33s cause lots of stress on truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reto101, Jan 21, 2020.
  1. Jan 21, 2020 at 8:47 AM
    Reto101
    Reto101 [OP] Member
    2008 Tacoma Prerunner
    I have a 2008 prerunner 2wd with a little over 200,000 miles on it. If I get a 3in lift and 33s all terrains will that really stress the transmission and the truck in general? Do you think this is a good idea?
  2. Jan 21, 2020 at 8:47 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    It’ll be fine
    DG92071, VanDoom and Johnny DemonT like this.
  3. Jan 21, 2020 at 8:51 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    No, but you may start posting about bad mileage. Maybe not.
    whatstcp likes this.
  4. Jan 21, 2020 at 9:27 AM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    The chicks love lifted Taco's Do It Man!!! :benchpress:
  5. Jan 21, 2020 at 9:32 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    You'll notice it being slower especially if 4cyl but it'll work.
  6. Jan 21, 2020 at 9:41 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    No noticeable difference when I went 33's. I have a v6 and still get on it with no issues. These transmissions and differentials are quite strong. Most people SC without an issue so I would like to believe an NA setup and your typical 3" lift/33's will not make any component sneeze.
  7. Jan 21, 2020 at 10:05 AM
    badger
    badger Well-Known Member
    07 SR5
    In general 33's are OK, but it really depends on the specific tires and wheels. Without gearing, you will have reduced power on hills and towing. If you want the least impact on wear, stress, braking, acceleration, etc., Stick with factory wheels and narrower, light weight tires. This will mean searching the specs for the tires. Don't assume that a C rated tire weighs less than an E. If you want wide tires, wide wheels, etc., you will see the worst effects.
  8. Jan 21, 2020 at 10:40 AM
    tacomavan
    tacomavan Well-Known Member
    Oregon
    research the weights on your tire/wheel combo vs. stock and attempt to minimize it as much as possible while achieving your other aims (looks, traction, comfort, etc)
    Tacotj, whatstcp and will.i.was like this.
  9. Jan 21, 2020 at 10:43 AM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    I agree with the above statements. I attempted to mitigate any loss of power by reducing rotational mass.
    My 16x8 Enkei RPT1 weigh in at 18lbs and my Falken Wildpeak AT3W LT285/75r16 weigh 60lbs.
    Altogether the tire/wheel combo I am running is 78 lbs. I believe the stock wheel weight is 30-32 (sr5 16") and stock tires are 36 lbs.
    That puts me at about 10-12 lbs over stock, which is probably why the upgrade felt negligible in terms of mileage and power.
    davidstacoma and whatstcp like this.
  10. Jan 21, 2020 at 10:45 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    less power and less MPG with bigger tires than stock with out regearing
  11. Jan 21, 2020 at 10:47 AM
    Lol
    Lol Member
    SoCal
    2006 Access Cab Prerunner
    3.5" Long Travel with Fox Coilovers and All Pro leafs
    You will be fine. I'm running 35's. Only recommendation is that you should probably regear just for the your sanity and also your trucks sanity. Lol
  12. Jan 21, 2020 at 2:35 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Short answer, no, that isn't enough of a difference to damage the truck.
    Assuming your truck is equipped the same as most you'll effectively change the axle ratio from 3.73 to about 3.44 That means less power and the engine will have to work harder. But to be honest that isn't a huge difference. Most full size Chevy trucks come from the factory with 3.43 gears and 3.55's are the most commonly seen on Fords. But they have much more powerful engines too.
    You'll notice a little difference when driving in mountains or if towing. In fact the amount you tow should be reduced some to account for the power loss.
    Your speedometer will be off by about 5 mph at 65. If it says 65, you're actually driving closer to 70. The odometer will be off some too. If it says you've traveled 300 miles you've actually driven closer to 315. That needs to be taken into account when figuring fuel mileage and to prevent a speeding ticket.
  13. Jan 21, 2020 at 5:26 PM
    badger
    07 SR5
    Yes, and you are in Houston! It's pretty much dead flat there, and you are (occasionally) below sea level :D
    will.i.was[QUOTED] likes this.
  14. Jan 21, 2020 at 9:15 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    You are not wrong about that! :D Quite a large variable as well I may add...
  15. Jan 22, 2020 at 3:32 AM
    DG92071
    DG92071 Well-Known Member
    About a half second slower with a V6 and 37's in a 0-60 which I think would be on the extreme end of tire size choice for most people. 33's should be about 0.2 seconds slower with a V6 in a 0-60.
  16. Jan 22, 2020 at 3:57 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Do taller and wider tires add stress, of course they do, but you really need to look at the entire picture which includes the additional stresses that go with everything else one does before they stuff bigger tires under their vehicle. Heavy bumpers, winches, driveline angles [a real killer of parts life] all add their own stresses and unless you try to compensate to a degree by choosing well designed systems, you'll be wrenching on parts that would last 2-3 times as long under a stock height vehicle. [U joints, wheel bearings, ball joints, CV joints and axles themselves] And simple unsprung weight [tires and rims] can change how stresses are applied to certain parts.
  17. Jan 22, 2020 at 9:18 AM
    andrew61987
    Hard to quantify exactly how much less reliable they make things but for the most part I agree. This is why I went with 32s and 884 springs for the truck I do the most with way out far from help.
  18. Jan 22, 2020 at 9:41 AM
    Tacoma_SR5Pro
    Tacoma_SR5Pro Well-Known Member
    '16 SR5 Pro
  19. Jan 22, 2020 at 4:53 PM
    Reto101
    Reto101 [OP] Member
    Thank y’all so very much this helps a lot I live in Austin Tx and I do have a V6 4.0 L engine. I am currently thinking about 285/70/17 BFG KO2s with a Method NV 305 wheel. With a Pro Comp 3” lift kit. Does anybody have opinions on these?
  20. Jan 23, 2020 at 3:43 AM
    DG92071
    I'm fairly sure without changing the UCA it'll ride like crap.
