you want, hell break out the sawzall and most anything is possible.
  6. Dec 10, 2019 at 9:26 PM
    Muddinfun
    Muddinfun Well-Known Member
    So, this is the look you’re going for? 12.50 wide tires on 14 wide wheels?
    Memphis or Hawaii?
    outlawtacoma, DG92071 and Mo86 like this.
  7. Dec 10, 2019 at 10:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Barf.
    Muddinfun[QUOTED] and Mo86 like this.
  8. Dec 10, 2019 at 10:55 PM
    Cam2323
    6 inch lift
    Louisana. Yes I want the stretch look. But the shops are telling me it’s impossible to run it.
  9. Dec 10, 2019 at 10:58 PM
    tcjacado
    tcjacado Well-Known Member
    Not impossible, they just don't want to be responsible.
    DG92071 likes this.
  10. Dec 10, 2019 at 11:04 PM
    tcjacado
  11. Dec 11, 2019 at 1:47 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    What others have said it's a liability thing. Tire manufacturers have listed a safe rim width for given size tires. A 12.5 wide tire would be maximum on a 11.5 or 12 wide wheel for safety reasons. If a shop deviates from this and an accident occurs from a failure then they could possibly be sued and held liable for any injuries and property damage. I've seen the stretched look tires debead going down the highway not a very safe thing to have happen.
