33's yes or no
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Oct 25, 2020.
  1. Oct 25, 2020 at 7:04 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    33's...Yes or no?
    Saw a 4runner on 35's, guy said it takes too much work and isn't worth it. That 33's are easier.
    Currently am on 31's, 265 70 17. I think Jeeps come with that and Ford Ranger uses that size if equipped with Ford Performance fox shocks as their recommended size.
    Am thinking 33's MIGHT require crazy mods, like:
    -cab mount chop
    -trim plastic
    -different wheels for offset that sticks farther out
    -more lift
    -gearing upgrade
    really am not sure if stock gearing can handle it (6 lug TRD sport, might be 3.70)
    and how it'd affect MPG
    or if mild lifts can even handle it. Like 1.5-2" rear AAL and front spring lift (2" OME 883X)
    On one side, higher diameter would reduce RPM's in 6th cruising at highway speed. Which is usually better mpg.
    But if the tire tread is now further out (33" diameter) especially if the tire weighs more, that might reduce MPG because it could be harder to accelerate it in city driving and have worse rolling resistance if it's wider.
    Another option for 33 overall height is tall skinny tires like 250 (or 255?) / 80 / 17
    5 lug 2.7L tacomas seem to have torquier gearing (3.9?), 3rd gen manual is 4.3, and old 4runners even came as 4.88...
    Say you had mismatched tires wearing out. For next tire set, would you just keep doing 31's again? Or would you try 33's?
    the few pics I've seen of tall skinnies have had 3" lift
  2. Oct 25, 2020 at 7:10 PM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Stay with 31’s :thumbsup:
    BassAckwards, $yoda$, DR_CA68 and 3 others like this.
  3. Oct 25, 2020 at 7:17 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I would go tall skinny. 255/80r17. You get the ground clearance, it looks good, and the tires weigh less and have less rolling resistance. They are also easier to fit without any cutting.
    BassAckwards, Poncate, Sna and 2 others like this.
  4. Oct 25, 2020 at 7:19 PM
    Foster1
    Foster1 Well-Known Member
    California
    2023 SR V6 4x4
    I'd just go for 33s. Sounds like you want them and will regret it if you buy the same size tires again.
    Just get what you want in the first place.
    dk_crew and Slick Taco like this.
  5. Oct 25, 2020 at 7:23 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    not crazy, but yeah, this. All of it.
    Anthony 82, dk_crew and Slick Taco like this.
  6. Oct 25, 2020 at 7:25 PM
    ImMrCrash
    ImMrCrash Intermittent Error
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Bilstein 5100’s Dakar CS047R Supreme Suspension U-Bolt flip kit Sumo Springs Blue ADV Fiberglass Fenders 1st Gen Snorkel DV8 Apex Plate Bumper X-Bull 13k Winch KC HiLiTES 6x9 Trail-Gear Sliders 4x Innovations LCA Skids Spidertrax 1.25” Eagle Alloy 16x8 4” BS Fierce Attitude M/T 315/75R16 Bearcat 980SSB CB
    If it’s your daily and you don’t leave the pavement often I wouldn’t go larger, but I do love the look of a bigger tire.
    For me it wasn’t even a question to go bigger but I like to explore trails in the mountains so the added benefits of ground clearance and big tires to fill big dirt holes far exceeded any concerns I had for daily driving.
    I liked the large tires so much I did it again and went even bigger!
    crackils and Key-Rei like this.
  7. Oct 25, 2020 at 7:50 PM
    TacoTuesday1
    FL
    bigger tires look so much better
    plus with 31's if you air down to 20psi for grip on a trail, it just lowers the ride height a lot...
    I don't know why but a 35" I saw aired down to 15psi didn't even look aired down at all
    crhsharks12 likes this.
  8. Oct 25, 2020 at 7:52 PM
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    I have 315/75r16 (metric 35’s) now, E rated, and at 13 psi they barely bulge
    Edit: added image
    DavesTaco68 and Island Cruiser like this.
  9. Oct 25, 2020 at 9:23 PM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    Are you doing this for how it looks, or for off road? I have 255/85/16. I would never go with this size for commuting if That’s all I need it for. Reduced gas mileage, reduced power without gearing, etc.. but I am fortunate to have a Camry to drive to work. I wouldn’t go with a smaller tire for off road in my situation where I use my truck for hauling shit and off road only for the most part. Depends on what your needs are. If it’s just for looks I’m sure you can find a beefier looking tire that’ll look better but is not as large and heavy.
    badger and Sna like this.
  10. Oct 25, 2020 at 10:06 PM
    crhsharks12
    crhsharks12 Well-Known Member
    Denver, CO
    ‘06 Tacoma 4WD TRD Sport DCSB 4.0L V6
    RR 2.5 King shocks front/rear, Camburg UCA's, Icon AAL Springs Softopper & BA Bumper
    Yeah, I got 31.5” tires and honestly they are more than enough for most of my off off roading and camping adventures. And frankly, 33” is the highest you should go on a Tacoma that is a DD or is driven often/is not strictly for off road. Higher than 33 and you have to re gear and that’s a PITA. Plus, why? 33” have an amazing truck to tire ratio. To me, 35” tires look lame.
    32” inch also works well.
    Island Cruiser likes this.
  11. Oct 25, 2020 at 10:10 PM
    crhsharks12
    Denver, CO
    That’s a fair point about ride height. Although, I don’t sit down much on 31’s. 33 imo are a perfect tire size, but can be impractical. Depends on your driving amounts. Or a 32 Inch
  12. Oct 25, 2020 at 10:11 PM
    G-shock!
    G-shock! Well-Known Member
    OC TACOMAN
    Orange County
    2GTRD4L
    Fox 2.0 frt/resi rr PolyPerf. UCAs
    How about 275/70/17s which comes out to 32.2" tires? These are K02s and I only get a very slight rub on the UCA at full lock and it only happens in reverse. No CMC necessary and pretty close to 33's. I'm still at stock height for now...
    crackils, 007fodo and Foster1 like this.
  13. Oct 25, 2020 at 10:34 PM
    crhsharks12
    Denver, CO
    Is this with any body/suspension lift?
  14. Oct 25, 2020 at 11:00 PM
    G-shock!
    OC TACOMAN
    Orange County
    2GTRD4L
    All stock TRD Sport susp.- no lift.
    crhsharks12[QUOTED] likes this.
  15. Oct 25, 2020 at 11:04 PM
    airmax233
    airmax233 Always ready for the next adventure
    Southern California
    12 PreRunnerTrd sport R.I.P 21 Tacoma Off road 4x4
    2.5 Kings w/resi Adj. Total Chaos Upper control arms. IG: Cement_runner23
    Go with 33’s and don’t look back:burnrubber:
    crhsharks12 and Slick Taco like this.
  16. Oct 25, 2020 at 11:10 PM
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    Don't be so fooled by everyone saying re-gearing is an absolute must for 33's. The truck will be fine without it, it'll just be a little slower. Im on 34's (305/70/17) with no re-gear and really couldn't care less. These trucks were never made to go fast and if you need your acceleration that badly, why drive a pickup? It is nice to re-gear and feels a lot better with big tires, but it is not a necessity.
  17. Oct 25, 2020 at 11:22 PM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    I have 33 12.5 on a ‘14 with stock gears, perfectly fine. I had the same on a Jeep with stock gearing and couldn’t even put it in overdrive.
  18. Oct 25, 2020 at 11:48 PM
    Foster1
    California
    2023 SR V6 4x4
    Looks really good!
    G-shock![QUOTED] likes this.
  19. Oct 26, 2020 at 4:19 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    This is mine on 33's-255/85r16 to be exact. No rub out of the box with 2 1/2" lift. Rides the same as far as I can tell (came from 245/75r16's.) I have since cut the little tab thingy that hangs down in the front from the inner liner as at extension it was catching the lt side.
    007fodo, Anthony 82, jlemmond and 3 others like this.
  20. Oct 26, 2020 at 5:31 AM
    Sancho
    Sancho Active Member
    Silver Tacoma TRD Sport DCLB
    SCS Wheels Sr8 Rigid Lights Cooper 285/70/17 AT3 Toytec Lift 3" Excalibur Remote Start Truxport Tonneu Cover Bed Rug Viofo A129 duo camera Redline Hood Struts EZ down Tailgate Dampner 3M Tint Fumitomo Oil Valve Drain DIY MagFilter Husky Floor Mats
    I am at 33x12.5 Ko2's. No regear and no CMC. Love the look and MPG impact was minimal switching from 285s. Slight rub in reverse and full turn.
    I would make decision based on your lift size and what type of off-roading you do.
