33s with 6inch lift, show off your truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GreysonTHAO08, Apr 9, 2018.
  1. May 2, 2018 at 9:06 PM
    Yotaholic
    Yotaholic Well-Known Member
    Oahu, HI
    2017 DCSB Sport 4x4 MT
    I’m from Hawaii as well. Lots of 6” lifts with American Forces or some kind of flashy wheels rolling around here. Nice to see a 6” lift built with FUNCTION in mind brah! @alwaysHI :mudding:
    Wixo, camillethetoy and alwaysHI like this.
  2. May 2, 2018 at 9:13 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    From Hawaii? Sure... I don't see your "808" Sticker, Island chain sticker, your Natin2krazy sticker, or your tokunaga sticker. Hard to believe you...
    Naa J/K. you from Hilo side? I think I seen you around. Looks very clean man. who doing your regear?
    ksanti808 and Yotaholic like this.
  3. May 2, 2018 at 9:17 PM
    Yotaholic
    Oahu, HI
    You just can’t see the green bottlez and gold chain in the pics.
    ksanti808 and alwaysHI like this.
  4. May 2, 2018 at 9:19 PM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    I'll second that...:facepalm:
    travis.diller likes this.
  5. May 2, 2018 at 9:21 PM
    2016trdtacoma
    Trevor
    Utah
    Full retard, never go full retard:
  6. May 2, 2018 at 9:26 PM
    Yotaholic
    Oahu, HI
    In all realness, I can’t hate. Your money, your truck. Do what makes you happy.
    Wixo, Rockslide, SCJeffro and 5 others like this.
  7. May 2, 2018 at 9:43 PM
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    Thanks bro!
    Hahaha! My runner had Tokunaga sticker, I only have “toyoda” with master yoda on this one :p
    But yes, Hilo side.
    Thanks bro, I went thru Steve at Jimmy’s Radiator. He’s the son and does a little more diverse work, great job he did may I add. Only took one day
    i died reading this! Hahahaha
    Yotaholic[QUOTED] likes this.
  8. May 2, 2018 at 9:44 PM
    alwaysHI
    2017 MGM DCSB
    This is my coworkers truck..
    Wixo likes this.
  9. May 2, 2018 at 10:08 PM
    ahkouchi
    Andrew
    Big Island Hawaii
    Man I always recommend Steve. He is an awesome braddah. Good work and he is honest. He quoted me like 350 once for a job. When I went in, he said 275 cus he did It faster than the book said. Super good braddah.
    I was going ask him to do mine when the time came. Now I know he can.
    Hope you're on the right side of the lava flow. I'd love to see your truck sometime if you get time.
    alwaysHI[QUOTED] likes this.
  10. May 2, 2018 at 10:24 PM
    2016trdtacoma
    Trevor
    Utah
    hahah
    camillethetoy and Catfish21 like this.
  11. May 2, 2018 at 10:46 PM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    I Wanna see som of dem rollers with 6ench lif and 2ench body lif ya heard?
  12. May 2, 2018 at 10:47 PM
    Lunatic209
    Lunatic209 Well-Known Member
    17 Inferno TRD
    I would go 35's if it was me but 6 inch for sure
  13. May 2, 2018 at 10:50 PM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    People are hating probably because the geometry in the front suspension is thrown way out and you’re going to be loading the balljoints more and risk binding. Most other problems, like drivetrain angles, can be worked around somewhat, but the inherent limitations of the Toyota IFS are exaggerated when you go above 3” of lift. Keep it lower and you can extend the droop, have better articulation, and still have proper strut travel and suspension geometry. Jack it up 6” and all that goes to shit. This is why people say a 6” lift is for mall crawling or people who don’t care about fucking up the off road capabilities. Approach angle is great and all, but if your articulation is shot then you aren’t going to efficiently move over obstacles. Period.
    Edit: I’m an idiot and didn’t read/understand about this lift, so ignore me :)
    Tac0Man, wolf2600, Ctupton and 2 others like this.
  14. May 3, 2018 at 1:37 AM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    How do you figure all the geometry is gone to shit? Please explain how anything above 3 inches equates to ball join bindage and poor strut travel and geometry.
    Wixo, rlx02 and alwaysHI like this.
  15. May 3, 2018 at 1:52 AM
    #35
    alwaysHI
    2017 MGM DCSB
    What you put your tire over and what I put my tire over are completely different things. And I’m not talking about mall pavement.
    Ever heard of lava? That molten shit that comes out of the earth? If you’ve never been on true lava trails (and not the type that you tourist drive on when you visit) then you would understand.
    Guys with DB lifts get hassled, even guys with 3” lifts and STOCK UCA’s get hassled. There’s no win on TW.
    Do good, get talked bad. Do bad, still get talked bad about. Moral = don’t give a fuck.
    I second this
  16. May 3, 2018 at 1:58 AM
    #36
    Long Time Toy Fan
    Long Time Toy Fan Well-Known Member
    17 DCOR
    Cookie cutter Tacoma, 888/Dakars/LR/ECGS/Sliders
    JoeRacer, what you said would be correct if it were not a drop bracket lift. Basically this type of lift uses a bracket that bolts onto the bottom of the front end that is 3.5 or more inches lower that the arms bolt to. They then use a longer spindle that connects to the upper control arm keeping the suspension geometry correct. Essentially it lowers the front suspension rather than just cranking the A arms down for more height. These kits give a more height under the belly where it actually matters off road as well as better approach and departure angles. There are trade offs for having the higher center of gravity but they are very capable and better in a lot of situations. This is why I don't get the hate, I've seen them perform well on the trail. They're no comparison to a SAS obviously but neither is my OME kit.
    Edit: Hindsight, doing it again I'd go 4" Rough Country up front and Chevy's out back. I'd weld up the chopped crossmember like Diablo169 did for additional strength. Match that up with some 285/75R17 if the rims fit and call it a day. I spent too much money for not enough clearance although the road manners of my OME kit are great.
    Wixo, Rockslide, rlx02 and 5 others like this.
  17. May 3, 2018 at 1:59 AM
    #37
    alwaysHI
    2017 MGM DCSB
    I applaud you sir
  18. May 3, 2018 at 3:21 AM
    #38
    inksin
    Hawaii
    Totally agree. It's funny that you mentioned that lift combo, I'm using the 4 inch RC up front although I didn't have enough time to get to box it like Diablo169 did. That was a brilliant build and one of the most entertaining ones to read by far. I haven't gotten around to the 63s in the back yet but have my Archive Garage hangers sitting in the house waiting to be put to use. I did install the 63s on my '96 Tacoma in my avatar pic and they rode fantastic so it's a definite must do for me on my '16.
    I think JoeRacer just reinforced the theory that I go by, people that don't have much experience with suspensions parrot what they hear the "cool guys" say. They hear that DB lifts are created by Satan to cruise the Church parking lot while the manly men drive their 2 inch lifted with 37s Tacomas on the actual path that Jesus traveled over 2000 years ago and the only time their truck ever touches a foot of pavement is when Whole Foods is running a sale on granola. My truck has a drop bracket lift and a 1" body lift *gasp* which is enough ammo to be the object of hate by 75% of the people on TW. I have front end geometry that is close to stock in every aspect except the driveshaft angle and caster. I needed the extra caster to fit the 35s without cutting too much out of the fenderwell. Now I have 35s with minimal fenderwell cutting and LESS CV angles and ball joint wear then a 3" lift, quite the opposite of what JoeRacer suggests.
    AlwaysHI, we always gonna get the hate from people that think their way is the only way
  19. May 3, 2018 at 6:10 AM
    #39
    crappie man
    crappie man Well-Known Member
    sweet set up.
    alwaysHI and inksin[QUOTED] like this.
  20. May 3, 2018 at 9:15 AM
    #40
    JoeRacer302
    Joe
    Pasadena, CA
    Hey, thanks for explaining why I’m wrong about this lift. I totally understand now. I’m okay admitting I didn’t fully understand how this lift worked, and that I have some more studying to do about this stuff. Thanks again for taking time to explain about it so I could learn some.
